Home » Modeling » M2T (model-to-text transformation) » Nested packages in input ecore file
Nested packages in input ecore file [message #55441] Wed, 14 January 2009 13:27 Go to next message
Hi Guys,
This is my first message on this board. I tried to create a JET project
with Rational Software Architect ("jet project with exemplar authoring").
I specified an ecore model file as input schema for my project. But
unfortunately the loader dialog says: Failed to load model
"/hf_model/Test_Model.ecore". I have tried with other models and realized
that the loader could have problems because i have nested packages in my
ecore model:
Package
|-------Package
|--------EClass
|-------Package
I didn't find any information about this. Is this a bug or did i something
worng? How can i solve this problem?
Heiko
Re: Nested packages in input ecore file [message #55601 is a reply to message #55441] Thu, 15 January 2009 09:20 Go to previous message
Heiko:
(btw, this is slightly off topic, as it concerns IBMs tooling around JET,
rather than JET itself.)
If I understand you correctly, you are trying to get RSAs JET authoring tool
to use your ecore model as the input model for your transformation. Bottom
line is, I don't think you will get it to work. The JET tooling only really
works with ecore models that it has produced. My suggestion: if you want to
use the JET exemplar authoring tooling, use it to define a meta-model that
mirrors your existing one, then bridge between using either a model-to-model
transformation.
Sorry I couldn't be more helpful. You might find more insights on Rational
Software Architect on the IBM Rational forums:
http://www-01.ibm.com/software/awdtools/architect/swarchitec t/support/community.html
Paul
Previous Topic:Efficient Development with a user plugin in JET2
Next Topic:When is generated file availible?
Current Time: Sun Nov 09 09:50:44 EST 2025
Powered by FUDForum. Page generated in 0.23599 seconds
