Home » Modeling » Epsilon » org.eclipse.epsilon.ewl.emf.WizardsExtensionPreferenceDialog
| org.eclipse.epsilon.ewl.emf.WizardsExtensionPreferenceDialog [message #4916] |
Tue, 25 November 2008 02:22  |
Epsilon (from SVN) seems to be OK on 3.4 and 3.5M3 except for the
WizardsExtensionPreferenceDialog which shows just the text, label and
OK/Cancel buttons.
There is no field editor for selecting the namespace.
There is no selector for choosing the *.ewl file.
Is this normal?
-- Nicolas.
| Re: org.eclipse.epsilon.ewl.emf.WizardsExtensionPreferenceDialog [message #5676 is a reply to message #5325] |
Wed, 26 November 2008 10:05   |
Hi Nicolas,
I just set up a fresh copy of 3.5M3, installed EMF/GMF/UML2 etc, checked
out the code of Epsilon from the SVN and the
WizardsExtensionPreferenceDialog seems to be working under this setup.
I'm pretty much clueless as to what the problem could be or what to try
next...
Dimitrios
Nicolas Rouquette wrote:
> Hi Dimitrios,
> I am running 3.5M3 on Windows XP Pro SP3.
> Basically, I get the same dialog as you except that there is no
> "Namespace URI:" field and no "Wizards" field and no "Browse
> workspace..." button either.
> Just the title, message, OK and Cancel.
> I filed a bug: 256473
> -- Nicolas.
> Dimitrios Kolovos wrote:
>> Hi Nicolas,
>> Strange... I've just checked and it seems to be working fine with my
>> 3.4.1/WinXP setup (see attached screenshot). What OS are you running?
>> Cheers,
>> Dimitrios
>>> Hi,
>>> OK/Cancel buttons.
>>> Is this normal?
>>> -- Nicolas.
| Re: org.eclipse.epsilon.ewl.emf.WizardsExtensionPreferenceDialog [message #5694 is a reply to message #5676] |
Wed, 26 November 2008 18:25   |
Hi Dimitrios,
I seems that the problem is that the TitleDialog isn't resized.
The WizardsExtensionPreferenceDialog.createDialogArea(Composite) method
does construct the two widgets but it seems that the geometry of the
dialog itself isn't re-computed so it shows up as a default-size dialog
instead of a dialog sized to accomodate all of the widgets.
I don't know how to force the dialog geometry/layout to be computed but
I'm willing to try that if you can offer a suggestion.
-- Nicolas.
> Hi Nicolas,
> next...
> Cheers,
> Dimitrios
>> Hi Dimitrios,
>> -- Nicolas.
>>> Hi Nicolas,
>>> Cheers,
>>> Dimitrios
>>>> Hi,
>>>> and OK/Cancel buttons.
>>>> Is this normal?
>>>> -- Nicolas.
| Re: org.eclipse.epsilon.ewl.emf.WizardsExtensionPreferenceDialog [message #5712 is a reply to message #5694] |
Thu, 27 November 2008 05:19   |
Hi Nicolas,
I've changed the code a bit and removed a suspicious statement
(preferredSize.height = 210;). Could you please update from the SVN and
let me know if it works now?
Dimitrios
> Hi Dimitrios,
> -- Nicolas.
>> Hi Nicolas,
>> checked out the code of Epsilon from the SVN and the
>> try next...
>> Cheers,
>> Dimitrios
>>> Hi Dimitrios,
>>> -- Nicolas.
>>>> Hi Nicolas,
>>>> Cheers,
>>>> Dimitrios
>>>>> Hi,
>>>>> Is this normal?
>>>>> -- Nicolas.
| Re: org.eclipse.epsilon.ewl.emf.WizardsExtensionPreferenceDialog [message #5729 is a reply to message #5712] |
Fri, 28 November 2008 02:23   |
Hi Dimitrios,
It works for me! Thanks!
-- Nicolas.
> Hi Nicolas,
> Cheers,
> Dimitrios
>> Hi Dimitrios,
>> method does construct the two widgets but it seems that the geometry
>> of the dialog itself isn't re-computed so it shows up as a
>> default-size dialog instead of a dialog sized to accomodate all of the
>> widgets.
>> but I'm willing to try that if you can offer a suggestion.
>> -- Nicolas.
>>> Hi Nicolas,
>>> setup. I'm pretty much clueless as to what the problem could be or
>>> what to try next...
>>> Cheers,
>>> Dimitrios
>>>> Hi Dimitrios,
>>>> -- Nicolas.
>>>>> Hi Nicolas,
>>>>> my 3.4.1/WinXP setup (see attached screenshot). What OS are you
>>>>> running?
>>>>> Cheers,
>>>>> Dimitrios
>>>>>> Hi,
>>>>>> Is this normal?
>>>>>> -- Nicolas.
| Re: org.eclipse.epsilon.ewl.emf.WizardsExtensionPreferenceDialog [message #5746 is a reply to message #5729] |
Fri, 28 November 2008 05:01  |
Hi Nicolas,
Glad it helped and thanks for your persistence and patience with this!
Dimitrios
> Hi Dimitrios,
> -- Nicolas.
>> Hi Nicolas,
>> and let me know if it works now?
>> Cheers,
>> Dimitrios
>>> Hi Dimitrios,
>>> the widgets.
>>> -- Nicolas.
>>>> Hi Nicolas,
>>>> what to try next...
>>>> Cheers,
>>>> Dimitrios
>>>>> Hi Dimitrios,
>>>>> -- Nicolas.
>>>>>> Hi Nicolas,
>>>>>> running?
>>>>>> Cheers,
>>>>>> Dimitrios
>>>>>>> Hi,
>>>>>>> Is this normal?
>>>>>>> -- Nicolas.
| Re: org.eclipse.epsilon.ewl.emf.WizardsExtensionPreferenceDialog [message #562355 is a reply to message #4916] |
Tue, 25 November 2008 04:31  |
--------------020608020008090300010401
Hi Nicolas,
Dimitrios
> OK/Cancel buttons.
> Is this normal?
> -- Nicolas.
