Patch for CDateTime behaviour [message #54764] |
Sun, 22 June 2008 05:25  |
Originally posted by: jprogrammer.gmail.com
Hi I've been using CDateTime in a project I am doing only needing an
editor for editing time only. I found the behaviour when taking away
focus confusing as you adjust the clock and then click out for focus and
the control would revert. Only by clicking the original drop down would
it stick. So I wrote a patch to change the behaviour. It could be
modified to only do this when a time is present.
I also found that the footer control would not be the value of the
current control on opening, I have patched this as well.
Cameron Crothers
Index: src/org/eclipse/nebula/widgets/cdatetime/CDateTime.java
RCS file: /cvsroot/technology/org.eclipse.swt.nebula/
org.eclipse.nebula.widgets.cdatetime/src/org/eclipse/nebula/ widgets/
cdatetime/CDateTime.java,v
retrieving revision 1.5
diff -u -r1.5 CDateTime.java
--- src/org/eclipse/nebula/widgets/cdatetime/CDateTime.java 16 Nov
2007 21:44:29 -0000 1.5
+++ src/org/eclipse/nebula/widgets/cdatetime/CDateTime.java 22 Jun
2008 09:07:05 -0000
@@ -416,11 +416,7 @@
protected void contentShellEvents(Event event) {
if(isOpen()) {
if(SWT.Deactivate == event.type) {
- Point p = Display.getCurrent
().getCursorLocation();
- Rectangle r = Display.getCurrent().map
(button.getParent(), null, button.getBounds());
- if(r.contains(p)) {
- cancelDate = null;
+ cancelDate = null;
super.contentShellEvents(event);
Index: src/org/eclipse/nebula/widgets/cdatetime/Picker_Clock_Analog .java
cdatetime/Picker_Clock_Analog.java,v
retrieving revision 1.2
diff -u -r1.2 Picker_Clock_Analog.java
--- src/org/eclipse/nebula/widgets/cdatetime/Picker_Clock_Analog .java
11 Oct 2007 20:37:23 -0000 1.2
+++ src/org/eclipse/nebula/widgets/cdatetime/Picker_Clock_Analog .java
22 Jun 2008 09:07:08 -0000
@@ -615,6 +615,8 @@
protected void updateSelection() {
- // TODO Auto-generated method stub
+ if(footerButton != null) {
+ footerButton.setSelection(combo.getSelection());
\ No newline at end of file
Re: Patch for CDateTime behaviour [message #54791 is a reply to message #54764] |
Sun, 22 June 2008 06:58  |
Hi Cameron,
Could you please file a bug and attach the patch there?
Tom
> Cameron Crothers
> 2008 09:07:05 -0000
> if(isOpen()) {
> @@ -615,6 +615,8 @@
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Patch for CDateTime behaviour [message #590579 is a reply to message #54764] |
Hi Cameron,
Tom
> Cameron Crothers
> 2008 09:07:05 -0000
> if(isOpen()) {
> @@ -615,6 +615,8 @@
FUDForum. Page generated in 0.05445 seconds
