Home » General (non-technical) » Eclipse Foundation » Eclipse test-suite
Eclipse test-suite [message #55493] Mon, 04 August 2008 07:58 Go to next message
Hello everyone!
Could anybody give me a link to the whole test-suite that is used for
releasing the Eclipse IDE?
At this page of eclipsepedia
--http://wiki.eclipse.org/Automated_Testing#Correctness_test s --
It is explained how to run the Eclipse tests and short list of plugins
(not all though) that I will likely need for this.
However, there is no link to how to download and install these plugins. I
failed to find the plugins by myself: I have found them in CVS repository
but not in downloadable form. So do they exist in a public available
binary form?
Thanx,
Nikita
Re: Eclipse test-suite [message #55520 is a reply to message #55493] Tue, 05 August 2008 03:40 Go to previous messageGo to next message
Nikita Lipsky wrote:
> Hello everyone!
> plugins. I failed to find the plugins by myself: I have found them in
> CVS repository but not in downloadable form. So do they exist in a
> public available binary form?
Each download page contains different downloads. Among them are normally
also the tests.
e.g.
http://download.eclipse.org/eclipse/downloads/drops/R-3.4-20 0806172000/index.php
Dani
> Thanx,
> Nikita
Re: Eclipse test-suite [message #55599 is a reply to message #55520] Wed, 06 August 2008 04:54 Go to previous messageGo to next message
Thank you very much!
It is exactly what I was looking for :)
--Nikita
"Daniel Megert" <daniel_megert@ch.ibm.com> wrote in message
news:g7904k$6a0$1@build.eclipse.org...
>> Hello everyone!
>> At this page of
>> eclipsepedia --http://wiki.eclipse.org/Automated_Testing#Correctness_test s
>> I failed to find the plugins by myself: I have found them in CVS
>> repository but not in downloadable form. So do they exist in a public
> also the tests.
> e.g.
> Dani
>> Thanx,
>> Nikita
Re: Eclipse test-suite [message #55626 is a reply to message #55520] Thu, 07 August 2008 05:53 Go to previous messageGo to next message
Hello again,
Ok, I have passed the tests and got 44 .html files with results. Is there
any way to combine them together to see overall results in one html file
like
http://download.eclipse.org/eclipse/downloads/drops/R-3.4-20 0806172000/testResults.php ?
There are some failures in results. There is a note in results "failures are
anticipated and checked for with assertions while errors are unanticipated."
So should I think that test passes if it fails by failure not by error?
Is there a way to pass a test (not a group of tests) separately? Do I need
check out the test or the group of tests from CVS for this? Is there any GUI
(plug-in to Eclipse?) for running tests separately and configuring them like
JCK JavaTest harness?
--Nikita
>> Hello everyone!
>> At this page of
> also the tests.
> e.g.
> Dani
>> Thanx,
>> Nikita
Re: Eclipse test-suite [message #55658 is a reply to message #55626] Mon, 11 August 2008 04:08 Go to previous messageGo to next message
> Hello again,
> there any way to combine them together to see overall results in one
> html file like
> "failures are anticipated and checked for with assertions while errors
> are unanticipated." So should I think that test passes if it fails by
Do you have a concrete example? Normally the test should either be green
or red but might log some errors in the console even if the test itself
is green.
> need check out the test or the group of tests from CVS for this? Is
> there any GUI (plug-in to Eclipse?) for running tests separately and
> configuring them like JCK JavaTest harness?
AFAIK there's no GUI.
You might find some answers here:
http://wiki.eclipse.org/index.php/Platform-releng-faq
Dani
> --Nikita
>>> Hello everyone!
>>> for releasing the Eclipse IDE?
>>> plugins (not all though) that I will likely need for this.
>>> in CVS repository but not in downloadable form. So do they exist in
>>> a public available binary form?
>> normally also the tests.
>> e.g.
>> Dani
>>> Thanx,
>>> Nikita
Re: Eclipse test-suite [message #55681 is a reply to message #55658] Tue, 12 August 2008 03:58 Go to previous messageGo to next message
news:g7os1d$3fr$1@build.eclipse.org...
>> are anticipated and checked for with assertions while errors are
>> unanticipated." So should I think that test passes if it fails by failure
>> not by error?
> or red but might log some errors in the console even if the test itself is
> green.
See for instance this link:
http://download.eclipse.org/eclipse/downloads/drops/R-3.4-20 0806172000/testresults/html/org.eclipse.releng.tests_linux.g tk.x86.html
There is 1 failtire, sucess rate 80%, however it is reported in the overall
page as all-passed: "(0)"
Thank you, I will check it.
Nikita
Re: Eclipse test-suite [message #55708 is a reply to message #55681] Tue, 12 August 2008 04:21 Go to previous message
>>> errors are unanticipated." So should I think that test passes if it
>> green or red but might log some errors in the console even if the
>> test itself is green.
> overall page as all-passed: "(0)"
Yes, that was "fixed" manually on the main page(s) because the reported
error was known/intended. This is also done when a test fails for
unknown reasons and a rerun makes the failure go away: instead of doing
a full rebuild the pages are adjusted manually.
Dani
> Nikita
Previous Topic:RCP Webinar - Aug. 26
Next Topic:A Second RCP Webinar - Sep. 4
Current Time: Thu Nov 06 14:07:24 EST 2025
Powered by FUDForum. Page generated in 0.06955 seconds
