Home » Eclipse Projects » Remote Application Platform (RAP) » Starting Equinox service programmatically
Starting Equinox service programmatically [message #54946] Wed, 24 October 2007 04:01 Go to next message
For automatic testing I want to start/stop the Equinox service
programmatically add/remove bundles at runtime, is it possible ?
Best Regards,
Setya
Re: Starting Equinox service programmatically [message #55353 is a reply to message #54946] Thu, 25 October 2007 03:02 Go to previous messageGo to next message
I've got it working, for those insterested I followed this article :
http://www.eclipsezone.com/eclipse/forums/t93976.rhtml
Best Regards,
Setya
Re: Starting Equinox service programmatically [message #55870 is a reply to message #55353] Fri, 26 October 2007 10:17 Go to previous messageGo to next message
Sory, that article only tells how to install & start bundles as jars, when
I tried to install & start bundle as projects it throws the following
exception:
org.osgi.framework.BundleException: The activator
com.farbeyond.core.rap.CorePlugin for bundle com.farbeyond.core is invalid
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:962)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:317)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:256)
at com.farbeyond.core.test.TestCore.startTest(TestCore.java:84)
Caused by: java.lang.ClassNotFoundException:
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:402)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:347)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:278)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:134)
... 26 more
... Removed 22 stack frames
It complains about not being able to find the activator class, I don't
understand this since PDE does not complain about this and I can launch
through Equinox OSGI Framework without problems.
This how I install the bundle:
String[] args = new String[]{"-debug","-clean"};
BundleContext context = EclipseStarter.startup(args,null);
Bundle bundle =
context.installBundle("file:/home/setya/Projects/Farbeyond/JProjects+RAP/FBCore ")
bundle.start() //Exception thrown here.
Any ideas ?
Best Regards,
Setya
Re: Starting Equinox service programmatically [message #56018 is a reply to message #55870] Sun, 28 October 2007 23:06 Go to previous message
> exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 26 more
> Bundle bundle =
I've got it working now. It turns out I had to add 'Bundle-ClassPath:
bin/' in MANIFEST.MF. Now I have fully automatic unit testing.
Thanks.
Setya
Previous Topic:MessageDialog doesn't work!
Next Topic:Dialog setBlockOnOpen
Current Time: Sat Nov 08 16:05:45 EST 2025
Powered by FUDForum. Page generated in 0.03310 seconds
