| JDialogs vs JFrames behaviours [message #4888] |
Tue, 25 November 2003 01:35  |
Hello!
I observed a different behavior to JFrame and JDialog.
When I create a JFrame and I open it with the VE, an empty
Window appears. If I put a JPanel in the JFrame this JPanel
is treated as the ContentPane. And I can add my components
into this JPanel.
When I create a JDialog and I open it with the VE, an empty
Window appears. If I put a JPanel in the JDialog an error
appears: "components: java.lang.Error (Do not use
javax.swing.JDialog.add()
use javax.swing.jDialog.getContentPane().add() instead)".
So, if I add a first JPanel to an empty JFrame this JPanel is treated
as the Content Pane. If I do the same with a JDialog, no.
Well, but If I use the "New Visual Class" pop-up menu?
If I create a JFrame (I select "Frame" and "Swing"), an empty
Window appears but with a size and a ContentPane and a getContentPane()
method created.
If I create a JDialog (I select "Other", "Swing" and "JDialog")
[I think if JFrame haves a Radio Button in the wizard, then
JDialog must have another Radio Button. A JFrame based application
usually haves JDialogs]. An empty sized Window appears and an empty
JPanel outside the Window. It seems this JPanel is the Content Pane
for the Dialog. This JPanel appears without size. I must resize it
to add the components. If I add components into this JPanel, the
Window stays inalterable. The new components I added are only showed
into the JPanel.
Now, I drag the Content Pane into the JDialog. An error appears:
"components: java.lang.Error (Do not use javax.swing.JDialog.add()
use javax.swing.jDialog.getContentPane().add() instead)". Well, I undo
the add() and now I have a copy of the Content Pane in my JDialog!
Now I resize the Window/JDialog. The JPanel is resized and the
Window/JDialog don't shows the components of JPanel/ContentPane
any more.
Conclusion: IMHO I'm unable to develop a JDialog in a normal
manner. I think there is no reason to maintain two behaviours.
A JDialog must be the same bahaviour of a JFrame.
Francesc Rosés
| Re: JDialogs vs JFrames behaviours [message #5525 is a reply to message #5294] |
Tue, 25 November 2003 14:05  |
Peter,
Thanks a lot! Exactly there is an XML syntax error (JEdit indicates
the error...!). I modified the JDialog.override and all works!
Francesc
Peter Walker wrote:
> Francesc,
> Thanks for finding and reporting this problem. I opened bug 47421 to track
> this and I found the cause of the problem which is easy to fix. I'll release
> the fix for the next build (RC2).
> For now until the fix is available in the next build (which probably won't
> be out until after the US thanksgiving holiday) you can easily fix this
> yourself since it's not code and is just and xmi file change. Here's how:
> Edit (with Wordpro or Notepad) the file JDialog.override located in
> YOUR_INSTALL_DIReclipsepluginsorg.eclipse.ve.jfc_0.5.0overri desjavaxsw
> ing. Line 17 the statement says:
> </event:Add>
> Change it to:
> </event:AddMany>
> Save the file and restart Eclipse. (If you already have the project open,
> just close and reopen the project and the settings will be recached). The
> JDialog class should come up correctly with the contentpane on the JDialog.
> Note: I wouldn't recommend editing these files in the future since these are
> the xmi files that are used to decorate the AWT/Swing classes with specific
> overrides needed for the classes to work correctly in VE.
> Regards...
> Peter Walker
> "Francesc Rosés" <froses@menta.net> wrote in message
> news:bput6q$dsj$1@eclipse.org...
> > Hello!
> > into this JPanel.
> > method created.
> > into the JPanel.
> > any more.
> > Francesc Rosés
| Re: JDialogs vs JFrames behaviours [message #569097 is a reply to message #4888] |
Tue, 25 November 2003 09:57  |
Francesc,
YOUR_INSTALL_DIR\eclipse\plugins\org.eclipse.ve.jfc_0.5.0\ov errides\javax\sw
</event:Add>
Change it to:
</event:AddMany>
Regards...
Peter Walker
"Francesc Ros
| Re: JDialogs vs JFrames behaviours [message #569157 is a reply to message #5294] |
Peter,
Francesc
Peter Walker wrote:
> Francesc,
> </event:Add>
> Change it to:
> </event:AddMany>
> Regards...
> Peter Walker
> > Hello!
> > into this JPanel.
> > method created.
> > into the JPanel.
> > any more.
> > Francesc Rosés
FUDForum. Page generated in 0.03366 seconds
