| Runtime workbech hangs after moving a node in graphical editor [message #55471] |
Fri, 17 January 2003 04:21 |
Originally posted by: rampi.mailcity.com
I am relatively new to GEF. I took the examples from the site
http://eclipsewiki.swiki.net/50 to get a hang of it. Then i modified one
of them to get a custom shape (i used polygon for that). With orginal
example i am able to move the rectangle from one location to other
location. And i saw that constraint that is being given is rectangle
itself.
I followed the same procedure and i gave the rectangle (got from the
getBounds() of the polygon) as the constraint for each and every node.
And i use this rectangle to get the new location. But if i move the node
with my custom shapes, then the workbench hangs. Only way to get rid of
it is to kill the process. I am using the latest build of GEF (I20030116)
It would be great if somebody could help me here.
Thanks in advance,
Rampi.
FUDForum. Page generated in 0.03282 seconds
