| Zend Debugger and breakpoints [message #54978] |
Wed, 26 September 2007 04:22  |
--------------090408070206060100000301
I use pdt 1.0,XP,php5.0.5/apache2.0.59,
and I have problems with Zend debugger...
I use zenddebugger.dll from
http://downloads.zend.com/pdt/server-debugger/ZendDebugger-5 .2.10-cygwin_nt-i386.tar.gz
When I debug,debug session starts, but debugger doesn't stop at breakpoints.
Here is php.ini:
zend_extension_ts=C:/php/ZendDebugger.dll
zend_debugger.allow_hosts=127.0.0.1
zend_debugger.expose_remotely=always
In phpinfo() everything is regular. I have zend debugger section.
I attached my .log file.
It seems that i have some errors for debugger.
name=".log"
Content-Disposition: inline;
filename=".log"
!ENTRY org.eclipse.php.debug.core 4 10001 2007-09-26 09:51:41.734
!MESSAGE PHPDebug plugin internal error
!STACK 0
java.lang.StringIndexOutOfBoundsException: String index out of range: -21
at java.lang.String.substring(Unknown Source)
at org.eclipse.php.internal.debug.core.zend.model.ServerDebugHa ndler.parsingErrorOccured(Unknown Source)
at org.eclipse.php.internal.debug.core.zend.debugger.RemoteDebu gger.handleNotification(Unknown Source)
at org.eclipse.php.internal.debug.core.zend.communication.Debug ConnectionThread$InputMessageHandler.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
!STACK 0
!ENTRY org.eclipse.php.debug.core 4 10001 2007-09-26 10:06:37.906
!STACK 0
!STACK 0
!ENTRY org.eclipse.php.debug.core 4 10001 2007-09-26 10:07:10.203
!STACK 0
!ENTRY org.eclipse.php.debug.core 4 10001 2007-09-26 10:07:10.312
!STACK 0
!ENTRY org.eclipse.php.debug.core 4 10001 2007-09-26 10:08:38.453
!STACK 0
!STACK 0
--------------090408070206060100000301--
| Re: Zend Debugger and breakpoints [message #56797 is a reply to message #56506] |
Thu, 04 October 2007 03:14  |
Andrew Thompson wrote:
> Not sure if this helps, but I ran into the same problem myself. I found
> out that it was that the plugin expects the project root to be the http
> root.
> My project structure had the http root as a subfolder of the project root.
> If the http root isn't the same point as the project root, then the
> plugin can't correctly inform the debugger which file the breakpoint is in.
> I ended up hacking the source to make the plugin work at a subfolder level.
"I found
root.
is in."
Same thing :-). I completely agree with you.
My http root is different than project root.
httproot = projectroot/webroot
I just try a little hack.
I made new php file which include my actual index.php, and new file is
in projectroot. But this also didn't work.
Can you tell me, please, how you solved this problem?
FUDForum. Page generated in 0.04417 seconds