Content-Type: image/png;
name="AddWizardDialog.png"
Content-Disposition: inline;
filename="AddWizardDialog.png"
iVBORw0KGgoAAAANSUhEUgAAAcgAAADiCAIAAABFg8BZAAAACXBIWXMAAA7D AAAOwwHHb6hk
AAAgAElEQVR42u2dCXxTVd73T9IFylIoIAhdoTQtTWdcXxCXZ6xWQVLLmnYc GRRFneL2dBxh
1NdPk9cRUF6t29AZQRhHnJk2QJFpQKXIPO/4sSOjgk6TtqlsBUTckEK3LPe+ 59x7k9ykSZqm
aWnT31ds7z337On95X/+595zFDzPk0HOuXPnDAbDihUrOjs7Ozo6aIjD4aA/ bTab1WqlBzSc
HnAcp1Ao1Gr1pk2baGQxrdFo1Gg0J06c6Gmh1dXVxcXFBAQN7eTk5GT0AxjU f1fl5eX5+fkB
IsTHxz/wwANKfDAAABBeIKwAAABhBQAACCsAAEBYAQAAQFgBAADCCgAAkUo0 uqA3hPAALLoL
gEH6dxX8A7MQ1n7qaIAXBMDQ+bvqmbCqVKoB27/PP/98aJFLSkpCK7GsrAx/ 1gAMKYKUi2CF
lUpqamrq4sWLR44cqVTCMwsAGFpwHNfa2rpjxw5qUe3bty9ATKqQQQnrZZdd tmjRovj4+PPn
z589e1Z8Ex8AAIYOUVFRsbGxubm5LS0t+fn51dXV/mImJCR0L6zUVqWqSg9O nz6NzgUADE2o
QWm1Wi9cuEBH7bfddtvNN9/sz26dP39+98KamppKbdVTp06hZwEAgA7cExMT qTD6vGqz2WbN
mhXdrbm6ePFiOvxHbwIAIoPvvvvu+++/72mq8ePHT5gwQTymknj11Vf7NFrb Bbq3WKnde/r0
aSrD+DwAAIOdc+fOKRSKO1XJP0+fwBMFr1ByQjinVMijKTm2ULWS0BicgvB/ O/zdez+0U0Ue
M2YMDW9ra5s8eXKAUroXVqVSabfb/V2lVYyApbIBAEMEaqsuVSUtGsudbWmx K6LsVFiVSk7B
nnSyK6TnnaJ5JrZKnlNyHD2O5h2Lx1J5Hb7VclIUViqJgR+OkgmrSZ+TozM5 z7SVfKVWOsZj
AACAiGFR2viWlnNU16hYcgrewXM8T7U1io9yUDORGot2B1VVB6/gCEevcRzv aFHGLEobQ4WV
47hgivC0WNW6urpStaSyikLC+xRWKtXqlKxrpl81alh8mz3qoOWH760Oa6et rePbc+3H7fbT
RNGJDw8AMDCh6slTTeMcUdTq5BVRyiiHQkFH3w6bgg7C6fUoBU8jRVGRpXHo mJyKqTJKHJoH
aWX6cwWoSyt0OUV68cRLpG+97MZrr742Km748TOt5qMt33TyVquj02pvt41y OKZ3WocrFM3R
0Rfw+QEABiBU0Bx2WwyhBikZt3jFyGtuOvX4L7pGS1z/l9Z/ffDj9k302MZx ogyGZLF6SGt2
tslwKMPDYqVGcvqE1KsyLhs+ZkTn8OG2H23DR8Z0WtmefR2d7F97e2d7+2i7 Y/yoUW3R0Zjv
AgAMOJScg9jtRMEkkqqqqKGnfl3ooaovVopXf6z8g2DlKlmqXluslGy12nyI bXJKXI8EUGG9
Ln2m0qb49oeOC9GOjg5bexvbAZX+395B/3VQYW3roNoaZ7UNSxjb1iXPJO0L LyxJYkf/Kisq
+5czKMkgnlxTUqE9+dhjhpPsqOQad7qT24RQIsYpSXKdulO4L5WRkheWnHTm 3wtYfiQM+QAA
BpLFyjs4h40IEnnqwQWJv98pKik9llRVCBGvSkmiomgquRiGLKxmkymbZByS W79KpXJiwoS2
71pPtPG2YTFnz7Z99dWPHZ22DqaqTFLbRG1tp0obOybey2ZOLnzxhSUn1t7w sxdPt2U+8o9V
U3e9dXgCSUxMItfkX9f5zj+nPbjkGpL0/o+mY+dnzOIJ+fKVG2e/0uhMPSJt xpVpwwn56KPa
kl//JPXcc5bRacNnX0NTHJnyw8sNYy8dwU6Ol7/0zs5OS8NzRz87NjzrxqkT eueKIaS1/oPD
3/QyHwDAQMLmUNjshFgl9Sy+LbF8j6inrmMx3JVCwcXSVOFwBZjMZrWaWJmw njlzxhUcGzPs
5PQpseyJBBI7OeGSrCl2qv4cz346mEeYHtg57sK581Wb/tsjw9yV2uR9q65/ 8XRs4pQM5bb7
nj1//Ltox3XzJh/b+Gr9I/dmnRyh/fKpEtOyrOQfPj1zroOwqbNho1OnjY6V Mjh35sw5+mvn
u/t/rb/tltFbDGcKVs4+dqRpWv6tY7ZsO7N45WxyuLyC/Pf7/34onewv/a8t aev/vDzNVf6x
LcuWbSHL/yyFCafHSBoNyD26n+TmprE0pfuFEHey9wnpPJe9cr8+V5YIADBY RZWanF83dxz8
Qql0Pyd6/Jopqf/6immrU1VpiDxVB6cgV/y0tbXVarX2RlhN+iJddil/6Km3 va04QkZ9VP/+
153nO2wdneLAnzkB2pgTgP1kDoEOq83Wlp7iqas35pIjr/zHGp+QGi8EUNFM JGRqWtrhPf/3
pT9+8MHz6Xuf+FVL7rPzsq1balmEjEf+cfIRH2q2/x/79frH/vtnW/51Y+6x vfPWJe9efevk
f45czvLf1Xjs6/+96ba/rug4XX/w78uufeHIN993ktvf+PJ18sKTe74ZP23L slmvHD9yfg4N
eapw5zLmRyFpyZ/d9JP7VTfmbv/q9N0b/99ysqkg6+laOyl49fQb9HL6A8tz j/1hweyn66Rq
