| Automated test [message #55376] |
Tue, 28 February 2006 04:50  |
Originally posted by: ayesha.ltp.soft.net
Hi all,
I am having a problem setting up automated test.The problem is that the
eclipse classloader is unable to load junit/framework/TestListener class. I
am able to run the test from within the workbench successfully. All plugins
selected while running from workbench is also copied into the
test-application. Additionally, I have plugins, org.eclipse.test,
org.eclipse.ant_1.6.5 and org.junit_3.8.1.
I get the following stack trace:
[java] [java] Exception in thread "WorkbenchTestable"
org.eclipse.swt.SWTException: Failed to execute runnable
(java.lang.NoClassDefFoundError: junit/framework/TestListener)
[java] [java] !ENTRY org.eclipse.ui 4 4 2006-02-28 15:18:10.989
[java] [java] at org.eclipse.swt.SWT.error(SWT.java:3283)
[java] [java] !MESSAGE Unhandled event loop exception
[java] [java] at org.eclipse.swt.SWT.error(SWT.java:3206)
[java] [java] at
org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.j ava:178)
[java] [java] !ENTRY org.eclipse.ui 4 0 2006-02-28 15:18:10.989
[java] [java] !MESSAGE Failed to execute runnable
[java] [java] at
org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchroniz er.java:28)
[java] [java] at
org.eclipse.swt.widgets.Display.syncExec(Display.java:3700)
[java] [java] at
org.eclipse.ui.internal.testing.WorkbenchTestable.runTest(Wo rkbenchTestable.
java:109)
[java] [java] at
org.eclipse.test.UITestApplication.runTests(UITestApplicatio n.java:185)
[java] [java] at
org.eclipse.ui.internal.testing.WorkbenchTestable$1.run(Work benchTestable.ja
va:68)
Ayesha
| Re: Automated test [message #56270 is a reply to message #56110] |
Fri, 03 March 2006 03:32  |
Thanks for the help. I copied the fragment
org.eclipse.ant.optional.junit_2.1.0 and it started working.
Ayesha
"Ali Mehregani" <amehrega@ca.ibm.com> wrote in message
news:du7633$vkl$1@utils.eclipse.org...
> Hi Ayesha,
> So here's what I gather from your post:
> - You have an automated GUI test suite that you are attempting to launch
via
> an ANT script
> - I'm assuming that the automated GUI test suite launches fine when you
> launch it normally in your workbench
> Now does the ANT script launch when you launch it using the ANT launch
> configuration under "External Tools" in your workbench?
> Your problem doesn't sound like there is any issue with the automated gui
> recorder or the automatable service framework. It's seems like a
classical
> classpath problem.
> "Ayesha" <ayesha@ltp.soft.net> wrote in message
> news:du3aeg$eiq$1@utils.eclipse.org...
> > This an automated UI Test that I am running using build scripts written
in
> > test.xml. I have added the dependencies in my manifest.mf. Running the
> > test from within workbench as a Junit-Plugin test works fine. The test
> fails
> > with the ClassDefNotFoundError for junit/framework/TestListener when run
> > using test.xml.
> > Ayesha
> > news:du2as2$gqk$1@utils.eclipse.org...
> > > Is this an Automated GUI test that you are running or a JUnit plug-in
> > test?
> > > If it's a GUI test, then make sure that you have correctly defined the
> > > dependecies of your plug-in under
> > > the manifest file.
> > > news:du15pf$l3q$1@utils.eclipse.org...
> > > > Hi all,
> that
> > > the
> > class.
> > > I
> > > plugins
> > 15:18:10.989
> > > > [java] [java] at
> > > > [java] [java] at
> > > > [java] [java] at
> > 15:18:10.989
> > > > [java] [java] at
> > > > [java] [java] at
> > > > [java] [java] at
> > > > java:109)
> > > > [java] [java] at
> > > > [java] [java] at
> > > > va:68)
> > > > Ayesha
FUDForum. Page generated in 0.04400 seconds
