Home » Eclipse Projects » DSDP - Target Management » Remote Debugging
| Remote Debugging [message #4911] |
Wed, 24 January 2007 10:12  |
Originally posted by: kieran.flynn.morganstanley.com
I am tryiing to do a remote c++ debug from a local windows xp machine to a
remote linux machine. The XP machine is running eclipse sdk 3.2.0 with cdt
3.1.0 and RSE 1.0.1. The remote machine is running i686 Red Hat & gdb v6.0
(I think).
I can set up remote file and shell access and that works fine. I can also
remotely launch applications too. However when I try to launch a debug
session I get the mystery error of "Error creating session" Details: "Exec
error: launching failed" (3 times)
The last output from the Console is:
/my/home/dir>gdbserver :8888 /my/path/rse_test;exit
Process /my/path/rse_test created; pid = 16477
I don't really know where to begin in figuring out why it doesn't work.
Could you maybe point me in the right direction?
Also, the gdb-server continues to run after this fails, so I have to kill
it in the processes tree on the left before trying again. Is there a
smarter way around that?
Thank you for your help
Kieran
| Re: Remote Debugging [message #5048 is a reply to message #4911] |
Thu, 25 January 2007 17:02   |
For remote debugging, you'll need a _local_ gdb executable that is
capable of understanding the remote exe file and architecture, and
connecting to the remote gdbserver. The remote gdbserver is only a very
thin layer, most work will be done locally.
I'm not sure what version of gdb you could get for Windows X Linux
debugging. Most vendors who do cross-compile / cross-debug in their
commercial products based on GNU Tools and Eclipse, build their own
versions of gdb for the cross-support from the sources. Therefore,
cygwin gdb or mingw gdb may not work out of the box unless you compile
them yourself and enable cross-support for linux. [building from source
may not be too difficult].
I do agree, though, that the error message should be more informative.
Ewa, can you help any further? Is there any point in running a whole gdb
remotely and piping the gdb/mi channel through the RSE IHostShell,
instead of just running the gdbserver remotely?
Cheers
Martin Oberhuber
Wind River Systems, Inc.
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Kieran schrieb:
> Hello,
> a remote linux machine. The XP machine is running eclipse sdk 3.2.0 with
> cdt 3.1.0 and RSE 1.0.1. The remote machine is running i686 Red Hat &
> gdb v6.0 (I think).
> also remotely launch applications too. However when I try to launch a
> debug session I get the mystery error of "Error creating session"
> Details: "Exec error: launching failed" (3 times)
> The last output from the Console is: /my/home/dir>gdbserver :8888
> kill it in the processes tree on the left before trying again. Is there
> a smarter way around that?
> Regards
> Kieran
| Re: Remote Debugging [message #5256 is a reply to message #5048] |
Mon, 12 February 2007 10:23   |
Hi Martin,
Thanks for your help on that. I did as you said and it's working quite
well now! For the reference of anyone else who needs to do it, tryign to
build the "cygwin" package of gdb won't work, you need to get the "real"
gdb and compile it FOR cygwin (crossed with whatever architecture you
want).
I have a few other questions though and maybe you can help point me to a
solution. This might be a bit verbose, but hopefully that means you'll
find it easier to help me out...
The project is set up like this:
project/
project/src/
project/build/
project/install/
project/install/lib
project/install/bin
and so on. The windows machine is running eclipse and is also running
cygwin.
the machine with the project is a linux box. the project folder is
accessible both in windows under a drive letter, and in cygwin at a mount
point, so all edditing etc is done through windows side, only remote
debugging is done via rse. The first time the debugger starts, it can't
see the source code for main() so it shows the assembly. I can point it to
the code for _that_ file but I can't get it to see the code for any of the
library files. Also in modules in the top right corner it shows the main
binary and all the libraries from the project as not having symbols
loaded. After that a mixture of some libraries are loaded, some are not.
For example libraries like \lib\ld-linux.so.2 must have loaded via cygwin.
Some of the libraries that aren't in cygwin obviously didn't load as they
are on the linux machine.