u7UeADDohFVJHFGEPUUlDz86c/LUA6ddx16potjLAg6aNiYmpufCatLlKHTi ofgcq+op4mX9
trd3XLh2xrXMT0EcwiNe/izW7a8/4uHXoP87OklsbBSXevdbb90zlSrk09dv Tk0jDof12L7/
OZL3d73hwsipR6elT+34Hxa76ZUbr5VcAbETJiSPd9V13+bNd+XeM2dtdO7R d186+J5q3xu/
euR+kkb2rnymicaMZk/usocmOE45Nu3Shc98+Eza5sU37yGjx46N+Zn+w2dy xWyauHOnWuLo
eP/Ld//+H1vs+YPmKWMXzMsl7z/2dC0Zl3ZpwpThwmjhy/c/OPrAr3aeztv0 y7v/dDT40QAA
YEAKK88eqOI8H/BPr3UvMkUV9vBsD22N4niaiqbtuStAXVrHl/qMJJ8Ia/72 VLJd8emRHw6c
+rGtw0p1to3+62B+VXpMbVjmcu20jh978pJxHtNnh48cJbmZ03nuX44vN/5C a33T8KsLX309
9oapRyyNhP9q450//7E5euy1USQ9bUanzSZ+mcSOTEwZEdOlEl/W7D9yz723 z/vylVtNMSO/
+uCD9c/mE7L71Soy7JKxCof0RcRTqU9Z8Zdncj/4zdQ1H1lpVqrlb9Gz1dOL tiet2vOPAuZF
lb61YofFRTsc0aqsNELqrWTUiHh6Kl3jmzb+4urnZpU2vvTWh7mv/2LplqP4 6wRgkEKFJIp3
KKldKHuFdfpHkqp+ee1k8Xjq3sYjt2a6hZWn/xwiwZQS1JLVnIzqA3s6FPbU S0aOH6YUVLVT
UtWOjvZOK/3X2WkbHvvD6JHnOE8Ov76xhg6uf59nZ2fR0dGs8IyMdEKN3ZgY JbUu45PGxDcf
PkLSVVOdwsqsTl8crvngMCGNu3ccjBoxQllTwxZC+Pv2ajIyNo7a0NI7tvy0 e9/+y71HVquK
374QOyFpeJRw5ctDX7SOHH3tlRkkU6Ui7J0LWUGHa/YdIfMe+c104dR5iZ5E ja393R1/bCLp
k+N+ONvBAQAGJ1QZo2Njho+IGTksWvznUtXTucn0lP5kyjgqnoa74tD4NBVN 68onNB+rX+qO
m/cd3P+zK3KvUycqoxWfNJ6kFmt7BxVW9hxrZ6d9+LDvx4/5Njam6/IC+56a 9Zjj498fvF0y
Ycvv3zX912+QpvomQsbKbfLMTMfxbup9ZN/+IysubWqMHTY5lua8bx+x/30X GTFJ7vycs3LF
NEKmPWdpfE5IsumOOzZuqlmxZs/pX5N9mzYdJj/LnGr/p1e+G+9Ynfjxc3sP PiYFvEe/zVb+
dVfxNOFs729u3uWImUQtXHzzAzBILVbFsDjFqBGie/LSaosY/nW+SjEyznUs hk/ef4IeizYo
TRX8y/3dLKGiUqnuvvvuqqoqr/DsVHXezLkJYya3Wrk/v/Pvo6e/a+toVyjO KxRfU1vVl6q6
aG09+a1zXi0mblKisuVYK7kkYfxIVwzr90LIiLaz31tphOH+nMW2H1vO2IYn XRLrTGUbkSb1
DLv0Y9T4tJi2Y63tMkdJfGJ8vFWqQNzYOPuP1rjE+LjWljOtsfKC2r89+32r K1Xs+LThtlMt
LeLzayNHOksEAAw6zp07Zy6c+cOxI0R4KmD08tVxuQu+WTa7a8yJf65t37/z /BbBLuMU49Km
ZVceEBdhoSxcuPBPf/qTv7Wug7JYu9q9dUf/Q/+5TuOGs3+y+AEyi4ubkhIn i0sSUsZ4FhEt
hpC4MVNIoJmiqPhRU9zXaapo1wm7FM/yGJYyJsGrLfIKxMeySFJkd0HDxo+Z Ml6eiAybPGaU
/+4AAAwSmCk5arRy3ET25pWSb921qXXXRuX4cXZeaafndBjO2amS0F/flWio 6akcP4GwhQOV
NBXP3IK9fI41oLACAMAgFVZ+VELUOKaivKhsbNyuiFIqFZyCJwomokpewXEK thQLm+FSKJVs
FaxRCRBWAADwTYX5VOG0ce0xsTzTS4XguKR6SqKI0kGUUcz3yhSPyirVR57G IMo4m5WmImF4
88rLeAYAgMHPiBEjXjpg4hU5RXnXKwnPiWuxMAFlKwdyPDNcqeQpeGkHATFO Rc2HLx8w0bRB
iiEsVgDAECIqKqqzs1P37j/pP3m4gtmsRFzo2qc1SVVVqVT2fnUrCCsAINIQ 1WzYsGE9TRj8
2wFMWE0mfVERqRA3DjDpc4Rjc6Gi0MAuZ2Rk4JMAAIAe4dti1VZKdnBSUpIY 0tLSgs4CAABK
fDxbSaqtra2HrgDnxoKJiYliwMmTJ9GbAIChCbU07Q6+08ZZbbzNweded1ng +D7XCjAU5hi0
dTweBgAADGU4jqdKer7Ncfa8/Yfz9tYOzuYIShWVwt5WJrN4ZjY5t7/Ozlaj VwEAQ9Q+pXra
1sldaOeoqtKDIPVU7grQlur0OcITBkStVhO1PMTlCgAAgIiHjvfpPwd7kpXZ qnZHiKP2aGaY
dl2I1RnimrwCAIAINlEdHG+zM/cnL8ir1cb1xhMajT4FAAxlqJ5SJRVnlDjB UHVwvZ1egrAC
AIYoDmqZOtyT9MxQtfPCxn69BcIKABhycByx2j22E7Q5eJs9bK+YQlgBAEMI ap/Ssb/HYJ8n
nfYwv7cPYQUADBXESX/5A/ri7D8X7kf2B4KwGpwrEzgRt94eODULc33EXNW6 OnGBBgBA34/9
BUOVE2f9ZaraaeNJH7wI1Sthdb74KhKaUtA83NrVRWIBACBMhmoXqe0jVe2N sDpFVZJT4VRv
KO2xZSe+7KVWZ0um6oB6i3ag1QcA0CPo/WuzuTa591BVq60PV0MNVVgNesFU VesqRCNVXVpX
