Home » Archived » Visual Editor (VE) » VE support for SWT
VE support for SWT [message #55448] Tue, 10 August 2004 00:49 Go to next message
Originally posted by: bgreerdev.earthlink.net
Why can't I see any SWT controls in the palette? All I get is AWT/Swing.
VE does support SWT right?
Using 1.0M2
Re: VE support for SWT [message #55533 is a reply to message #55448] Tue, 10 August 2004 07:25 Go to previous messageGo to next message
> Using 1.0M2
Did you follow the instructions here?
http://dev.eclipse.org/viewcvs/indextools.cgi/%7Echeckout%7E /vep-home/WebContent/docs/newAndNoteworthy/1.0.0-M2/previewi ngSWT.html
- Jeff
Re: VE support for SWT [message #55641 is a reply to message #55533] Tue, 10 August 2004 17:32 Go to previous messageGo to next message
> > Using 1.0M2
> - Jeff
Yes, that solves it. Thank you. What is so important about this?(besides
adding the library) Will VE only edit Visual classes? I can't seem to get
any of my other programs(classes) to open/display.
Re: VE support for SWT [message #55667 is a reply to message #55641] Tue, 10 August 2004 17:41 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
We key off the container to know what is available. If the SWT container
is not in the classpath then you can't add SWT controls because they
don't exist in your classpath. You can't add something you don't have
access to.
Thanks, Rich Kulp
Re: VE support for SWT [message #55694 is a reply to message #55533] Tue, 10 August 2004 17:50 Go to previous message
> > Using 1.0M2
> - Jeff
nevermind previous posting. found your article on source code recognition.
Thank again.(and did I mention you are really fast?)
- Ben
Re: VE support for SWT [message #597128 is a reply to message #55448] Tue, 10 August 2004 07:25 Go to previous message
> Using 1.0M2
- Jeff
Re: VE support for SWT [message #597171 is a reply to message #55533] Tue, 10 August 2004 17:32 Go to previous message
> > Using 1.0M2
> - Jeff
Re: VE support for SWT [message #597179 is a reply to message #55641] Tue, 10 August 2004 17:41 Go to previous message
access to.
Thanks, Rich Kulp
Re: VE support for SWT [message #597188 is a reply to message #55533] Tue, 10 August 2004 17:50 Go to previous message
> > Using 1.0M2
> - Jeff
- Ben
Previous Topic:Change class to visual class
Next Topic:Update VE over previous version?
Current Time: Tue Jul 22 01:47:40 EDT 2025
Powered by FUDForum. Page generated in 0.04805 seconds
