| Zooming Rectangles [message #54827] |
Tue, 14 January 2003 06:43  |
Originally posted by: g.wagenknecht.intershop.de
Hi!
When drawing a figure with #paintFigure with:
g.fillRectangle(r);
g.drawRectangle(r);
and then zooming the rectangle gets detached from the background. Don't know
why. But when using polygons and polylines this doesn't happen.
PointList pl = new PointList();
pl.addPoint(r.getBottomLeft());
pl.addPoint(r.getTopLeft());
pl.addPoint(r.getTopRight());
g.fillPolygon(pl);
pl.addPoint(r.getBottomRight());
g.fillPolygon(pl);
g.drawPolyline(pl);
Is this by design or an implementation issue? Should I continue to use
polygones or rectangles?
Cu, Gunnar
| Re: Zooming Rectangles [message #54908 is a reply to message #54854] |
Tue, 14 January 2003 10:15   |
Originally posted by: noone.ibm.com
You are right, the way that Rectangles and polygons are drawn and filled is
inconsistent. This is done for a variety of reasons, and we haven't
completely decided on what the best approach is. (See Randy's post titled:
"Need help with ZOOM implementation" from 1/2/2002).
The reason that your rectangles and ovals are being clipped is due to the
way that draw and fill are currently implemented. To zoom a filled rectangle
or oval successfully, you must fill the rectangle and then subtract 1 from
the width and height of the rectangle, and then draw it.
Such as:
Rectangle rect = new Rectangle(0,0,100,100);
g.setBackgroundColor(ColorConstants.red);
g.fillRectangle(rect);
rect.height--;
rect.width--;
g.drawRectangle(rect);
> Hi!
> g.fillRectangle(r);
> g.drawRectangle(r);
know
> g.fillPolygon(pl);
> g.fillPolygon(pl);
> g.drawPolyline(pl);
> Cu, Gunnar
"Gunnar Wagenknecht" <g.wagenknecht@intershop.de> wrote in message
news:b00vbl$415$1@rogue.oti.com...
> "Gunnar Wagenknecht" <g.wagenknecht@intershop.de> schrieb im Newsbeitrag
> news:b00s7m$1p5$1@rogue.oti.com...
> > Hi!
> Same happens when painting ovals.
> graphics.fillOval(center.x-3, center.y-1, 5, 3);
> graphics.drawOval(center.x-3, center.y-1, 5, 3);
> It seems that Graphics#fillOval is scaled different from
Graphics#drawOval.
> How can I paint my figures correctly?
> Cu, Gunnar
| Re: Zooming Rectangles [message #58748 is a reply to message #54854] |
Tue, 28 January 2003 15:17  |
gunnar,
when you make those two calls for Rectangles, the top and left edges are
overlapping. The left edge of the drawRect(r) *overlaps* the fillRect(r).
However, the right edge of the drawRect(r) is *touching* the right edge (not
overlapping) of the fillRect(r). You can see this better using XOR for the
drawRect. Painting in the OS is inclusive (right and bottom edge) when
drawing, but exclusive for filling.
So, since the right and bottom edges are next to the filled region, you can
think of this as two lines that are next to each other. When you zoom in,
there is a gap. The solution is to use drawRect(r.getResized(-1, -1)),
which results in the rectangle exactly overlapping the fill region.
If you create a Figure and set it to be opaque with a LineBorder, you will
get exactly the right calls to draw/fill.
> > Hi!
Graphics#drawOval.
> Cu, Gunnar
FUDForum. Page generated in 0.05105 seconds
