Logic Example I20030116 not working in 2.0.2 or 2.1 M4 [message #55413] |
Thu, 16 January 2003 16:33  |
Originally posted by: gwaffen.redoaksw.com
I can't seem to get the Logic Example I20030116 working in either Eclipse
2.0.2 or 2.1 M4. I can create a Simple project as instructed and then bring
up the New wizard and select Examples->GEF, select Logic Diagram and press
"Next". The "Create Logic File" dialog opens. I can select my Simple project
and choose a Logic Model Sample. But when I press the "Finish" button,
nothing happens. I can press the "Finish" button as many times as I want. I
can then close the dialog using the "Cancel" button. However, in Eclipse's
Resource view, I can see that a logic model file has been added to the
project. Selecting this file and double-clicking (or selecting Open from the
context menu) does nothing. The GEF Editor does not appear. This behavior
occurs in both versions of Eclipse.
Any suggestions would be helpful.
- Greg
Re: Logic Example I20030116 not working in 2.0.2 or 2.1 M4 [message #55741 is a reply to message #55715] |
Fri, 17 January 2003 15:35  |
There were compile errors in the logic example during the last build (20030116). That's why there's
a big red X next to the examples download link. ;)
Eric
ian wrote:
> I had this exact same problem. I found that by installing GEF from a few
> weeks ago, things seemed to fix themselves. Can someone verify that Jan 16th
> build of the logic example does not work?
> cheers,
> ian
> "Gregory Waffen" <gwaffen@redoaksw.com> wrote in message
> news:b077tr$r3v$1@rogue.oti.com...
> bring
> project
> I
> the
>>Thanks,
>>- Greg
FUDForum. Page generated in 0.04537 seconds
