Home » Eclipse Projects » Mylyn » Generic Web named expressions ({Id}.+?) - are these supported?
Generic Web named expressions ({Id}.+?) - are these supported? [message #55555] Thu, 07 August 2008 14:05 Go to next message
Documentation for Generic Connector at
http://wiki.eclipse.org/index.php/Mylyn_User_Guide#Generic_W eb_Repository_Connector
indicates that I can define expressions like this:
Note: Query Pattern field should be a regexp with 1st matching group on
Issue ID and 2nd on Issue Description. Alternatively, you could use named
matching groups: ({Id}.+?), ({Description}.+?), ({Status}.+?), ({Owner}.+?)
and ({Type}.+?), then they can appear in query regexp in an arbitrary order.
The second option requires build 2.0.0v20070717 or later.
I tried to build pattern using the alternat form ... ({Id}.+?) ... but I get
expression errors.
I'm using Ganymede, and all mylyn related plugin jars have version numbers
of 3. something with build dates 2008...
The generic web plugin is
org.eclipse.mylyn.web.tasks_3.0.1.v20080721-2100-e3x.jar.
Question: Is this feature for naming the patterns supported, or possibly the
documentation is wrong?
Michael
Re: Generic Web named expressions ({Id}.+?) - are these supported? [message #55584 is a reply to message #55555] Thu, 07 August 2008 15:41 Go to previous messageGo to next message
The error you are seeing may be caused by a regression in Mylyn 3.0 that has
been reported here:
243131: [web connector] named regex groups don't work with 3.4
https://bugs.eclipse.org/bugs/show_bug.cgi?id=243131
Please comment on the bug report with the expression that is failing for
you.
Thanks.
Steffen
> ({Owner}.+?) and ({Type}.+?), then they can appear in query regexp in an
> arbitrary order. The second option requires build 2.0.0v20070717 or later.
> get expression errors.
> the documentation is wrong?
> Michael
Re: Generic Web named expressions ({Id}.+?) - are these supported? [message #55611 is a reply to message #55584] Thu, 07 August 2008 16:26 Go to previous messageGo to next message
I have added a comment to the bug.
What I find is that {Id} causes the parsing error: null pointer. Any of the
other keywords cause a message that taskId and summary must be specified
(see bug for exact message).
Also, I believe that if using named matching groups that it is necessary for
all matching groups to be named. If this is a rule, the NOTE regarding the
alternate form using named matching groups should be updated.
Michael
"Steffen Pingel" <steffen.pingel@tasktop.com> wrote in message
news:g7fj4g$3r9$1@build.eclipse.org...
> has
> been reported here:
> you.
> Thanks.
> Steffen
>> later.
>> numbers
>> Michael
Re: Generic Web named expressions ({Id}.+?) - are these supported? [message #56882 is a reply to message #55584] Wed, 27 August 2008 13:43 Go to previous message
Steffen,
Have installed the weekly build and the named expressions are working just
fine.
Michael
Re: Generic Web named expressions ({Id}.+?) - are these supported? [message #592295 is a reply to message #55555] Thu, 07 August 2008 15:41 Go to previous message
been reported here:
you.
Thanks.
Steffen
> Michael
Re: Generic Web named expressions ({Id}.+?) - are these supported? [message #592303 is a reply to message #55584] Thu, 07 August 2008 16:26 Go to previous message
Michael
> has
> been reported here:
> you.
> Thanks.
> Steffen
>> later.
>> numbers
>> Michael
Re: Generic Web named expressions ({Id}.+?) - are these supported? [message #592873 is a reply to message #55584] Wed, 27 August 2008 13:43 Go to previous message
Steffen,
fine.
Michael
Previous Topic:Creating tasks programmatically
Next Topic:Generic Web Connector configuration: How are URLs used?
Current Time: Fri Nov 21 07:55:38 EST 2025
Powered by FUDForum. Page generated in 0.09160 seconds
