Home » Language IDEs » ServerTools (WTP) » Derby dependency?
Derby dependency? [message #54737] Fri, 26 November 2004 15:21 Go to next message
I installed the new I20041125 binary and am trying to configure a Tomcat 5.0
server. I can add the server in the preference page, but it does not appear
in the target runtimes for a project configuration. Also, I cannot add it
to the Servers view.
No errors were reported, but I see errors in the log related to Derby. I
don't have Derby installed. Is there a config issue in the plugins, or is
Derby required? The referenced derby.server file is located in the plugin
directory; I don't know what's missing. Here is part of the log trace:
!ENTRY org.eclipse.jst.server.generic.core 4 1 Nov 26, 2004 13:01:56.462
!MESSAGE Error loading the server type definition
!STACK 0
Wrapped exception
org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'null'
not found.
(file:/C:/eclipse-contrib/wtp-I20041125/eclipse/plugins/org. eclipse.jst.server.generic.core_1.0.0/servers/derby.server,
5, 22)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.java:699)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM LHandler.java:740)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:444)
org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:65)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:431)
org.eclipse.emf.ecore.xmi.impl.SAXWrapper.startElement(SAXWr apper.java:75)
at org.apache.xerces.parsers.AbstractSAXParser.startElement(Unk nown Source)
at org.apache.xerces.impl.dtd.XMLDTDValidator.startElement(Unkn own Source)
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanSt artElement(Unknown
Source)
org.apache.xerces.impl.XMLDocumentScannerImpl$ContentDispatc her.scanRootElementHook(Unknown
Source)
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$Fragme ntContentDispatcher.dispatch(Unknown
Source)
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDo cument(Unknown
Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:129)
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:155)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:884)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:741)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:247)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:262)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:346)
at org.eclipse.jst.server.generic.internal.xml.XMLUtils.scanFil es(Unknown
Source)
at org.eclipse.jst.server.generic.internal.xml.XMLUtils.refresh (Unknown
Source)
at org.eclipse.jst.server.generic.internal.xml.XMLUtils.<init>(Unknown
Source)
org.eclipse.jst.server.generic.internal.core.ServerTypeDefin itionManager. <init>(Unknown
Source)
org.eclipse.jst.server.generic.core.CorePlugin.getServerType DefinitionManager(Unknown
Source)
org.eclipse.jst.server.generic.internal.ui.ServerDefinitionT ypeAwareWizardFragment.getAllServerDefinitionTypes(Unknown
Source)
org.eclipse.jst.server.generic.internal.ui.GenericServerRunt imeWizardFragment.createSelectionBar(Unknown
Source)
org.eclipse.jst.server.generic.internal.ui.GenericServerRunt imeWizardFragment.createContent(Unknown
Source)
org.eclipse.jst.server.generic.internal.ui.ServerDefinitionT ypeAwareWizardFragment.createComposite(Unknown
Source)
at org.eclipse.wst.server.ui.wizard.TaskWizardPage.createContro l(Unknown
Source)
at org.eclipse.wst.server.ui.wizard.TaskWizard.createPageContro ls(Unknown
Source)
org.eclipse.jface.wizard.WizardDialog.createPageControls(Wiz ardDialog.java:548)
org.eclipse.jface.wizard.WizardDialog.createContents(WizardD ialog.java:451)
at org.eclipse.jface.window.Window.create(Window.java:348)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:925)
at org.eclipse.jface.window.Window.open(Window.java:637)
at org.eclipse.wst.server.ui.actions.LaunchWizardAction.run(Unk nown Source)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:881 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:915)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:866)
org.eclipse.jface.action.ActionContributionItem$7.handleEven t(ActionContributionItem.java:785)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2772)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2431)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
Wrapped by
org.eclipse.emf.common.util.WrappedException: Package with uri 'null' not
found.
5, 22)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:266)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Re: Derby dependency? [message #55148 is a reply to message #54737] Thu, 02 December 2004 11:40 Go to previous message
Originally posted by: gercan.NOSPAM.acm.org
Actually there is no dependency on the derby server. The derby server
configuration for the generic server tooling was experimental
It was not meant to be in the integration build. This is corrected in todays
I build.
But an erronous config is something expected so it is handled and logged so
derby configuration should not cause the problem you describe.
Gorkem Ercan
"Dave Carlson" <dcarlson@xmlmodeling.com> wrote in message
news:co8379$jq0$1@www.eclipse.org...
5.0
appear
plugin
> !STACK 0
> Wrapped exception
'null'
> not found.
> 5, 22)
> at
:699)
> at
0)
> at
> at
> at
> at
Source)
> at
wn
> Source)
> at
entHook(Unknown
> Source)
> at
> Source)
> at
> Source)
> at
55)
> at
> at
> at
pl.java:247)
> at
eSetImpl.java:262)
> at
mpl.java:346)
> Source)
> Source)
> Source)
> at
it>(Unknown
> Source)
> at
r(Unknown
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> Source)
> at
48)
> at
Source)
> at
> at
tem.java:866)
> at
tionItem.java:785)
> at
> at
java:335)
> at
> at
> at
> at
..java:25)
> Wrapped by
> found.
> 5, 22)
> at
eSetImpl.java:266)
> at
mpl.java:346)
> Source)
> Source)
> Source)
> at
it>(Unknown
> Source)
> at
r(Unknown
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> Source)
Previous Topic:Bug? Problems during export
Next Topic:Build notes missing
Current Time: Mon Jul 21 21:59:51 EDT 2025
Powered by FUDForum. Page generated in 0.04708 seconds
