Home » Eclipse Projects » Simultaneous release » error updating Ganymede to Galileo
error updating Ganymede to Galileo [message #4940] Wed, 24 June 2009 12:08 Go to next message
Hello
I'm trying to update eclipse Ganymede to Galileo.
I added http://download.eclipse.org/releases/galileo to the update sites.
Eclipse recognizes the updates and tries to dl/install them but
encounters the following error:
An error occurred while collecting items to be installed
No repository found containing: com.ibm.icu/osgi.bundle/4.0.1.v20090415
com.jcraft.jsch/osgi.bundle/0.1.41.v200903070017
No repository found containing: javax.xml/osgi.bundle/1.3.4.v200902170245
org.apache.ant/osgi.bundle/1.7.1.v20090120-1145
org.apache.jasper/osgi.bundle/5.5.17.v200903231320
org.apache.xerces/osgi.bundle/2.9.0.v200909240008
org.apache.xml.resolver/osgi.bundle/1.2.0.v200902170519
org.apache.xml.serializer/osgi.bundle/2.7.1.v200902170519
org.eclipse.ant.core/osgi.bundle/3.2.100.v20090520
org.eclipse.ant.ui/osgi.bundle/3.4.0.v20090520
Error closing the output stream for
org.eclipse.cdt.gnu.build/org.eclipse.update.feature/6.0.0.2 00906161748
on repository file:/scream/home/farbea2/tools/eclipse/.
Error unzipping
/tmp/org.eclipse.cdt.gnu.build_6.0.0.20090616174813150227528 71639845.jar:
Invalid zip file format
org.eclipse.compare/osgi.bundle/3.5.0.I20090514-0808
org.eclipse.core.commands/osgi.bundle/3.5.0.I20090525-2000
org.eclipse.core.contenttype/osgi.bundle/3.4.0.v20090429-180 0
org.eclipse.core.databinding/osgi.bundle/1.2.0.I20090604-200 0
org.eclipse.core.databinding.beans/osgi.bundle/1.2.0.I200905 25-2000
org.eclipse.core.expressions/osgi.bundle/3.4.100.v20090429-1 800
org.eclipse.core.filebuffers/osgi.bundle/3.5.0.v20090526-200 0
org.eclipse.core.filesystem/osgi.bundle/1.2.0.v20090507
org.eclipse.core.jobs/osgi.bundle/3.4.100.v20090429-1800
org.eclipse.core.net/osgi.bundle/1.2.0.I20090522-1010
org.eclipse.core.net.linux.x86/osgi.bundle/1.1.0.I20081021
org.eclipse.core.resources/osgi.bundle/3.5.0.v20090512
org.eclipse.core.resources.compatibility/osgi.bundle/3.4.0.v 20090505
org.eclipse.core.runtime/osgi.bundle/3.5.0.v20090525
org.eclipse.core.runtime.compatibility/osgi.bundle/3.2.0.v20 090413
org.eclipse.core.runtime.compatibility.auth/osgi.bundle/3.2. 100.v20090413
org.eclipse.core.runtime.compatibility.registry/osgi.bundle/ 3.2.200.v20090429-1800
org.eclipse.core.variables/osgi.bundle/3.2.200.v20090521
org.eclipse.cvs/osgi.bundle/1.0.300.v200906051444
org.eclipse.debug.core/osgi.bundle/3.5.0.v20090526-1600
org.eclipse.debug.ui/osgi.bundle/3.5.0.v20090603
org.eclipse.draw2d/osgi.bundle/3.5.0.v20090528-1511
org.eclipse.ecf/osgi.bundle/3.0.0.v20090604-1131
org.eclipse.ecf.filetransfer/osgi.bundle/3.0.0.v20090604-113 1
org.eclipse.ecf.identity/osgi.bundle/3.0.0.v20090604-1131
org.eclipse.ecf.provider.filetransfer/osgi.bundle/3.0.0.v200 90604-1131
org.eclipse.ecf.provider.filetransfer.ssl/osgi.bundle/1.0.0. v20090604-1131
org.eclipse.ecf.ssl/osgi.bundle/1.0.0.v20090604-1131
org.eclipse.emf.common/osgi.bundle/2.5.0.v200906080927
org.eclipse.emf.common.ui/osgi.bundle/2.5.0.v200906080927