It seems sort of hit and miss to get eclipse to see all the code, all the
binaries/libraries and link it all together and I have to do it almost one
file at a time. I'm sure there's a better way but I can't see it. Any
suggestions?
Second, we have a highly customised build process here, is there any way
of doing remote builds in the same nature as teh remote debugging?
I really appreciate your help on this
Kieran
> Cheers
| Re: Remote Debugging [message #6046 is a reply to message #5256] |
Wed, 14 February 2007 11:55  |
Hello Kieran,
it looks like there's two distinct problems you have:
1.) The Debugger's source path mapping is not what you
want it to be. Since you built on remote, the debug
info has pathes like /home/kieran/... embedded, these
need to be mapped to local F:\kieran\... etc.
This source path mapping can be edited in the Launch
Configuration Dialog, Source Path Mapping tab.
2.) Since you're debugging a Linux executable on Windows,
your debugger needs access to the Linux libs and
sharedlibs, and NOT the cygwin variants of these.
Basically, you need to setup a LINUX /usr/lib/...
structure that is visible from Windows, and point
your debugger's libraryLoadPath to it. Such a setup
is very typical, most embedded debuggers have a
/target/lib, /target/bin, /target/share etc. structure
somewhere to mimic the layout of the remote filesystem
for the debugger.
Looking at the ELDK (embedded linux development kit)
might help.
3.) Remote Builds - when you execute "make" in an RSE
Commandview, it will automatically parse any error
output and allow you navigate to it in the editor.
The other option is to edit the CDT's "make command"
to do something like "ssh remotesystem make".
Above that, the CDT project has a bug from HP where
they contribute a solution for remote edit & build.
I'd be keep to hear from you how it's working since
I haven't tried it so far:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=168048
https://bugs.eclipse.org/bugs/show_bug.cgi?id=88546
https://bugs.eclipse.org/bugs/show_bug.cgi?id=71484
https://bugs.eclipse.org/bugs/show_bug.cgi?id=30091
Martin Oberhuber
Kieran wrote:
> Hi Martin,
> want).
> The project is set up like this: project/
> project/src/
> project/build/
> project/install/
> project/install/lib
> project/install/bin
> cygwin.
> mount point, so all edditing etc is done through windows side, only
> remote debugging is done via rse. The first time the debugger starts, it
> can't see the source code for main() so it shows the assembly. I can
> point it to the code for _that_ file but I can't get it to see the code
> for any of the library files. Also in modules in the top right corner it
> shows the main binary and all the libraries from the project as not
> having symbols loaded. After that a mixture of some libraries are
> loaded, some are not. For example libraries like \lib\ld-linux.so.2 must
> have loaded via cygwin. Some of the libraries that aren't in cygwin
> obviously didn't load as they are on the linux machine.
> the binaries/libraries and link it all together and I have to do it
> almost one file at a time. I'm sure there's a better way but I can't see
> it. Any suggestions?
> Kieran
>> very thin layer, most work will be done locally.
>> gdb remotely and piping the gdb/mi channel through the RSE IHostShell,
>> Cheers
| Re: Remote Debugging [message #566040 is a reply to message #4911] |
Cheers
Martin Oberhuber
Kieran schrieb:
> Hello,
> gdb v6.0 (I think).
> Regards
> Kieran
| Re: Remote Debugging [message #566153 is a reply to message #5048] |
Hi Martin,
want).
project/
project/src/
project/build/
project/install/
project/install/lib
project/install/bin
cygwin.
suggestions?
Kieran
> Cheers
| Re: Remote Debugging [message #566291 is a reply to message #5256] |
Hello Kieran,
for the debugger.
might help.
Martin Oberhuber
Kieran wrote:
> Hi Martin,
> want).
> project/src/
> project/build/
> project/install/
> project/install/lib
> project/install/bin
> cygwin.
> Kieran
>> Cheers
Current Time: Fri Nov 21 08:09:10 EST 2025
Powered by FUDForum. Page generated in 0.04777 seconds
