Home » Archived » Test and Performance Tools Platform (TPTP) » JWizardDialog text input
JWizardDialog text input [message #55430] Tue, 28 February 2006 05:41 Go to next message
Originally posted by: tom.andersson.accenture.com
Hi!
Is it a known issue that you can not perform actions on UI components
inside a JWizardDialog? We are having problems when trying to record text
input in a textfield inside a JWizardDialog. In InputDialog recording
seems to work fine.
We also tried to insert data to the textfields by manually changing the
macro script. As a result the content of the textfield changed to empty
instead of intended content. It did clear the textfield though.
Position-based recording seems to work fine but doesn't really suit our
needs that well.
Thanks!
Tom
Re: JWizardDialog text input [message #55673 is a reply to message #55430] Tue, 28 February 2006 15:24 Go to previous messageGo to next message
Do you mean org.eclipse.jface.wizard.WizardDialog?
I've recorded many actions under a jface wizard dialog, including text
modifications.
"Tom Andersson" <tom.andersson@accenture.com> wrote in message
news:4031cd1347ebc2bb6205e8dd01aece9d$1@www.eclipse.org...
> Hi!
> seems to work fine.
> needs that well.
> Thanks!
> Tom
Re: JWizardDialog text input [message #55808 is a reply to message #55673] Wed, 01 March 2006 03:28 Go to previous messageGo to next message
Hi Ali.
Yep, WizardDialog it is. It's pretty weird if it should work. None of them
seem to record actions performed on the UI components. Actually clicking
on Finish/Cancel buttons works but actions on text and list components do
not get recorded. Here's an example of what gets recorded:
<shell id="org.eclipse.jface.wizard.WizardDialog" return-code="0">
<command type="select" contextId="wizard"
widgetId="org.eclipse.swt.widgets.Button#{{16}}-{{1.0}}"/>
</shell>
By the way, don't want to open another topic but have a quick question:
Can i use tptp.persistent.id to identify my widgets? Assigning a key/value
pair with that key results in the widget identifiers being something like
Button#{{null},{null}} (don't have an actual sample at the moment) in the
macro.
Thanks for the help.
> modifications.
>> Hi!
>> seems to work fine.
Re: JWizardDialog text input [message #56136 is a reply to message #55808] Thu, 02 March 2006 11:35 Go to previous messageGo to next message
Hi Tom,
I'm not sure why you're having problems recording UI actions under a wizard.
The sample that I've included under the user guide makes use of a wizard to
create a Java project and I haven't had anyone reporting any such issue. It
might be helpful if you can tell me if your wizard is created any
differently than how most other wizards are created. (e.g. if you are
making an uncommon use of the wizard by adding widgets differently). If you
like us to pursue this problem, I'll need a plug-in that isolates your
wizard. I have to be able to some how reproduce this problem.
As for your second question: "Can i use tptp.persistent.id to identify my
widgets?":
You have to stick ids into your widgets before you can use them. For
example, you can only use tptp.persistent.id for a button if it's created
as:
Button myButton = new Button (...);
myButton.setData("tptp.persistent.id", "myButtonId");
i.e. if you would like your macro to be very robust, then you'll have to
adapt a good UI development policy that always defines persistent Ids for
all widgets that are created.
news:8337079d30d7350cfd9b318aa3d0cb34$1@www.eclipse.org...
> Hi Ali.
> </shell>
> macro.
> > modifications.
> >> Hi!
text
> >> seems to work fine.
Re: JWizardDialog text input [message #56256 is a reply to message #56136] Fri, 03 March 2006 02:54 Go to previous message
Hi.
We'll take a look at the way we create the wizards. Also, i've assigned
the id's to components the way you described, i.e.
deleteButton.setData("tptp.persistent.id", "deleteButton"); and that's
when i get null id's to the macro. If i don't assign the id's then the
macro just has some numeral identifiers like Button#1.
Maybe it's functioning the way it is as I'm using some January milestone
build..
Anyway, thanks for the tips, we'll doublecheck that we do things right.
Tom
Previous Topic:Specify workspace for AGR Testsuite to be launched in
Next Topic:Automated test
Current Time: Sat Nov 15 13:02:15 EST 2025
Powered by FUDForum. Page generated in 0.09933 seconds
