Home » Modeling » OCL » GMF/OCL Bug?
GMF/OCL Bug? [message #55340] |
Fri, 09 May 2008 11:49  |
Originally posted by: vineet.architexa.com
I am trying to setup an OCL constraint in the GMF Map and am getting an
error when trying to validate or generate code using it. This constraint
does work in the OCL interpreter:
> self.connectorType = metadata::ConnectorType::Input
The Background:
in package metadata
enum ConnectorType {Input, Output}
in package graph
class Connector
property connectorType: ConnectorType
class Processor
property connectors: Connector
The constraint is on a connector, and my feeling is that the error has
to deal with accessing the other package, but the expression does return
a true when clicking on a connector and running it in the ocl interpreter.
Any help will be appreciated.
Thanks!
Vineet
Re: GMF/OCL Bug? [message #55394 is a reply to message #55367] |
Fri, 09 May 2008 13:15   |
Sorry I meant to include this earlier. The error message is:
> Invalid expression body 'self.connectorType = metadata::ConnectorType::Input'. Cause: Invalid expression body 'self.connectorType = metadata::ConnectorType::Input'. Cause: ERROR in (enumerationOrClassLiteralExpCS): (Unknown type ([metadata, ConnectorType, Input]))
Thanks for looking into this!
Vineet
Christian W. Damus wrote:
> Hi, Vineet,
> What is the error message that you see? That should help to diagnose
> the problem.
> Cheers,
> Christian
> Vineet Sinha wrote:
>> an error when trying to validate or generate code using it. This
>> constraint does work in the OCL interpreter:
>> The Background:
>> in package metadata
>> in package graph
>> class Connector
>> class Processor
>> return a true when clicking on a connector and running it in the ocl
>> interpreter.
>> Thanks!
>> Regards,
>> Vineet
Re: GMF/OCL Bug? [message #55473 is a reply to message #55394] |
Fri, 09 May 2008 17:32   |
Originally posted by: give.a.damus.gmail.com
Hi, Vineet,
Right, this is what you had indicated: the qualified reference to your
enumeration literal cannot be resolved.
Either your metadata EPackage is not registered in the package registry
used by the OCL Environment employed by GMF for audit constraints, or it
is registered in the static package registry but resides there still as
a PackageDescriptor. Until the package is looked up in the registry by
its namespace URI (and thus the descriptor replaced by your package
instance), OCL will not be able to find the EPackage named 'metadata'
You might try debugging the
EcoreEnvironment::findPackage(List<String>, EPackage.Registry)
method to see why this qualified name isn't being resolved as you expect.
HTH,
Christian
> Vineet
>> Hi, Vineet,
>> the problem.
>> Cheers,
>> Christian
>> Vineet Sinha wrote:
>>> Hi,
>>> The Background:
>>> in package metadata
>>> in package graph
>>> class Connector
>>> class Processor
>>> has to deal with accessing the other package, but the expression does
>>> interpreter.
>>> Thanks!
>>> Regards,
>>> Vineet
Re: GMF/OCL Bug? [message #55554 is a reply to message #55473] |
Mon, 12 May 2008 18:57   |
How would I get GMF to do the appropriate registering? As a side note, I
was able to get the constraints working using the Java option in GMF.
Perhaps GMF's integration of OCL has a bug in it?
How?
Are you suggesting somehow setting up the OCL interpreter in the
development workspace (as opposed to the runtime workspace)?
Thanks!
Vineet
>> Vineet
>>> Hi, Vineet,
>>> the problem.
>>> Cheers,
>>> Christian
>>> Vineet Sinha wrote:
>>>> Hi,
>>>> The Background:
>>>> in package metadata
>>>> in package graph
>>>> class Connector
>>>> class Processor
>>>> does return a true when clicking on a connector and running it in
>>>> Thanks!
>>>> Regards,
>>>> Vineet
Re: GMF/OCL Bug? [message #55582 is a reply to message #55554] |
Tue, 13 May 2008 12:16   |
>> your enumeration literal cannot be resolved.
>> registry used by the OCL Environment employed by GMF for audit
>> constraints, or it is registered in the static package registry but
>> resides there still as a PackageDescriptor. Until the package is
>> looked up in the registry by its namespace URI (and thus the
>> descriptor replaced by your package instance), OCL will not be able to
It isn't up to GMF to register EPackages; your EMF model plug-in does
that. Note that Java code doesn't have to worry about whether the
EPackage descriptor is resolved in the registry, because it doesn't rely
on the registry to look up meta-data.
> How?
Using a breakpoint in JDT's debugger. Step through the findPackage
algorithm to see what the package registry contains.
No. The OCL interpreter has nothing to do with it.
> Thanks!
> Vineet
>>> Vineet
>>>> Hi, Vineet,
>>>> diagnose the problem.
>>>> Cheers,
>>>> Christian
>>>> Vineet Sinha wrote:
>>>>> Hi,
>>>>> getting an error when trying to validate or generate code using it.
>>>>> This constraint does work in the OCL interpreter:
>>>>> The Background:
>>>>> in package metadata
>>>>> in package graph
>>>>> class Connector
>>>>> class Processor
>>>>> Thanks!
>>>>> Regards,
>>>>> Vineet
Re: GMF/OCL Bug? [message #58113 is a reply to message #55582] |
Tue, 10 June 2008 11:24  |
I have the same problem.
I have an OCL constraint and I want to access to an enum.
This is my constraint :
self->mode = PetalsDomainMode::STANDALONE implies self->subdomains->size() = 1
and this is the error :
ERROR in (enumerationOrClassLiteralExpCS): (Unknown enumeration literal
(STANDALONE))
The 'mode' attribute is a PetalsDomainMode. This class is an enum type
implementing Enumerator.
What must I do to resolve this problem ?
Where do I add the good package in OCL Environment (if this is the
solution of course :D !) ?
Thanks !
Guillaume
Current Time: Mon Sep 01 02:41:48 EDT 2025
Powered by FUDForum. Page generated in 0.06305 seconds
