Home » Modeling » TMF (Xtext) » [xText] syntax highlighting
[xText] syntax highlighting [message #55525] Fri, 03 July 2009 10:58 Go to next message
Originally posted by: anders.hessellund.gmail.com
my first little grammar is progressing and the editor-features that
xText allows with minimal code are amazing! I am, however, a bit stuck
on the syntax highlighting part. The documentation is a bit too
abstract. Specifically, in the grammar below, I'd like to do thing like
making XML elements bold. What are the steps, I need to go through?
Anders
grammar c.m.XmlGrammar with org.eclipse.xtext.common.Terminals
generate xmlGrammar "http://www.example.com/XmlGrammar"
Model :
(productions+=Production)*
Production :
name=ID '=' expression=OrExpression ';'
OrExpression :
Expression ( '|' right=OrExpression )?
Expression :
XmlElement |
expressions=QuantifiedExpression+
XmlElement :
XmlNonTerminal |
XmlTerminal
XmlNonTerminal :
'<' begin=ID '>'
expression=Expression
'</' end=ID '>'
XmlTerminal :
'<' name=ID '/>'
QuantifiedExpression :
TerminalExpression ( '?' | '*' | '+' )?
TerminalExpression :
name=[Production] |
'(' expression=OrExpression ')'
Re: [xText] syntax highlighting [message #55552 is a reply to message #55525] Fri, 03 July 2009 11:40 Go to previous messageGo to next message
Hi Anders,
in your case, you'll need semantic highlighting.
First of all, please register a highlighting configuration. It should
look like this:
public class SemanticHighlightingConfiguration
implements ISemanticHighlightingConfiguration {
public final static String XML = "XML";
public void configure(
IHighlightingConfigurationAcceptor acceptor) {
acceptor.acceptDefaultHighlighting(XML, "XML Element",
xmlStyle());
public TextStyle defaultTextStyle() {
TextStyle textStyle = new TextStyle();
textStyle.setBackgroundColor(new RGB(255, 255, 255));
textStyle.setColor(new RGB(0, 0, 0));
return textStyle;
public TextStyle xmlStyle() {
TextStyle textStyle = defaultTextStyle().copy();
textStyle.setStyle(SWT.BOLD);
return textStyle;
The second part is to implement the algorithm, that computes the
highlighted ranges in your file:
public class SemanticHighlightingCalculator implements
ISemanticHighlightingCalculator {
public void provideHighlightingFor(XtextResource resource,
IHighlightedPositionAcceptor acceptor) {
if (resource == null)
return;
Iterator<EObject> iter =
EcoreUtil.getAllContents(resource, true);
while(iter.hasNext()) {
EObject current = iter.next();
if (current instanceof XmlNonTerminal) {
AbstractNode begin =
getFirstFeatureNode(current,
XmlGrammar.Literals.XML_NON_TERMINAL__BEGIN.getName());
highlightNode(begin, SemanticHighlightingConfiguration.XML, acceptor);
AbstractNode end =
XmlGrammar.Literals.XML_NON_TERMINAL__END.getName());
highlightNode(end, SemanticHighlightingConfiguration.XML, acceptor);
} else if (current instanceof XmlTerminal) {
AbstractNode name = getFirstFeatureNode(current,
XmlGrammar.Literals.XML_TERMINAL__NAME.getName());
highlightNode(node, SemanticHighlightingConfiguration.XML, acceptor);
private void highlightNode(AbstractNode node, String id,
if (node == null)
return;
if (node instanceof LeafNode) {
acceptor.addPosition(node.getOffset(), node.getLength(), id);
} else {
for (LeafNode leaf: node.getLeafNodes()) {
if (!leaf.isHidden()) {
acceptor.addPosition(leaf.getOffset(), leaf.getLength(), id);
public AbstractNode getFirstFeatureNode(EObject semantic, String feature) {
NodeAdapter adapter = NodeUtil.getNodeAdapter(semantic);
if (adapter != null) {
CompositeNode node = adapter.getParserNode();
if (node != null) {
for (AbstractNode child: node.getChildren()) {
if (child instanceof LeafNode) {
if (feature.equals(((LeafNode) child).getFeature())) {
return child;
return null;
To enable the bold style for the '<' and '>' -signs as well, you should
go with the token to id mapper as it is responsible for the highlighting
configuration of keywords. Please try something like this:
public class TokenToIdMapper extends DefaultAntlrTokenToAttributeIdMapper {
