Home » Archived » M2M (model-to-model transformation) » resolve duplicate elements of the target model
| resolve duplicate elements of the target model [message #54906] |
Thu, 26 July 2007 08:07  |
hi all,
ATL do not allow to navigate over the target model. But if i created
multiple different target elements (A1, .. ,Ai, .. An)from one source
element (S), i need to set correct references to this elements, so how
it can be done?
When i define the reference with the type to the S then it is always
transformed to one specific Ai. It is not possible to use
resolveTemp()-method because all Ai are constructed using one target
pattern. I thought to create my own tracing within the transformation,
but perhaps there is "better" solution.
thanks
regars,
Yury Kornev
| Re: [ATL] Re: resolve duplicate elements of the target model [message #55014 is a reply to message #54987] |
Fri, 27 July 2007 06:17   |
Originally posted by: y_kornev.gmail.com
hi,
Quentin Glineur schrieb:
> Please prefix you post subject with [ATL], thanks !
sorry, next time i will be more carefully
> I may have not understood everything but:
> resolveTemp() is the function to use to get the reference to a
> particular (i.e. not the first) target element when it has been created
> by a multi-target rule.
the question is how to get the reference to the one specific target
element (that was created through the lazy rule or distinct-foreach)
from the set of elements matched to one source element,e.g
from ob : MOF!EClass
to t1 : MOF!EClass(...)
do {
for (iterate in sequence) {
Lazyrule(ob);
Lazyrule{
to t : MOF!EClass (...)
if i undestood right, ATL engine traces all target elements, in this
case it provides only one reference (to t1)
but what happens to the elements initialized through the Lazyrule?
regards,
yury
> So, what do you mean by "constructed using one target pattern" ?
> (I understand a rule whose target is defined as follows :
> to
> t1 : Persons!Man, t2 : Persons!Man, t3 : Persons!Man (
> fullName <- s.firstName + ' ' + s.family.lastName
> for wich only the last element will be initialised)
> HTH,
> Quentin GLINEUR
> kornev a écrit :
>> hi all,
>> it can be done?
>> thanks
>> regars,
>> Yury Kornev
| Re: [ATL] Re: resolve duplicate elements of the target model [message #55040 is a reply to message #55014] |
Fri, 27 July 2007 06:55   |
Originally posted by: matt.mcgill.gmail.com
Yury Kornev wrote:
> hi,
>> created by a multi-target rule.
> do {
> Lazyrule(ob);
> Lazyrule{
Are you sure you didn't meed Lazyrule(iterate)? Or did you really want
to create |sequence| number of EClasses from ob?
Anyway, you can do this by decorating the source model with the target
elements you're creating, using a combination of helper and called rule.
Like this: (using your example, creating many target elements from same
source element)
helper context MOF!EClass def:
derived : Sequence(MOF!EClass) =
self.sequence->collect(i |
thisModule.CalledRule(self)
rule CalledRule(source : MOF!EClass) {
Then any time you need to get any of the created objects, you can just
access the derived collection.
Did I understand your problem correctly?
-Matt McGill
> regards,
> yury
>> to
>> fullName <- s.firstName + ' ' + s.family.lastName )
>> HTH,
>> Quentin GLINEUR
>> kornev a écrit :
>>> hi all,
>>> source element (S), i need to set correct references to this
>>> elements, so how it can be done?
>>> transformation, but perhaps there is "better" solution.
>>> thanks
>>> regars,
>>> Yury Kornev
| Re: [ATL] Re: resolve duplicate elements of the target model [message #55317 is a reply to message #55040] |
Mon, 30 July 2007 09:48  |
hi Matt,
i got your idea, thanks a lot
regards
yury kornev
Matt McGill schrieb:
> Yury Kornev wrote:
>> hi,
>> do {
>> Lazyrule(ob);
>> Lazyrule{
> source element)
> -Matt McGill
>> regards,
>> yury
>>> to
>>> HTH,
>>> Quentin GLINEUR
>>> kornev a écrit :
>>>> hi all,
>>>> thanks
>>>> regars,
>>>> Yury Kornev
Current Time: Sat Nov 08 10:19:41 EST 2025
Powered by FUDForum. Page generated in 0.04482 seconds