No ruinox.p2.ui.sdk/osgi.bundle/1.0.100.v20090520-1905
org.eclipse.equinox.p2.updatechecker/osgi.bundle/1.1.0.v2009 0520-1905
org.eclipse.equinox.p2.updatesite/osgi.bundle/1.0.100.v20090 525
org.eclipse.equinox.preferences/osgi.bundle/3.2.300.v2009052 0-1800
org.eclipse.equinox.registry/osgi.bundle/3.4.100.v20090520-1 800
org.eclipse.equinox.security/osgi.bundle/1.0.100.v20090520-1 800
org.eclipse.equinox.security.ui/osgi.bundle/1.0.100.v2009052 0-1800
org.eclipse.equinox.simpleconfigurator/osgi.bundle/1.0.100.v 20090520-1905
org.eclipse.equinox.simpleconfigurator.manipulator/osgi.bund le/1.0.100.v20090520-1905
org.eclipse.gef/osgi.bundle/3.5.0.v20090528-1511
org.eclipse.help/osgi.bundle/3.4.0.v20090526
org.eclipse.help.appserver/osgi.bundle/3.1.400.v20090429_180 0
org.eclipse.help.base/osgi.bundle/3.4.0.v200906051444
org.eclipse.help.ui/osgi.bundle/3.4.0.v20090528
org.eclipse.help.webapp/osgi.bundle/3.4.0.v20090429_1800
org.eclipse.jdt/osgi.bundle/3.5.0.v200906051444
org.eclipse.jdt.apt.core/osgi.bundle/3.3.200.v20090528-1135
org.eclipse.jdt.apt.pluggable.core/osgi.bundle/1.0.200.v2009 0526-2130
org.eclipse.jdt.apt.ui/osgi.bundle/3.3.200.v20090528-1135
org.eclipse.jdt.compiler.apt/osgi.bundle/1.0.200.v20090528-1 135
org.eclipse.jdt.compiler.tool/osgi.bundle/1.0.100.v_963
org.eclipse.jdt.core/osgi.bundle/3.5.0.v_963
org.eclipse.jdt.core.manipulation/osgi.bundle/1.3.0.v2009060 3
org.eclipse.jdt.debug/osgi.bundle/3.5.0.v20090526
org.eclipse.jdt.debug.ui/osgi.bundle/3.4.0.v20090527
org.eclipse.jdt.doc.user/osgi.bundle/3.5.0.v20090603-1530
org.eclipse.jdt.junit/osgi.bundle/3.5.0.v20090526-2000
org.eclipse.jdt.junit.runtime/osgi.bundle/3.4.100.v20090513- 2000
org.eclipse.jdt.junit4.runtime/osgi.bundle/1.1.0.v20090513-2 000
org.eclipse.jdt.launching/osgi.bundle/3.5.0.v20090527
org.eclipse.jdt.ui/osgi.bundle/3.5.0.v20090604
org.eclipse.jem.util/osgi.bundle/2.0.200.v200905140200
org.eclipse.jface/osgi.bundle/3.5.0.I20090525-2000
org.eclipse.jface.databinding/osgi.bundle/1.3.0.I20090525-20 00
org.eclipse.jface.text/osgi.bundle/3.5.0.v20090602
org.eclipse.jsch.core/osgi.bundle/1.1.100.I20090430-0408
org.eclipse.jsch.ui/osgi.bundle/1.1.200.I20090430-0408
org.eclipse.ltk.core.refactoring/osgi.bundle/3.5.0.v20090513 -2000
org.eclipse.ltk.ui.refactoring/osgi.bundle/3.4.100.v20090604
org.eclipse.osgi/osgi.bundle/3.5.0.v20090520
org.eclipse.osgi.services/osgi.bundle/3.2.0.v20090520-1800
org.eclipse.osgi.util/osgi.bundle/3.2.0.v20090520-1800
org.eclipse.platform/osgi.bundle/3.3.200.v200906051444
org.eclipse.platform.doc.user/osgi.bundle/3.5.0.v20090604-20 00
org.eclipse.rcp/osgi.bundle/3.5.0.v200906051444
org.eclipse.search/osgi.bundle/3.5.0.v20090526-2000
No repository found containing: org.eclipse.swt/osgi.bundle/3.5.0.v3550a
org.eclipse.swt.gtk.linux.x86/osgi.bundle/3.5.0.v3550a
org.eclipse.team.core/osgi.bundle/3.5.0.I20090527-0620
org.eclipse.team.cvs.core/osgi.bundle/3.3.200.I20090430-0408
org.eclipse.team.cvs.ssh2/osgi.bundle/3.2.200.I20090508-2000
org.eclipse.team.cvs.ui/osgi.bundle/3.3.200.I20090521-1750
org.eclipse.team.ui/osgi.bundle/3.5.0.I20090430-0408