R/TmLnas04yVArVarcFgcF0gorlKL+tyFDqqY5Wk0GW/epuvQgqzfHAuH6m7 j7UGeuTDAu46
oJePyZ0VlKWjF0pNoj2t05l1btvclR3xrKLLZvdVGX/WuGc4HAQAhG34z7EF U7oaR+yNVXvf
rjEdrVAoQriZneqoXeJOpy51Wq5yfdLl5BAmoVI6ouX5UiGOrki/pK60rtIk d2MaCj3lpsce
AjOVapM8CzEHoVr03FNbs9VqYjAJKyWopWUSzGaT8NPZOCmvbNfLaVID1bpS Vl0vLdXlFGbL
SnBXxp/Dw9PdKiyHCwAI2/Dfhw0rqmofD0WVfJ2OGLaZwpSdZMhSw5S4fplk 2Qsh6uzsIIVb
yqdHo/cKtioXX5mt1xvcOaiXaNXubF1fBWIoE1N2hcUVKiuIrMeXhtu8FIxx baWops7f7oJE
YfauDPHoFpk/xSza+Dq9wWn2w1wFoNfDf6vdj6oKj6/2g3+vP54KYCbhEt/B JKCMSJ7XnuBa
lUuyQKlJqAhQAFVWHTNZqZhSJdWqzQaDyWwwGZw5mb1kVbA0tZVuozSgMe21 RFjX5lAjX6tj
6V3VHDAPRAAwOFWVGaR+3p7qew9Ab4WV2V7UxvPQRpNeb14iDK596aO5n/tX HOZ3J1SC8Wwy
6IuotGaXapnO6vR6tU/rUhzN02G7M0OXV0CwM0N7osE5PeZ0TIuWM24PAELA wfldj4oX1gTo
t5ooQ0ynLdWJnsUcvUk2SPYccou/fI6pgxBulxNBGjC79NI54paH+zRGBd+E 3iQbx+tNvgsy
CfNqks4yW9dbV036IvEZiAr3WF0yikW7NGBl/DWHyalYJWa7hmikAwCIf6eq CFu5qh8rE7Ir
QF1ax2eLEzYKndP4YtpQV0eEiSJxaOual+mxJVeno9kImavV8hmyCp2BTX3R C/Jw3xVcwuxA
Z/2E2pT6sb0lRfM8kzkBRCep9PSCa9BeqaUdIA7jA1dGK0bt0hyPHPFIAACh q6qDC3S1nx+c
VAQuMCkpaeXKlVu3bjWbzRetzzyH3AAAIB/j2+2ud1LdauYSNiq4LktWlDvn /54HzquutF5X
5eRed9nSpUs3bNhQW1sbVldAn+Met5u2CV7bUDwKAIBIt1XtgYxDtoK1I2zG KsfxtLhgfLUD
eBEWDJIBACSQaLKtqPhAxqytN6oqbCtADV6qp9Qi7pEzYcAKK94mBQAEUlW7 o5s3/UPYsYom
4ByinkpO29B0CMsGAgAGpaoGVjxhQ8DgM2Qy6nDw7O0B3u1dDRkIKwAg0lSV E8bvwRioVEkd
4rasIVunEFYAQMSrKi/IJenOnnUIktp74xTCCgAY9KrabTS7I5BWCu8REK6P p3CUsrd/AABg
cKuqMOPkc1Er3mrnOqy8zUH64W2BaJOwkioAAAxoVQ3CZ0qjdXWtUuPU5uA5 rl8rHG026YuK
SIVrCWkBaekSkx6fKADgoquqgwtmDxXvt1qpZWqzE699rvpLWM1uMZVKZ+st 603aJduKdIQk
4nMFAFxcVQ1m7M5x7jE+J/gNLoqkSsLqXnRavqWKWsfeJCVUWDcGmZE8dfCL ispX+R/QCIv7
V/h/+6sPG+K5ZaPUvdlCoLs8IRKRbzJDnJ/k4H1njXaqQevuUeepzw7Rdv8Z gcGII7hpJiqp
og9AfB2L4y7y60XR2a6/2hyDto6vC2mHEPan7kwtrtpcGJTEGAziflAsfd/f En144zkb0kc1
76qOJmE9LWH1RGHRQmE9BXUkqGmPO0QaYEFPI1FVg3t1ipfM1W7WuOpXYZX9 OToXvGfrjKrZ
gqYkZ2NwrgBm3LoXKg36bVST2Syuz9c/E2h9V4qrIf2KVptt2GYqZasQmtl6 smrzkLz51NnZ
JkN3m1GAiLVVibg2ivhQ6oB5Dd71HKu2VKfPcW1jwm5WtvTpxjlBuQLoILhC HWAM6zRLi4g2
W6cTt7NiO7KyqzkKU2WdWi/akp7uiLoKUuSyMUV7k4WYsqmFSIfBNJUU2dNC Y8Ny4ty2TxxL
0gO9ulJr0HtN03lvtSqNsn0UIbhHZG2SFSlthMUa4jFQdbXamZvTpDX4KFHe M8Gavku02UWC
shoMZrb/rb57g92rFIPfttMGsp1l3cs1utvlHcDOl2xzJZTtDNllOlQW5h6/ +/wQB/q3Guh7
VQ1OJamcdtouojfVn7C67DjXRqQyEy94H6uP+7hIl13J14lbpBYaWOYmnamU 7a0n3OTmijqd
2amnes8kgdwRJrO6jq9kGlwk812wLV/Vru8INdtrhZgNBsL+02bTe09bSu97 mUXNamUSVvb3
mrWrkBeRI9WHKTMRFrwWAoSHfw2logAKi3JLXwA+Wy3m5uET7FKivGe6DGzl C33JhZcOMfRU
Wc1UV12t84zvqdJdStH6azthDSR19CoNp0WQbUUGz97O9ugKtqGt1Eyp4ZVa H9OhOewbj5cU
NkfPvjkNvj/Ebv64vDsE5mokwQX3mr+4JGA/bw3QU4vVhxnKDL/EUJ8KEOa+ KlxbpBrMom1T
qg0qScChn7AwK/MqmkyyhQWlQbFscEjtOF2lTthFio6U6R27rYvsaz0ta8ks dRfhqo+0JQz9
xTzIzLjiS4NudZeVZH2UGLBn/BlzzF2jZ5sfZmsr5buK+Y3fpRS/bZcdEJ+9 XeHRFfSr0dlM
YYdGYesuX9Ohzs9X2G+CRvD7IQbpYxXc+9gnLIJgz6IGIZWcsL0VN8AM1WCE lRkcSUlJQXn7
