Home » Eclipse Projects » GEF » Drag-and -Drop & Icons
Drag-and -Drop & Icons [message #55499] Fri, 17 January 2003 06:06 Go to next message
Originally posted by: jan.odvarko.schemantix.com
Hi All,
How can I change the icons, which are displayed
during a drag-and-drop operation?
thanks for all tips
Honza
Re: Drag-and -Drop & Icons [message #55553 is a reply to message #55499] Fri, 17 January 2003 12:21 Go to previous messageGo to next message
What do you mean by "icons"?
Eric
Jan Odvárko wrote:
> Hi All,
> thanks for all tips
> Honza
Re: Drag-and -Drop & Icons [message #56593 is a reply to message #55553] Mon, 20 January 2003 12:20 Go to previous messageGo to next message
oops
I meant the cursors, which are used during that operation...
Honza
"Eric Bordeau" <ebordeau@us.ibm.com> wrote in message
news:b09d2t$aa2$1@rogue.oti.com...
> Eric
> Jan Odv
Re: Drag-and -Drop & Icons [message #56698 is a reply to message #56593] Mon, 20 January 2003 13:32 Go to previous messageGo to next message
The cursor is based on the current DropTargetEvent's detail field, which can be DND.DROP_NONE,
DND.DROP_MOVE, DND.DROP_COPY, or DND.DROP_LINK. Changing the detail should change the cursor to the
appropriate one.
Eric
Jan Odvárko wrote:
> oops
> Honza
>>Eric
>>Jan Odvárko wrote:
>>>Hi All,
>>>thanks for all tips
>>>Honza
Re: Drag-and -Drop & Icons [message #57565 is a reply to message #56698] Thu, 23 January 2003 09:57 Go to previous messageGo to next message
Yeah, I see...
Another question, is there any chance to supply my own cursors?
Thanks again
Honza
news:b0he9p$79n$4@rogue.oti.com...
> appropriate one.
> Eric
> Jan Odv
Re: Drag-and -Drop & Icons [message #57706 is a reply to message #57565] Thu, 23 January 2003 13:01 Go to previous messageGo to next message
I'm not sure. That would be a good question for the SWT folks.
Jan Odvárko wrote:
> Yeah, I see...
> Thanks again
> Honza
>>appropriate one.
>>Eric
>>Jan Odvárko wrote:
>>>oops
>>>Honza
>>>>Eric
>>>>Jan Odvárko wrote:
>>>>>Hi All,
>>>>>thanks for all tips
>>>>>Honza
Re: Drag-and -Drop & Icons [message #57871 is a reply to message #57565] Fri, 24 January 2003 13:38 Go to previous messageGo to next message
Yes, you can do that. To create your own cursors, look at
org.eclipse.graphics.swt.Cursor. In particular, the following constructor:
public Cursor(Device device, ImageData source, ImageData mask, int hotspotX,
int hotspotY)
Pratik Shah
"Jan Odv
Re: Drag-and -Drop & Icons [message #57895 is a reply to message #57871] Fri, 24 January 2003 14:16 Go to previous messageGo to next message
I think the question was whether a custom cursor can be used during drag and drop. I'm not sure of
the answer to this. You would be better off to ask this question on the eclipse.tools newsgroup.
The SWT folks should be able to answer this. If I had to venture a guess, I would say this is not
currently possible. But, again, I don't know for sure.
Eric
> int hotspotY)
> Pratik Shah
> "Jan Odvárko" <jan.odvarko@schemantix.com> wrote in message
> news:b0oupi$8u6$1@rogue.oti.com...
>>Yeah, I see...
>>Thanks again
>>Honza
>>>appropriate one.
>>>Eric
>>>Jan Odvárko wrote:
>>>>oops
>>>>Honza
>>>>>Eric
>>>>>Jan Odvárko wrote:
>>>>>>Hi All,
>>>>>>thanks for all tips
>>>>>>Honza
Re: Drag-and -Drop & Icons [message #58947 is a reply to message #55499] Tue, 28 January 2003 15:48 Go to previous message
You cannot change the Cursor during DND. This is probably because of Motif
or some platform that doesn't support changing the cursor. Windows CE
maybe?
"Jan Odv
Previous Topic:Rich Text Editor
Next Topic:Make Label to have several editable parts?
Current Time: Sun Aug 31 05:17:26 EDT 2025
Powered by FUDForum. Page generated in 0.03777 seconds