org.eclipse.text/osgi.bundle/3.5.0.v20090513-2000
org.eclipse.ui/osgi.bundle/3.5.0.I20090604-2000
org.eclipse.ui.browser/osgi.bundle/3.2.300.v20090526
org.eclipse.ui.cheatsheets/osgi.bundle/3.3.200.v20090526
org.eclipse.ui.console/osgi.bundle/3.4.0.v20090513
org.eclipse.ui.editors/osgi.bundle/3.5.0.v20090527-2000
org.eclipse.ui.externaltools/osgi.bundle/3.2.0.v20090504
org.eclipse.ui.forms/osgi.bundle/3.4.0.v20090526
org.eclipse.ui.ide/osgi.bundle/3.5.0.I20090525-2000
org.eclipse.ui.ide.application/osgi.bundle/1.0.100.I20090525 -2000
org.eclipse.ui.intro/osgi.bundle/3.3.0.v20090526
org.eclipse.ui.intro.universal/osgi.bundle/3.2.300.v20090526
org.eclipse.ui.navigator/osgi.bundle/3.4.0.I20090525-2000
org.eclipse.ui.navigator.resources/osgi.bundle/3.4.0.I200905 25-2000
org.eclipse.ui.net/osgi.bundle/1.2.0.I20090430-0408
org.eclipse.ui.presentations.r21/osgi.bundle/3.2.100.I200810 07-0800
org.eclipse.ui.views/osgi.bundle/3.4.0.I20090525-2000
org.eclipse.ui.views.log/osgi.bundle/1.0.100.v20090527
org.eclipse.ui.views.properties.tabbed/osgi.bundle/3.5.0.I20 090429-1800
org.eclipse.ui.workbench/osgi.bundle/3.5.0.I20090603-2000
org.eclipse.ui.workbench.compatibility/osgi.bundle/3.2.0.I20 090429-1800
org.eclipse.ui.workbench.texteditor/osgi.bundle/3.5.0.v20090 603
org.eclipse.update.configurator/osgi.bundle/3.3.0.v20090312
org.eclipse.update.core/osgi.bundle/3.2.300.v20090525
org.eclipse.update.core.linux/osgi.bundle/3.2.100.v20081008
org.eclipse.update.scheduler/osgi.bundle/3.2.200.v20081127
org.eclipse.update.ui/osgi.bundle/3.2.200.v20090213
org.eclipse.wst.common.emf/osgi.bundle/1.1.300.v200905060430
org.eclipse.wst.common.emfworkbench.integration/osgi.bundle/ 1.1.300.v200811200330
org.eclipse.wst.common.frameworks/osgi.bundle/1.1.300.v20090 4160730
org.eclipse.wst.common.frameworks.ui/osgi.bundle/1.1.300.v20 0904160730
org.eclipse.wst.common.modulecore/osgi.bundle/1.1.300.v20090 4132230
org.eclipse.wst.common.project.facet.core/osgi.bundle/1.4.0. v200906080535
org.eclipse.wst.common.snippets/osgi.bundle/1.1.300.v2009031 20643
org.eclipse.wst.common.ui/osgi.bundle/1.1.402.v200901262305
org.eclipse.wst.common_core.feature/org.eclipse.update.featu re/3.1.0.v200903021835-7B77FXTF7RZHITIwQkLs_V
org.eclipse.wst.common_ui.feature/org.eclipse.update.feature /3.1.0.v200903021835-7B5FREDhdMNPm7dkmBmpUJxRlMta
org.eclipse.wst.dtd.core/osgi.bundle/1.1.300.v200904181727
org.eclipse.wst.dtd.ui/osgi.bundle/1.0.400.v200904300717
org.eclipse.wst.dtdeditor.doc.user/osgi.bundle/1.0.500.v2009 04292308
org.eclipse.wst.sse.core/osgi.bundle/1.1.400.v200905141750
org.eclipse.wst.sse.ui/osgi.bundle/1.1.100.v200905141750
org.eclipse.wst.standard.schemas/osgi.bundle/1.0.200.v200902 270215
org.eclipse.wst.validation/osgi.bundle/1.2.102.v200905201610
org.eclipse.wst.validation.ui/osgi.bundle/1.2.104.v200904232 035
org.eclipse.wst.xml.core/osgi.bundle/1.1.400.v200904300540
org.eclipse.wst.xml.ui/osgi.bundle/1.1.0.v200905242047
org.eclipse.wst.xml_core.feature/org.eclipse.update.feature/ 3.1.0.v200901260254-7C7OFPeF7RZHIXHnTz0Jqc0
org.eclipse.wst.xml_ui.feature/org.eclipse.update.feature/3. 1.0.v200905240756-7H6FMVDxtkM-5OgPGKK4xQocS5AL
