Home » Modeling » M2T (model-to-text transformation) » [bug?] problem with xsi:nil
[bug?] problem with xsi:nil [message #54936] Thu, 08 January 2009 14:27 Go to next message
I think I hit a strange bug... using the transformation
<c:get select="/name" />
on
<name xsi:nil="true" />
I get the error:
templates/main.jet(1,1): <c:get select="/name">
Error: XPath expression returned no result
while it works for any other namespace/attribute:
<name any:nil="true" />
<name xsi:any="true" />
<name nil="true" />
<name any="true" />
any idea on the reason why?
Re: [bug?] problem with xsi:nil [message #54963 is a reply to message #54936] Thu, 08 January 2009 17:34 Go to previous message
Mauro,
I imagine that's because xsi:nil and xsi:type have special "meta
meaning" in the XML instance and hence aren't treated like any other
attribute. The <name xsi:nil="true"/> will be treated as if the name
were set to null, which would look the same as there being no name at
all. Likely that's the root of the issue...
> on
> I get the error:
> <name nil="true" />
> <name any="true" />
Previous Topic:append to an existing file using ws:file
Next Topic:MTL & GMF
Current Time: Mon Nov 03 03:17:05 EST 2025
Powered by FUDForum. Page generated in 0.02507 seconds