iCHYWyKsTkZ/g2Y6Ltab9cyO02abqPKYzYL/eJsvWe3RrJ1aNOuZoihCnq3q 1TxhF2U1F+np
twatiL6Pa9KlvfKuqPP87NnYPMjMA3Rjtmx6zt+Qn20WpoCyRpCqOrqb0Bdf FhAfAuC5AdqQ
8OwgQA0nXZHrvVjhqQAzC9MbnOaO107Q/lTCmYS4TU+TZIlJW/fJIqulPQvZ feu1Q6qW+RLN
zIRiR4W6bPl9J8qq7G6Wz9r5ro+0iwEriL3/ywb/4j3vvwkBW+2nxJCUlZiy e6EqwdWka297
dYVZ2s7cs+GemXt8voIrgAT8ED0+fiETn/3JvMsGAzQpAlSVdG+rUtm1sUkq Fo1Jq2KAtiU8
i7AIftocj3326K2ercsRp8PYwE0bxHtcbLosxzWDxkamsik1tgef2rPMSmYt EVcBXsaO4IKU
dkj10FUmkqZCV826zNr5qo+4A6C4laHQTpZSHbAJflut9V9iMC5FcbJIbkOH bvIHXZMuva2m
H6+sK7K3GdRmPf1ClX0aPqZD3ZmwPxI2mA/0ITLVNueImfq87vqsBX8PJrAG ORzX/cLVLuHl
w7nIX/gZqJsJej0bDgY4eDgf9FpVxRX8eJ+WrLiev3trP97hcO0ASJz/uZPL Nw30DJfWXXXt
Pei6ysuSeSXpiubmKwJvJjiglg2UP59D7ROoKgBDQ1X9m6q88JqAl7oN2Dmr gSms2Odq0II1
0kCoMCvSz43vZ6EAfuDrBBa6BgBcPFX1P2HFCWsAdr04KKwvCCsA4OIJq5+H q/y9ecUPEmFV
4qMFAFwU/LlKA7zPyg8SbyEsVgDAxbBVeR9bqHDCa1d+VXXQ6CosVgBA/6uq rxE927M6oHAO
orltCCsA4GKYq5GrqnAFAAAuvhNAePi/2yUCBpOywmIFAPSrqvJdbFVCIkpV YbECAPpXWD3l
Msi9qQbdi0OwWAEA/egECEFVB+H7mBBWAEB/OwGYqoZk5EJYAQDAp8L2zAZV DMI2QlgBAP3n
BOB7JKs8GaTrMkFYAQD9oap8T1VVdAIoBmWTIawAgH7yAAydxkJYAQB9b672 XFUHtQ5DWAEA
faaqTlt1qK1gD2EFAPShsgqSqhhq7YawAgD6ylzlSSiPoUaADENYAQB96Qjo v3QQVgBAZIvq
0N4XFMIKAIgEO3dAEezqVkajEZ84AACEU1g1Gg06CwAAKI8//nh4hPXEiRPo TQAACAb4WAEA
AMIKAAAQVgAAgLACAAAIHWwmGDrV1dXoBACGAvn5+RDW/qO4uBidAEBkU15e DlcAAABcZCCs
YUChUKATAAAQVgAA6CtC9bFayvLyjJqamhKV83Ql2eA8G6gYi1Oq85vLNV6n rC1lFlk8TbkQ
aXA0CgAQMcIqqunKMk1k6I6qxPUdIehpmUUDPQUA9L8rQFVSklFWFnmLXqlU GRZLE/40AAAX
w2IlmpISo6dxR0fXxUbZgDqDWn+WDGI0WqgOl2uMxWUWp3XoHoB7B7BzjdGV 0DU0985c41Gg
e/zumW3PDXFLE9VW/GkAAC6KsApGa0qZsaQ8w613zfIB9QZ60KSqaS4nTO9I Db1Kw42WEmJc
adTUNNeopJiaGlVZWUZ5c43o8TRqVFJCUXCLjVQ1vTPXUPUtJjRQUti8spoN xDvb4KSVRk4p
IzLRhh8AAHCRhJWJUHl1niCgLoVyTQSpSoSfGg2TOdkBi0ZNUYvFLWYqo0Wj UlFxTGF2ZnMJ
zadMjC+mK6s2Eo3GK3OaCSnZoHGpoYaV7p1tiSoYjXRbt6wMoTD8bQAALpKw Mn+ApmxlGTVZ
VcxszJMbjN1psnuCXoAJKrM8U1I05TWecsjG5kFm3iVbNxkqVZPFQjSqAEN+ aoRrUqCsAIBe
EIbnWJk/QPSFSuIl/GYKFiANtUKN1UbXMLzYyH4yc5RqagmVvyZB+FzWrZSr Z+Y0E+KaPRNc
AaRLtt7yLJuWoplk+DJnNfkaZx4AAHBRLFbBaC1RCXti0QMqZykuHQs49i5n tqlzHE6tyIwS
Y54wimfnVKpVTWUpKcXO6/R3l8zlmTBLlQ3mvbL1tmZrLHlipj6vu74bmLJq MIEFAAgJBR9w
m9qkpKSVK1du3br1vffe69d6DYaH86urq8VFWBSKbroRADB4KS8v91rdas6c OUuXLt2wYUNt
bW1fuQIAAACE3RXQB7Bx+qDpRJirAABYrAAAMAQt1kFCCCvgAgAgrMAvPd2t AQAAVwAAAAAI
KwAAQFgBAADCCgAAAMIKAAAQVgAAgLACAACAsAIAAIQVAAAgrAAAMETBK60A RCZxcXExMTHo
h95js9na29shrAAAQlX1448/rqmpOXHiBMdx6JAeD+eVyokTJ2o0mlmzZg05 Ya2ursZfABjK
BFgMaM+ePZmZmQ899BCWDA4BhUKxe/du2odUWIeiK0DcHwWAIUjghSvPnDnz 5JNPJiQkUI1A
X/UU+m20ePHiRx99NIS0cAUAELFwHGe1WumQ1m63ozd6LI7R0bT3QvOiQFgB iGQcDge1vKhG
oCtCsFhp74Uoyug+ACJeWNEP/S2sBkK0hBgKFYUGKUhbyVdm63OKTNmEBiX6 TFaWl2IpaS7X
sGNLWV5eWUa5dGYsTikmzpNQGAwbXwMwiISVDmYlH6v5mcsvf8YsXcl++tCh p7MHWHVpDX9B
/jIw6tUrYS0sNPCVWiqm0peaiUqq3lRBD8zqOv6jOUk+k2k0KqPFQjRU/SxG I1Gpmpxnliai
KcmgWgtxBODiY7fbqUBIjkKO3uaL3m5/exE9rn/2yjv+z8LPnpoxoKrLMfOa C76/i8oAABG/