org.eclipse.wst.xml_userdoc.feature/org.eclipse.update.featu re/3.1.1.v200906020459-50FR7AkF77f7MESDKEF
org.eclipse.wst.xmleditor.doc.user/osgi.bundle/1.0.600.v2009 01231300
org.eclipse.wst.xsd.core/osgi.bundle/1.1.401.v200903020335
org.eclipse.wst.xsd.ui/osgi.bundle/1.2.203.v200904300717
org.eclipse.wst.xsdeditor.doc.user/osgi.bundle/1.0.700.v2009 05182240
org.eclipse.xsd/osgi.bundle/2.5.0.v200906080927
org.eclipse.xsd.edit/osgi.bundle/2.5.0.v200906080927
org.junit/osgi.bundle/3.8.2.v20090203-1005
No repository found containing: org.junit4/osgi.bundle/4.5.0.v20090423
org.sat4j.core/osgi.bundle/2.1.0.v20090520
No repository found containing: org.sat4j.pb/osgi.bundle/2.1.0.v20090520
org.eclipse.compare.core/osgi.bundle/3.5.0.I20090430-0408
org.eclipse.core.databinding.observable/osgi.bundle/1.2.0.I2 0090604-2000
org.eclipse.core.databinding.property/osgi.bundle/1.2.0.I200 90526-2000
org.eclipse.cvs/org.eclipse.update.feature/1.1.100.v20090514 -7E79FEc9BJ99r9YEV6IOIF
org.eclipse.cvs_root/binary/1.1.100.v20090514-7E79FEc9BJ99r9 YEV6IOIF
org.eclipse.ecf.provider.filetransfer.httpclient/osgi.bundle /3.0.0.v20090604-1131
org.eclipse.ecf.provider.filetransfer.httpclient.ssl/osgi.bu ndle/1.0.0.v20090604-1131
org.eclipse.equinox.concurrent/osgi.bundle/1.0.0.v20090520-1 800
org.eclipse.equinox.ds/osgi.bundle/1.1.0.v20090601
org.eclipse.equinox.p2.publisher/osgi.bundle/1.0.0.v20090527 -1812
org.eclipse.equinox.p2.repository/osgi.bundle/1.0.0.v2009060 1-1921
org.eclipse.equinox.p2.repository.tools/osgi.bundle/1.0.0.v2 0090527-1812
org.eclipse.equinox.p2.ui.sdk.scheduler/osgi.bundle/1.0.0.v2 0090520-1905
org.eclipse.equinox.p2.user.ui/org.eclipse.update.feature/1. 1.0.v20090605-1440-7u6Fb3FbPbJP5MiKiZgpdl
org.eclipse.equinox.util/osgi.bundle/1.0.100.v20090520-1800
org.eclipse.help/org.eclipse.update.feature/1.1.0.v20090602- 7e7eFAlFEx2XZoYqvM67e6F
org.eclipse.jdt/org.eclipse.update.feature/3.5.0.v20090527-2 000-7r88FEeFJePyvYeA27DiZdc1
org.eclipse.jdt_root/binary/3.5.0.v20090527-2000-7r88FEeFJeP yvYeA27DiZdc1
org.eclipse.platform/org.eclipse.update.feature/3.5.0.v20090 605-9gEeG1HFtQcmRThO2V4dTfhVTK1JW1-J
org.eclipse.platform_root/binary/3.5.0.v20090605-9gEeG1HFtQc mRThO2V4dTfhVTK1JW1-J
org.eclipse.rcp.configuration_root.gtk.linux.x86/binary/1.0. 0.I20090605-1444
org.eclipse.rcp/org.eclipse.update.feature/3.5.0.v20090519-9 SA0FwxFv6x089BEe3TVh51
org.eclipse.rcp_root/binary/3.5.0.v20090519-9SA0FwxFv6x089BE e3TVh51
org.eclipse.team.cvs.ssh/osgi.bundle/3.2.100.I20090508-2000
org.hamcrest.core/osgi.bundle/1.1.0.v20090501071000
org.mortbay.jetty.server/osgi.bundle/6.1.15.v200905151201
org.mortbay.jetty.util/osgi.bundle/6.1.15.v200905182336
Re: error updating Ganymede to Galileo [message #5013 is a reply to message #4940] Wed, 24 June 2009 23:32 Go to previous messageGo to next message
Originally posted by: david_williams.linux.vnet.ibm.com
Alex Farberov wrote:
> Hello
> [ ... and many many more ... ]
That long list of errors does seem odd ... and not really sure what that
is from .... may have been a timing issue with the system a little
overloaded today.
