Home » Archived » M2M (model-to-model transformation) » [ATL] What happened to MM!pkg::element notation
[ATL] What happened to MM!pkg::element notation [message #55422] |
Tue, 31 July 2007 14:32  |
Originally posted by: lw_mailme_00.yahoo.com
I tried to recompile a couple of older transformations today, and I got
error messages for UML!uml::Class, for example. The compiler seems to
have lost the ability to process the package name. UML!Class seems to
work fine.
I am using the atl2006 compiler from CVS, updated today.
Lutz
Re: [ATL] What happened to MM!pkg::element notation [message #55563 is a reply to message #55482] |
Wed, 01 August 2007 07:44   |
To complete what Hugo said: the "technical reason" is that we did not
find how to write the corresponding lexer rule with ANTLRv3 yet :-/.
See: https://bugs.eclipse.org/bugs/show_bug.cgi?id=196433
for more details.
Do not hesitate to contribute a solution if you find one ;-).
Frédéric Jouault
Hugo Bruneliere wrote:
>> got error messages for UML!uml::Class, for example. The compiler seems
>> to have lost the ability to process the package name. UML!Class seems
>> to work fine.
>> Thanks,
>> Lutz
> Hi Lutz,
> ATL2006 now uses ANTLRv3 and for technical reasons, you must put your
> elements name between double quotes if they include package name(s):
> e.g. UML!"uml::Class"
> Best regards,
> Hugo
Re: [ATL] What happened to MM!pkg::element notation [message #55644 is a reply to message #55563] |
Wed, 01 August 2007 16:42   |
Originally posted by: lwrage.sei.cmu.edu
I'd like to help, but it seems that the ANTLR source code for the lexer
is not in cvs...
- Lutz
Frédéric Jouault wrote, on 8/1/2007 7:44 AM:
> for more details.
> Frédéric Jouault
>>> seems to have lost the ability to process the package name. UML!Class
>>> seems to work fine.
>>> Thanks,
>>> Lutz
>> Hi Lutz,
>> Best regards,
>> Hugo
Re: [ATL] What happened to MM!pkg::element notation [message #55724 is a reply to message #55697] |
Thu, 02 August 2007 05:43  |
Quentin is right about the location of the source.
However, I advise against trying to solve this minor lexer issue on the
all ATL grammar. It takes a relatively long time compare indeed, whereas
you only need to play with one rule of the lexer.
Trying on a simpler grammar is probably better ;-).
Frédéric Jouault
Quentin Glineur wrote:
> have you checked org.eclipse.m2m.alt/dsls/atl ?
> (if I have well understood, it should be what you are looking for)
> Quentin GLINEUR
>> lexer is not in cvs...
>> - Lutz
>>> Hi,
>>> for more details.
>>> Regards,
>>> Frédéric Jouault
>>>>> UML!Class seems to work fine.
>>>>> Thanks,
>>>>> Lutz
>>>> Hi Lutz,
>>>> your elements name between double quotes if they include package
>>>> name(s):
>>>> Best regards,
>>>> Hugo
Current Time: Tue Jul 22 08:29:00 EDT 2025
Powered by FUDForum. Page generated in 0.25035 seconds