SURBVFnPwgr9NgrZNx2tNhgMRKulepqjM4lhap3wU7tETTb6SaZSZVjKjJYS lYo0UUUt0Rhd
ZxZNvkal0dTgTxqAAaBUHCcXVjGEnWRmzqivMnFc5gATVncNLzZKpTLkikQT tZoO+QtzDNo6
vk4tWqxBpKPqWVzdRBXWWG3MyKcD/7IydkYNVqq5ruF8U3FKsVFKUN5cTtyn wjk1bFdaMojR
aNGU16jK8soskmyXOD0MFuGsBrYvACG7AtxDWiqyhJfswQazOSvzt6bfXbWs YQapqmpY+OaB
rLUz1zaweAvfbHlzYdVd8XcRdkDo0c4F0sHarAMHFlbNFCNmPXHgwBNZpGGt dO4MkPCfwxPE
lUQoi+YgVYPlIdSQJa4S8nPFZWe0bFdMMa1YTpVUphQkC5NC/FUyoMUauivA lJ2tFhwu4i9i
NpmIOoiEGeLwP8PSRDWWqEiGcGY0Es0GKoJuNW0WJdKSz5yuwikRVXNlmWUD PWhS1TSXq1iU
jPLmGo3gpC2jMYxlZUKAoK/GktB9tgAMZaxWKx3PSgLh4AXFqbpL0Jff1tZm OJ4jDfWZtWfP
ZjU8N3t21paztQsIO1q2vWDLqt9mLa83OQoaqqrITn775oKs+vqsBasytq9Z K0Rk8dZsX7W6
cVnVgtqzq6lU0ZBlawpqV0uqVeAvB9Oa2Ws9ylrNS9Ugz81eTr8Gti9LeC6L 1YrWeftyeXEF
Wc4Ku+q5oGDz2bObhRJp0PI1poL578y+i99y9uwCGrRzecLMNaotZLmfSnbX eyEKa12llv4q
1elzXI8Qq4MRVjraJ2VNFiqhKo2gs6TMaKEWa0Y+87TKIlrKVjKJdM9zyc1S lo3kpy3ZoHEq
tvSLSmwKM1ebS3B7ABCysNpsNmlI66AWa8Eb375RwE523XvJXTs+zOIzC/Kn 2+2mqip+1Rv5
zKk4Pb8gs6reZM/PUDW8Y7bveKd+1Rur3qnaYZ9v5gtWTbcTVSZVq53rVn34 4bePEdP6dQ0N
jbMT1kkFZlaZHntc8i9M951D17IcRKpGI8c3PD87gbBqThc9nBkexTWuXyfG FNOuq9qxMb+g
cf311z/fKJW/yiHLn5D8jd/m01TX+61kIC9K6MIqiqi6tI4v9bhQV9edsqoy jNXUttQIw3RB
Z42i+Ur8yKqxOM+oqWmuUUlT/4GzLxEElYlriqY3TxkAMMRdAZTz58+zkwud HLG3tbS0sJPE
qRn1XxycSiX3Ag2hl8QDMZpwfOMt89Z98Tt7/dxHypLr1n3xt6n16dMn0xgP 7D78ACG7H06/
5JJ5r76bwZF5rx5+dZ67TKkAiu8cupZ1gbirwXJ75Mu5c+/6m5jpZO/i5Gkz pia2/O2u66vm
vnt4dwYhTa/MfbjTnZurRlK2vivpj9GjR4fsCujFsoFUQ41Go2RgCjpbVkZU GV1lVSaKztjM
b+Bt/pYJ/gNqvFpE2zaFGbea8poSlVdsAECwiE8FWEVsDp5wdvHYXG1sSk9L c/C8w0ZPU/Pm
8C+/tMt9JZUe5d2S/vLLljl5qcLRwy+n35JHL5fNSZ9TZrbmvfD3h6ZbGm15 c6bvNu4S86SX
HtxlleEzh65l2ZzVoAfTp6VZU3/14kOWh4WsvIqrd/BNjfVWeT3tHBGra7XW NzbRfGT5W627
HqTJA1fSD7TfQn8qoBcfGVPJJpeSMlu1SaWRzzIJImmhNieRpqBKqFymuCxe D/t0Q0meeE0l
XGABRhpSJqbE3BUAvbBYpSEtE9Z3S2a8KzrXbl3/+U22P7zGE6ZoJOW+54sX LZoxg15LL96x
4yYhSerUdMKlptDjm26+lXA3s1AWcc+i22e8Jkakd+329Y9fJiSUpXTiK4eu ZR228GI1mMIK
B1KUfMuOHR7Fpe7dk970mkdp5P7i18TMiBBoo4ndVWLNvI8qi49Kvv/4ZXtv +Xz9rT4O3F0X
WrcrAr+VkZSUtHLlyq1bt7733nsD8++muroai7CAIUt5ebm/1a3i4+MfeOCB e+65R61Wf/31
1xHS4COvF/6WrKu8f1rfF3XppZeaTKbNmzf/8Y9/9HIczJkzZ+nSpRs2bKit rQ27xQoAGOhw
Ah0dHRHSnk47NQU7+6U9Ytf1vysAADAIXAF0VGqz2SKkPUm/3LxZWNO/74vC IiwAAB8olWx2
ur29PXKEtR8Rdw0Q+3AoCmvgtX4BGLIkJCQcPHgw5Icxhzhms9lkMo0bN653 wiq8zFpRV6oe
VI0PsC8FAEOc+fPn792712AwYM+rEFAoFJMmTSooKIArAAAgQYf/swTQFb3v yR4Lq7hQo1pX
qTXoTCaSk0PqKkiRsBirwUQSExPRrQAMRtoF0A8XBWUlz/N1OqIzZFfo1Gpd negKMJnVFUI4
AACAngproUKRs21JHS+sxeJCWIyVqEvRQQAA0GNhpQZrqSlH4d6ZBQAAQO+E VW8i2so6ndps
NqM3AAAgDETrchQ6NnlVV6c1mwoLcxSmyjo1+gUAAEIXVtkiLGrXjoLaOvQM AACE6goIdNFQ
iA4CAICwCqu2Eh0EAABhFVYAAAA9J/rEiRPoBQAAgMUKAAAQVgAAGDrCmpIi 7IYqwTZHLTa6
T9BBAADQU6Kbm5tlpyqNRmW0WAjbbNViNKJ/AACg164AlSpD2LSa0kT1FR0E AAC9FVaiyddY
LE30wFhtzFChgwAAoMfCmuL2qYpkqFRNFguh6ko1Fh0EAAA9Jbq52WsnPpVG Q8qaLMRIj8gh
