Home » Archived » XML Schema Definition (XSD) » particle.getElement()
particle.getElement() [message #55570] Tue, 30 November 2004 09:45 Go to next message
Originally posted by: ooi.ibm.com
I have a question.when reading out a schema, the return type of a particle
as a child from the sequence tag below is of type
org.apache.xerces.dom.DeferredElementNSImpl
but not org.w3c.dom.Element as I have expected it to be.
<element name="ServiceProperties">
<complexType>
<sequence>
<element ref="tns:OtherEnabledState" />
what is the reason for that? I have also tried to set the content of a
XSDModelGroup instance to this DeferredElementNSImpl but it doesnt work.
Thank you.
Re: particle.getElement() [message #55598 is a reply to message #55570] Tue, 30 November 2004 09:54 Go to previous messageGo to next message
HT,
That implementation class implements Element, so this should not be a
problem. You're not very clear on what you tried to do. In general, I
would not expect you to call setElement on anything but an XSDSchema...
HT Ooi wrote:
> particle as a child from the sequence tag below is of type
> org.apache.xerces.dom.DeferredElementNSImpl but not
> <complexType>
> <sequence>
> <element ref="tns:OtherEnabledState" /> .......
> a XSDModelGroup instance to this DeferredElementNSImpl but it doesnt
> work.
> Thank you.
Re: particle.getElement() [message #55624 is a reply to message #55598] Tue, 30 November 2004 10:08 Go to previous messageGo to next message
Ed,
yeah,I'm an absolute newbie in xml technologies. I was meaning to say
XSDElementDeclaration instead of the dom element. sorry..
how do I go about it then? i mean i can extract DeferredElementNSImpl when
I extract using getElement() of XSDParticleImpl from a modelGroup contents
which i read out.but i don't know how to add a DeferredElementNSImpl to a
XSDParticleImpl. It doesnt work using the setContent() method.
Ed Merks wrote:
> HT,
> HT Ooi wrote:
>> <complexType>
>> <sequence>
>> work.
>> Thank you.
Re: particle.getElement() [message #55650 is a reply to message #55624] Tue, 30 November 2004 11:00 Go to previous messageGo to next message
HT,
You should focus on either editing the DOM directly using only DOM APIs
(the XSD model will synchronize with your changes to the DOM) or editing
the XSD model directly using only the XSD APIs (the DOM will synchronize
with the changes in the XSD model). Don't try to edit by calling
setElement; that will never work. The XSDPrototypicalSchema has samples
for how to create all the types of XSD instances bottom up, so you
should have a look at those.
HT Ooi wrote:
> Ed,
> when I extract using getElement() of XSDParticleImpl from a modelGroup
> contents which i read out.but i don't know how to add a
> DeferredElementNSImpl to a XSDParticleImpl. It doesnt work using the
> Ed Merks wrote:
>> HT,
>> I would not expect you to call setElement on anything but an
>> XSDSchema...
>> HT Ooi wrote:
>>> Hi,
>>> <complexType>
>>> <sequence>
>>> doesnt work.
>>> Thank you.
Re: particle.getElement() [message #55677 is a reply to message #55650] Tue, 30 November 2004 11:10 Go to previous messageGo to next message
Originally posted by: ooi.de.ibm.com
Ed,
I undertand what you mean. I am actually concentrating on the XSD API's. I
am not using any DOM API. And I have looked throught the examples on how
to create.My question is how I read a schema. Please bear with me.
I dint use setElement in the Particle,I used setContent.I use getElement
only to read it out.
what I wanted to do was to copy the elements(<element
ref="tns:OtherEnabledState" />) in
<complexType>
<sequence>
and stick them in another complexType sequence. But i do not know how to
read them out properly as XSDElementDeclaration.
Thanks for your time.
> HT,
> HT Ooi wrote:
>> Ed,
>> Ed Merks wrote:
>>> HT,
>>> XSDSchema...
>>> HT Ooi wrote:
>>>> Hi,
>>>> <complexType>
>>>> <sequence>
>>>> doesnt work.
>>>> Thank you.
Re: particle.getElement() [message #55704 is a reply to message #55677] Tue, 30 November 2004 12:35 Go to previous messageGo to next message
--------------060505020801040700040604
HT,
XSDParticle.getContent will return either an XSDModelGroupDefinition, an
XSDModelGroup, or an XSDElementDeclaration. You need to do instanceof
to check for the one you are interested in.
To *copy *the content from one particle to another, you'd do something
like this:
otherXSDParticle.setContent((XSDParticleContent)xsdParticle. getContent().cloneConcreteComponent(true,
false))
But probably you really should be moving/copying the particles
themselves, not the content ...
HT Ooi wrote:
> Ed,
> API's. I am not using any DOM API. And I have looked throught the
> examples on how to create.My question is how I read a schema. Please
> bear with me.
> getElement only to read it out.
> <complexType>
> <sequence>
> to read them out properly as XSDElementDeclaration.
