Home » Archived » Test and Performance Tools Platform (TPTP) » hyades plug-in versus IAC
hyades plug-in versus IAC [message #54884] Fri, 24 February 2006 14:36 Go to next message
Originally posted by: Harry.Arendt.us.ing.org
If I intend to use only the IAC with tptp 4.1 do I need to have any of the
hyades plug-ins installed
at all?
It appears that there is a fair number of hyades classes and I wonder if I
need them.
Harry
Re: hyades plug-in versus IAC [message #54992 is a reply to message #54884] Mon, 27 February 2006 07:21 Go to previous message
It depends on what you are trying to do with IAC. If you wish to perform
profiling on Java applications, then I guess you might have to install
the complete TPTP runtime in order to do so.
If you can describe your use case then it may allow me to investigate
this further. Thanks.
Samson
> at all?
> need them.
> Harry
Previous Topic:Why is it so slow?
Next Topic:running tests from eclipse 3.2M5a
Current Time: Fri Jul 25 00:38:27 EDT 2025
Powered by FUDForum. Page generated in 0.10586 seconds
