Error 'AM3Repository' is not legal [message #54823] |
Thu, 26 July 2007 05:58  |
I have install a topcased toolkit, and the atl_am3-stable plugins, and
then when I run the topcased eclipse, I have the following error :
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Value
'AM3Repository' is not legal. (file:///local/arobert/topcased/topc
ased/megamodel-AM3.ecore, 3, 318)
org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.handleErrors(XMLL oadImpl.java:81)
org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:189)
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1354)
org.atl.engine.repositories.emf4atl.ASMEMFModel.loadASMEMFMo del(ASMEMFModel.java:341)
org.atl.eclipse.engine.AtlEMFModelHandler.loadModel(AtlEMFMo delHandler.java:110)
org.eclipse.am3.core.AM3Handler.mergeMegamodel(AM3Handler.ja va:129)
org.eclipse.am3.core.AM3Handler.initASMModel(AM3Handler.java :104)
org.eclipse.am3.core.AM3CorePlugin.createLoader(AM3CorePlugi n.java:117)
at org.eclipse.am3.core.AM3CorePlugin.start(AM3CorePlugin.java: 51)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:974)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:417)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:405)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319 )
at org.eclipse.am3.tools.tge.Startup.earlyStartup(Startup.java: 23)
org.eclipse.ui.internal.EarlyStartupRunnable.runEarlyStartup (EarlyStartupRunnable.java:87)
org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartu pRunnable.java:66)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.ui.internal.Workbench$54.run(Workbench.java:2190 )
Caused by: org.eclipse.emf.ecore.xmi.IllegalValueException: Value
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XM LHandler.java:2524)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setAttribValue(XML Handler.java:2578)
org.eclipse.emf.ecore.xmi.impl.SAXXMIHandler.handleObjectAtt ribs(SAXXMIHandler.java:76)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFa ctory(XMLHandler.java:2058)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromTy peName(XMLHandler.java:1961)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHa ndler.java:1896)
org.eclipse.emf.ecore.xmi.impl.XMIHandler.createObject(XMIHa ndler.java:131)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLH andler.java:1705)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:974)
org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:87)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:953)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:684)
org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa ndler.java:167)
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(AbstractSAXParser.java:533)
com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocume ntParser.emptyElement(AbstractXMLDocumentParser.java:220)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanStartElement(XMLDocumentFragmentScannerImpl.j a
va:872)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDispatcher.dispatch(XMLDocumentFra g
mentScannerImpl.java:1693)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java: 3
68)
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:834)
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:764)
com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(X MLParser.java:148)
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(AbstractSAXParser.java:1242)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:375)
org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:179)
... 32 more
Caused by: java.lang.IllegalArgumentException: The value 'AM3Repository'
is not a valid enumerator of 'LocationType'
org.eclipse.emf.ecore.impl.EFactoryImpl.createFromString(EFa ctoryImpl.java:280)
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.createFromStrin g(XMLHelperImpl.java:1575)
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.setValue(XMLHel perImpl.java:1141)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XM LHandler.java:2519)
... 55 more
Is there anything wrong in my installation?
Thank you for your help,
Anne.
Re: Error 'AM3Repository' is not legal [message #54851 is a reply to message #54823] |
Thu, 26 July 2007 06:09  |
Originally posted by: freddy.allilaire.univ-nantes.fr
Hi Anne,
There was a conformance problem between a model and its metamodel
(during AM3 loading). This error is fixed in CVS.
This problem should not impact on your work.
Freddy.
Anne Robert a écrit :
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.am3.core.AM3Handler.initASMModel(AM3Handler.java :104)
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> va:872)
> at
> at
> 68)
> at
> at
> at
> at
> at
> ... 32 more
> at
> at
> at
> at
> ... 55 more
> Anne.
Freddy Allilaire - ATLAS Group (INRIA & LINA)
http://www.sciences.univ-nantes.fr/lina/atl/contrib/allilair e
FUDForum. Page generated in 0.03807 seconds