>> HT,
>> APIs (the XSD model will synchronize with your changes to the DOM) or
>> editing the XSD model directly using only the XSD APIs (the DOM will
>> synchronize with the changes in the XSD model). Don't try to edit by
>> calling setElement; that will never work. The XSDPrototypicalSchema
>> has samples for how to create all the types of XSD instances bottom
>> up, so you should have a look at those.
>> HT Ooi wrote:
>>> Ed,
>>> say XSDElementDeclaration instead of the dom element. sorry..
>>> DeferredElementNSImpl when I extract using getElement() of
>>> XSDParticleImpl from a modelGroup contents which i read out.but i
>>> don't know how to add a DeferredElementNSImpl to a XSDParticleImpl.
>>> Ed Merks wrote:
>>>> HT,
>>>> a problem. You're not very clear on what you tried to do. In
>>>> general, I would not expect you to call setElement on anything but
>>>> an XSDSchema...
>>>> HT Ooi wrote:
>>>>> Hi,
>>>>> <complexType>
>>>>> <sequence>
>>>>> of a XSDModelGroup instance to this DeferredElementNSImpl but it
>>>>> doesnt work.
>>>>> Thank you.
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
HT,<br>
<br>
an XSDModelGroup, or an XSDElementDeclaration.
Re: particle.getElement() [message #55731 is a reply to message #55704] Wed, 01 December 2004 08:18 Go to previous message
Tried moving the particles instead.It a good idea.. Thanks Ed.
Ed Merks wrote:
> HT,
> like this:
> false))
> HT Ooi wrote:
>> Ed,
>> bear with me.
>> <complexType>
>> <sequence>
>>> HT,
>>> HT Ooi wrote:
>>>> Ed,
>>>> Ed Merks wrote:
>>>>> HT,
>>>>> an XSDSchema...
>>>>> HT Ooi wrote:
>>>>>> Hi,
>>>>>> <complexType>
>>>>>> <sequence>
>>>>>> doesnt work.
>>>>>> Thank you.
Re: particle.getElement() [message #592872 is a reply to message #55570] Tue, 30 November 2004 09:54 Go to previous message
HT,
HT Ooi wrote:
> <complexType>
> <sequence>
> work.
> Thank you.
Re: particle.getElement() [message #592885 is a reply to message #55598] Tue, 30 November 2004 10:08 Go to previous message
Ed,
Ed Merks wrote:
> HT,
> HT Ooi wrote:
>> <complexType>
>> <sequence>
>> work.
>> Thank you.
Re: particle.getElement() [message #592894 is a reply to message #55624] Tue, 30 November 2004 11:00 Go to previous message
HT,
HT Ooi wrote:
> Ed,
> Ed Merks wrote:
>> HT,
>> XSDSchema...
>> HT Ooi wrote:
>>> Hi,
>>> <complexType>
>>> <sequence>
>>> doesnt work.
>>> Thank you.
Re: particle.getElement() [message #592907 is a reply to message #55650] Tue, 30 November 2004 11:10 Go to previous message
Ed,
<complexType>
<sequence>
> HT,
> HT Ooi wrote:
>> Ed,
>> Ed Merks wrote:
>>> HT,
>>> XSDSchema...
>>> HT Ooi wrote:
>>>> Hi,
>>>> <complexType>
>>>> <sequence>
>>>> doesnt work.
>>>> Thank you.
Re: particle.getElement() [message #592918 is a reply to message #55677] Tue, 30 November 2004 12:35 Go to previous message
HT,
like this:
false))
HT Ooi wrote:
> Ed,
> bear with me.
> <complexType>
> <sequence>
>> HT,
>> HT Ooi wrote:
>>> Ed,
>>> Ed Merks wrote:
>>>> HT,
>>>> an XSDSchema...
>>>> HT Ooi wrote:
>>>>> Hi,
>>>>> <complexType>
>>>>> <sequence>
>>>>> doesnt work.
>>>>> Thank you.
<html>
<head>
<title></title>
</head>
HT,<br>
<br>
Re: particle.getElement() [message #592935 is a reply to message #55704] Wed, 01 December 2004 08:18 Go to previous message
Ed Merks wrote:
> HT,
> like this:
> false))
> HT Ooi wrote:
>> Ed,
>> bear with me.
>> <complexType>
>> <sequence>
>>> HT,
>>> HT Ooi wrote:
>>>> Ed,
>>>> Ed Merks wrote:
>>>>> HT,
>>>>> an XSDSchema...
>>>>> HT Ooi wrote:
>>>>>> Hi,
>>>>>> <complexType>
>>>>>> <sequence>
>>>>>> doesnt work.
>>>>>> Thank you.
Previous Topic:particle.getElement()
Next Topic:Node -> XSDConcreteComponent
Current Time: Sun Jul 27 08:49:19 EDT 2025
Powered by FUDForum. Page generated in 0.08707 seconds