protected String calculateId(String tokenName, int tokenType) {
if ("'<'".equals(tokenName) || "'/>'".equals(tokenName) ||
"'>'".equals(tokenName)) {
return SemanticHighlightingConfiguration.XML;
Finally don't forget to bind your implementations in your ui module:
public class XmlGrammarUiModule extends AbstractXtextUiModule {
public Class<? extends ISemanticHighlightingCalculator>
bindISemanticHighlightingCalculator() {
return SemanticHighlightingCalculator.class;
public Class<? extends ISemanticHighlightingConfiguration>
bindISemanticHighlightingConfiguration() {
return SemanticHighlightingConfiguration.class;
public Class<? extends AbstractAntlrTokenToAttributeIdMapper>
bindTokenToAttributeIdMapper() {
return DefaultAntlrTokenToAttributeIdMapper.class;
Can you please elaborate on what you mean by "to abstract" in the
appropriate section of the documentation? I'ld be happy to improve it :-)
Hope that helps,
Sebastian
btw: the code snippets come without any guarantee ;-)
Am 03.07.2009 16:58 Uhr, schrieb Anders Hessellund:
> Anders
> Model :
> Production :
> OrExpression :
> Expression :
> XmlElement |
> XmlElement :
> XmlNonTerminal |
> XmlTerminal
> XmlNonTerminal :
> '<' begin=ID '>'
> '</' end=ID '>'
> XmlTerminal :
> '<' name=ID '/>'
> name=[Production] |
Re: [xText] syntax highlighting [message #55634 is a reply to message #55552] Fri, 03 July 2009 15:43 Go to previous messageGo to next message
Sebastian Zarnekow wrote:
> Hi Anders,
> look like this:
> xmlStyle());
> return textStyle;
> return textStyle;
> return;
> AbstractNode end =
> highlightNode(end,
> highlightNode(node,
> if (node == null)
> return;
> } else {
> feature) {
> if (node != null) {
> return child;
> return null;
> @Override
> Hope that helps,
> Sebastian
>> Thanks,
>> Anders
>> Model :
>> Production :
>> OrExpression :
>> Expression :
>> XmlElement |
>> XmlElement :
>> XmlNonTerminal |
>> XmlTerminal
>> XmlNonTerminal :
>> '<' begin=ID '>'
>> '</' end=ID '>'
>> XmlTerminal :
>> '<' name=ID '/>'
>> name=[Production] |
Thanks a lot!!
This was extremely helpful!
My comment about the documentation being "too abstract" is, I think,
mainly due to the lack of a proper recipe. Since syntax coloring is
probably the first thing most people will turn too when they succeed in
generating an editor, it would make sense to have a step-by-step recipe
(like the one you gave me above). I could probably have figured some of
these things out but it would have taken a lot more time since javadoc
appears to be missing.
Anyway, I don't mean to mock xText. I am actually extremely impressed
with your product and very pleased with the rapid community feedback.
Anders
Re: [xText] syntax highlighting [message #55661 is a reply to message #55634] Fri, 03 July 2009 16:03 Go to previous messageGo to next message
Hi Anders,
see below.
Am 03.07.2009 21:43 Uhr, schrieb Anders Hessellund:
[snip]
> Thanks a lot!!
Thanks for the hint, I think I can add something similar to the docs.
Btw: Have you tried the version that can be downloaded from the itemis
website http://Xtext.itemis.com ?
It is more up to date (slightly) and contains some javadocs for the
syntax highlighter. Nevertheless we are aware of the fact, that some
large pieces of the Xtext framework lack comprehensive javadocs and we
try to improve it steadily.
Thanks for the nice words.
Sebastian
> Anders
Re: [xText] syntax highlighting [message #55816 is a reply to message #55661] Mon, 06 July 2009 04:45 Go to previous message
No, I haven't tried that yet.
Btw, when you're updating the documentation, you might want to consider
adding a note about the deployment process. Specifically, which features
(antlr, xtext etc) do you need when deploying a generated xText editor
as a plugin or a feature.
Anders
Previous Topic:Re: first time problem running workflow (mwe 0.7.0)
Next Topic:DataType XMLGregorianCalendar
Current Time: Sat Jul 19 02:17:03 EDT 2025
Powered by FUDForum. Page generated in 0.09114 seconds