9BAA3REXFxcTExPBDbTZbF6bEQzBJvdMWLsGqVQZxuoyQjQlKoJ3WgHoFiox H3/8cU1NzYkT
JyJp2z6lUjlx4kSNRjNr1iwvlRmCTe6tsDI3a3GxUZOPTaUBCJI9e/ZkZmbq HsuJsHb9uaqN
Ns3njoRikx966CHZCnmDHoVCsXv3bn9N7p2wMjcraVJl4G4BIEjOnDnz7G+v oAfW06ciplGx
kxOXLRyxouSMvyY/+eSTCQkJ4oakkQH9kli8ePGjjz7ay3x8CquqpKa5pHf5 fv1Nc+Px9s/r
jxw7wT6VtORJl82Ylpkad+nEFNyEIPJwDYfjf7o6YhrV8e1WedO6NtlqtdKx s91uj5gmR0dH
00b13rkR3ReV+6Lpq3f3H5p1RdYvF90yNXkSHSgcO3nmi/ojb+08NPfG6J+o puA+BJEHb7cp
omMir1EBrjocDmriUTGKJIuVNioMAh32mn1u+erI8dO/eUCbnDjxPw1H3nm/ lgbm3XDlnQtv
vmHmT955/yOekJ9CW0HkCavVSpTKSHI48pyDNao7YY2oD3FgCuvX3zS/949D jwmq+uLr22r+
+emkCQk0fOuOmpL7l9xyw1UFt177wh8NE8deDp8AiDRvQGdHVExM+KfIt98R e8d24Sj76UOH
ns4WDs3PXP4L8hfpjJ5c/gxxXwwbDgdtVGBhpe0NzccqVFrawXTxX61/XRym Onv0zMUT1uTk
5DB+EPXH2mdekUVV9fDx01RVfzJj2ron7yM8uefXz7++tTrvhqvopf91RRaN dulE3IkgsoS1
o0M5PC4st6WbHXfG3Unebm9fxO6uZ6+8/DL+s8+emkELY5YiJxS2487Ln8l6 u/3tRSTMZRPe
bqeNChDBbrfTeoTwXUKbcuX2xZ+1fzpDamTsz4UWhONjcPdMCNAvibC4jMNs sX5Rf2Tp4ls4
nkxNnfzGi6tYMwlpa+ugo4VRI+LEMcNPs6Zt3bE3d2YmbkUQWcLazttHh9Vi rV/zu/qnPvlk
gZhp5hOfvGUe+bttT7y1iMoHEaaPTGuuvlMWJczjYiasbYGazHEhCWv99u3k qbeeyJRSLnir
tdX/JFmPhVWsWGiZKZXKsNQjzMJ6/OSZ5KRJPLOoyUTBCUBN16fWvE4PHr1P K3pjUpInHT9x
BvchiDRhbW+jShROq7Fh+/b6rCdUsiwzM7N27Nj2p/kLmaIRbtvSmc9mvdmy WhVuW1UmrO2B
XQGhjJ1pu/gFf+5S6aq74u+qko4Xvtny5oy1M5eRhTPWrq1yhiz0iCWFNKyd OXNtAwvIeuLA
gScI10uLdSD6WEXpFC1TXrBVRVV99sn7p6VM5oj7KgARJ6ytvN3GhVHiHDzJ yvTQnwxVFqln
qkEvNaybeZegR9s3FyzokxYp7DZHWyCL1Wq12kP4LnHwoih7JSvYfPbsZlF5 n5u9fI1pCz1Y
V79aCBRDCua/M/sufsvZs6y9O5cnzFyj2kKWVy2oPbs6S4izbE3BFuIz8+Cx BpyvuzjCmpo8
6VjzGXXWVOFjoebqV61tHXcszEsTVZVngTQCNVpxH4JIE9a2Nt5mDedDnQ6O b2gw2+3TXSGN
9fWEu52JGR3xZq768MPHG++9ZN3a3+Q/3heetWiblW9vDaxBNputx2NnBzMq HV17qnH99dc/
3yjZ5quoNPKZq36TL8QTk5iqqvhVb4ghJH/jt/ksSUND4+yEdU6Tvso833fm QX6IwsO5A05Y
c7Km/afhiCSsPLlkQsLPF+ZlZ03lBUllYssTGoFGw30IItEVENXS0hK2HCff NDej6otPW250
vQV5sK5x3m030jIudHIZc2+a3NIyeeWj6+Yu/91N7z4S/lclE+xKRzu1WKMC uAIo58+f73G7
uIcNnz7gWeXdD19fNffdw7tpYNMrcx/uvHCByhy5IHYobS89loeI0HAy79XD r85zhTS9UuUV
pyeMHj06LK6AMO95lTM17pNDDcdPfcMJ01b/+PCzv1XV1NUf5QWdpT/ppX8f aqDRcB+CCMPR
QS3WFms4Sf3VyvSX5z64Szwzl8152PJQcR47tjl43mET47z4EP/yQ2Vma9jh bRe49kCuAPGp
gBDalTdHXuVdD6anP7jLzpH0tFQhoL6xibbO3UZne4V0L+1ypZpTZsubM323 cZezf2g28lQh
NJnnB+JTAZdOTPmvq7837v1Ic8u1yVMm3nbrdX+tqrnxhiupplKdPfnVN/TS z65OxkOsIBIt
1nbOeiEsA0k3Nz33+frHL5sxQ3jFPL14x477UoQSmHwQm1hYyn3PF+9ZdPuj qZ+vvzW8LbKe
Fx63Gh3YYg2hySn3bd/hWHT7jNfE01vXf77+JnK4+LVFUktZW2024m6j1F6a zt0dNNV9VEjc
Iax/brL94TVXqhC+HR2OAfrm1ewrr6j97OArGw1XXZ6Vkzntzd8/TQPrGo7W NR759FADVVUa
ATchiEBh7ezgbK02my3M+eau+eSTNc4TZ/Yp91ZUeJx9cq/7NGwtohZrwMet xBcEQitWqrOs
XZ4hDHcb3e2Vd4d4zTOEePRMj5vMcQNUWEVtnZo0/j9H2/+2c2+z8GRVSvKk nKxpdy/AC1cg
YuE7O3hba0fAJ+oH2VeFrY3r7AwsQ5SIajLHDcTnWOU+gUsnkltm4S0AMGQs VpuVd7SF32K9
iDjaglkrIJKaPHAXYQFgCKJUKqnA8B0dV8a+KUzcKiOgUdT85u022jR/TaY/ 29vbI0lYxV0D
/DUZwgpAv5KQkFAx4pdFB9+6QI5HUrtoo8aN+9pfkw8ePBjmybqLjdlsNplM 48aNg7ACcPGZ
