Home » Archived » EPF » launch epf on Fedora10
launch epf on Fedora10 [message #55103] Fri, 09 January 2009 05:01
Originally posted by: eangel.free.fr
Pas few weeks, I can't launch epf.
I have other applications as Eclipse, Freemind, Topcased,... with no
problem.
I use : ./epf -vm /usr/java/jdk1.5.0_14/jre/bin/java
and the result is :
# Java VM: Java HotSpot(TM) Client VM (1.5.0_14-b03 mixed mode, sharing)
# Problematic frame:
# C [libxul.so+0x9f62ed]
and the bug report contain :
System: Linux 2.6.27.9-159.fc10.i686 #1 SMP Tue Dec 16 15:12:04 EST 2008
i686
X Vendor: The X.Org Foundation
X Vendor Release: 10503000
Selinux: Permissive
Accessibility: Disabled
GTK+ Theme: Nodoka
Icon Theme: Fedora
Memory status: size: 0 vsize: 0 resident: 0 share: 0 rss: 0 rss_rlim: 0
CPU usage: start_time: 0 rtime: 0 utime: 0 stime: 0 cutime:0 cstime: 0
timeout: 0 it_real_value: 0 frequency: 0
----------- .xsession-errors (140 sec old) ---------------------
** (nautilus:3313): WARNING **: Unable to add monitor: Non pris en charge
gnome-session[3064]: WARNING: Application
'libcanberra-login-sound.desktop' failed to register before timeout
Acceleration key: disabled
*** Exiting...
XSETTINGS manager support is explicitly disabled.
I: caps.c: Limited capabilities successfully to CAP_SYS_NICE.
I: caps.c: Dropping root privileges.
N: main.c: Called SUID root and real-time/high-priority scheduling was
requested in the configuration. However, we lack the necessary privileges:
N: main.c: We are not in group 'pulse-rt' and PolicyKit refuse to grant
us privileges. Dropping SUID again.
N: main.c: For enabling real-time scheduling please acquire the
appropriate PolicyKit privileges, or become a member of 'pulse-rt', or
increase the RLIMIT_NICE/RLIMIT_RTPRIO resource limits for this u
W: main.c: La planification à haute priorité est activée dans la
configuration mais n'est pas permise par la politique.
W: core-util.c: setpriority(): Permission non accordée
/usr/bin/start-pulseaudio-x11: line 26: /usr/bin/pactl: Aucun fichier ou
dossier de ce type
/usr/libexec/Eclipse Process Framework Composer: No such file or directory.
MDRawHeader
signature = 0x504d444d
version = 0xa793
stream_count = 6
stream_directory_rva = 0x20
checksum = 0x0
time_date_stamp = 0x4965d3ae 2009-01-08 10:21:34
flags = 0x0
Previous Topic:Model Meta-Doc?
Next Topic:launch epf on Fedora10
Current Time: Sun Aug 31 08:21:22 EDT 2025
Powered by FUDForum. Page generated in 0.02887 seconds
