Home » Language IDEs » C / C++ IDE (CDT) » Can't build, can't debug...
Can't build, can't debug... [message #55481] Fri, 27 December 2002 04:21 Go to next message
Originally posted by: dd.oal.com
I am using Eclipse R2.0.2 on Windows 2000, with CDT 1.0.1.
I have made a minimum C++ project (only 1 file with just main()!).
First problem: I can't build: nothing happens and I can see in the log:
at org.eclipse.cdt.internal.core.CBuilder.invokeMake(CBuilder.j ava:153)
So I used my own build command => it worked fine!
I can Run it, it works fine (euhh, in the "Launch properties" dialog, "C/C++
application" / "search" shows nothing, I have too specify my application by
myself ???!).
Finally, I can't debug it, because when I launch the debugger I have:
org.eclipse.core.runtime.CoreException[150]:
org.eclipse.cdt.debug.core.cdi.CDIException: Error initializing: Exec
error:Launching failed
org.eclipse.cdt.debug.mi.core.GDBDebugger.createLaunchSessio n(GDBDebugger.ja
va:47)
That makes a lot of troubles. Is my configuration not stable? Did I mess
somewhere?
Thanks a lot!
Re: Can't build, can't debug... [message #55508 is a reply to message #55481] Fri, 27 December 2002 04:17 Go to previous messageGo to next message
David wrote:
> java.lang.NullPointerException
> myself ???!).
Are you sure you specify makefile or/and path to make utility?
> at
> va:47)
> somewhere?
Make sure that you use correct version of gdb and path to gdb specifies
rightly
> Thanks a lot!
Igor S. Zamyatin
Interstron Ltd.
Re: Can't build, can't debug... [message #55562 is a reply to message #55508] Fri, 27 December 2002 07:26 Go to previous messageGo to next message
You're right.
Because the entry point for my make tool is a "make.bat", I was thinking the
"default command" was OK.
But it is NOT. "make" and "make.bat" are not interpreted the same way.....?
Why ? I was thinking it was the OS which was interpreting the command; for
the command "make" on Win 2000, it looks first for a "make.bat" then a
"make.com" and then a "make.exe"....
For the debugger, it was found on the path....
Thanks.....
David Dufour
Re: Can't build, can't debug... [message #55588 is a reply to message #55562] Fri, 27 December 2002 07:35 Go to previous message
David wrote:
> You're right.
You have to use standard "make" utility which you usually is situated in
C/C++ compilers such as MSVC and GCC. Also you have to write makefile.
Or you can use "External Tools" options of the project...
> Thanks.....
> David Dufour
Igor S. Zamyatin
Previous Topic:hpp file parsing
Next Topic:cygwin-gdb / Microsot Compiler
Current Time: Sun Nov 09 02:31:19 EST 2025
Powered by FUDForum. Page generated in 0.03737 seconds