BUT, upgrading from Ganymede to Galileo is not supported. You should
start off with one of the main packages found at
http://www.eclipse.org/downloads/ and then install other items into that
install.
Re: error updating Ganymede to Galileo [message #5076 is a reply to message #5013] Thu, 25 June 2009 10:50 Go to previous messageGo to next message
> install.
David,
Are you certain that Ganymede -> Galileo updates are really not
supported. One of the benefits of p2 was supposed to be the ability to
(finally) update across major releases.
Eric
Re: error updating Ganymede to Galileo [message #5142 is a reply to message #5076] Thu, 25 June 2009 13:37 Go to previous messageGo to next message
Eric Rizzo wrote:
> David,
Well, it's definitely not supported in the sense no one has tested it
(that I know of).
The way I heard it described was, to paraphrase, " ... it might work, in
some situations, depending on what you had installed, and what you were
updating, but it would never be perfectly correct (some things like
'config', eclipse executable etc., will never be updated) and it might
cause problems later", or something similar to that (but don't quote me :)
I'm not the definitive word (not being on p2 team) but that's my
understanding.
Re: error updating Ganymede to Galileo [message #5211 is a reply to message #5076] Thu, 25 June 2009 17:22 Go to previous message
Originally posted by: eclipseng.arthorne.com
The Galileo repository is using a completely new kind of repository
called a "composite repository". Since Eclipse 3.4 doesn't know anything
about this repository type, it can't find any artifacts (hence the "No
repository found..." errors). The metadata is otherwise completely
compatible between 3.4 and 3.5, so upgrades across releases are
theoretically possible. But, if your metadata takes advantage of new
concepts added in 3.5 (such as composite repositories), then previous
releases won't be able to process it.
Enabling major release upgrades while still allowing new releases to
make use of new features really requires a "staged" upgrade: upgrade p2
first, then use the new p2 to upgrade the rest. Some support for this
was added in 3.5, which should increase the number of cases where we can
support major-release upgrades in the future. Supporting upgrades across
major releases is on the draft plan for 3.6, but we've learned enough
about how complicated this really is that we won't be making any
promises until we're sure it will work ;)
>> that install.
> David,
> Eric
Re: error updating Ganymede to Galileo [message #567847 is a reply to message #4940] Wed, 24 June 2009 23:32 Go to previous message
> Hello
overloaded today.
install.
Re: error updating Ganymede to Galileo [message #567879 is a reply to message #5013] Thu, 25 June 2009 10:50 Go to previous message
> install.
David,
Eric
Re: error updating Ganymede to Galileo [message #567911 is a reply to message #5076] Thu, 25 June 2009 13:37 Go to previous message
Eric Rizzo wrote:
> David,
(that I know of).
understanding.
Re: error updating Ganymede to Galileo [message #567940 is a reply to message #5076] Thu, 25 June 2009 17:22 Go to previous message
>> that install.
> David,
> Eric
Previous Topic:error updating Ganymede to Galileo
Next Topic:Problem installing XML editors and tools from Galileo update site
Current Time: Thu Nov 20 20:51:19 EST 2025
Powered by FUDForum. Page generated in 0.06996 seconds