P3/+3r17S09dFUkbQCkUikmTvisoKAjQZIPBEHFNnuSvyRBWAPoPOhaeJRDB DUSTIawA9Cvt
AmgycKFEFwAAAIQVAAAgrAAAAGEFAAAAYQUAAAgrAABEKNF6Eykl+pwios3W 6QwsSFvJV2rp
b0OhopAkJqKPAACgZxaroYhKKyEmnUnLM+p0Zj0NMelzCkkltqcCAICeC6vJ ZNhmJkStK9XK
gk3bDMQzBAAAQJDCSm3U0mz0AwAAhI3oHEVhaZ3aO1i9REty9IZSV8Ds2bPR WQAAQImPj+9G
WLV1lVqi13dR1tK6ykKFQpy8Wrp0KboSAACCRMHzgWaokpKS0EcAAOCT2tpa 3xZr4GQnT54c
+G07d+6cwWBYsWJFZ2enuP2OuECkzWbrFHbsoT+tVisNVCgUarV606ZNNLKY 1mg0ajSaEydO
9LTQ6urq4uJi/GEFD+3k5ORk9AMY1H9X5eXl+fn53UbDCwIAABBmIKwAAABh BQAACCsAAEBY
AQAAhM7/B03iZjaotfzqAAAAAElFTkSuQmCC
--------------020608020008090300010401--
| Re: org.eclipse.epsilon.ewl.emf.WizardsExtensionPreferenceDialog [message #562443 is a reply to message #5051] |
Tue, 25 November 2008 13:12  |
Hi Dimitrios,
-- Nicolas.
> Hi Nicolas,
> Cheers,
> Dimitrios
>> OK/Cancel buttons.
>> Is this normal?
>> -- Nicolas.
| Re: org.eclipse.epsilon.ewl.emf.WizardsExtensionPreferenceDialog [message #562517 is a reply to message #5325] |
Hi Nicolas,
next...
Dimitrios
> Hi Dimitrios,
> -- Nicolas.
>> Hi Nicolas,
>> Cheers,
>> Dimitrios
>>> Hi,
>>> OK/Cancel buttons.
>>> Is this normal?
>>> -- Nicolas.
| Re: org.eclipse.epsilon.ewl.emf.WizardsExtensionPreferenceDialog [message #562541 is a reply to message #5676] |
Hi Dimitrios,
-- Nicolas.
> Hi Nicolas,
> next...
> Cheers,
> Dimitrios
>> Hi Dimitrios,
>> -- Nicolas.
>>> Hi Nicolas,
>>> Cheers,
>>> Dimitrios
>>>> Hi,
>>>> Is this normal?
>>>> -- Nicolas.
| Re: org.eclipse.epsilon.ewl.emf.WizardsExtensionPreferenceDialog [message #562564 is a reply to message #5694] |
Hi Nicolas,
Dimitrios
> Hi Dimitrios,
> -- Nicolas.
>> Hi Nicolas,
>> try next...
>> Cheers,
>> Dimitrios
>>> Hi Dimitrios,
>>> -- Nicolas.
>>>> Hi Nicolas,
>>>> Cheers,
>>>> Dimitrios
>>>>> Hi,
>>>>> Is this normal?
>>>>> -- Nicolas.
| Re: org.eclipse.epsilon.ewl.emf.WizardsExtensionPreferenceDialog [message #562586 is a reply to message #5712] |
Hi Dimitrios,
-- Nicolas.
> Hi Nicolas,
> Cheers,
> Dimitrios
>> Hi Dimitrios,
>> widgets.
>> -- Nicolas.
>>> Hi Nicolas,
>>> what to try next...
>>> Cheers,
>>> Dimitrios
>>>> Hi Dimitrios,
>>>> -- Nicolas.
>>>>> Hi Nicolas,
>>>>> running?
>>>>> Cheers,
>>>>> Dimitrios
>>>>>> Hi,
>>>>>> Is this normal?
>>>>>> -- Nicolas.
| Re: org.eclipse.epsilon.ewl.emf.WizardsExtensionPreferenceDialog [message #562604 is a reply to message #5729] |
Hi Nicolas,
Dimitrios
> Hi Dimitrios,
> -- Nicolas.
>> Hi Nicolas,
>> Cheers,
>> Dimitrios
>>> Hi Dimitrios,
>>> the widgets.
>>> -- Nicolas.
>>>> Hi Nicolas,
>>>> what to try next...
>>>> Cheers,
>>>> Dimitrios
>>>>> Hi Dimitrios,
>>>>> -- Nicolas.
>>>>>> Hi Nicolas,
>>>>>> running?
>>>>>> Cheers,
>>>>>> Dimitrios
>>>>>>> Hi,
>>>>>>> Is this normal?
>>>>>>> -- Nicolas.
Current Time: Thu Nov 06 04:24:27 EST 2025
Powered by FUDForum. Page generated in 0.05864 seconds
