Home » Eclipse Projects » Mylyn » Need Mylyn 2.0.1.v20070920-1000 or later 2.0.x
Need Mylyn 2.0.1.v20070920-1000 or later 2.0.x [message #54713] Wed, 30 July 2008 01:37 Go to next message
Originally posted by: yem_eclipse_news.filter.yve.net
Hi all,
I am looking for Mylyn version 2.0.1.v20070920-1000 mentioned in this
comment:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=175211#c21
However, the builds page at http://www.eclipse.org/mylyn/builds/ only
lists versions up to 2.0.0 in the 2.0.x branch...
Where can I download 2.0.1.v20070920-1000 (or above 2.0.x I guess) ?
Thank you very much.
(Note: according to the bug report linked above, I need 2.0.1 to get
things working with Trac 0.11 under Eclipse 3.2)
Yves-Eric
Re: Need Mylyn 2.0.1.v20070920-1000 or later 2.0.x [message #54941 is a reply to message #54713] Wed, 30 July 2008 21:08 Go to previous messageGo to next message
The version mentioned on the bug report refers to an integration build.
These builds are not retained in the archive. Unfortunately the latest
Mylyn release supported on Eclipse 3.2 is version 2.0.0 which is not
compatible with Trac 0.11.
I can only recommend to either try a manual build of a CVS snapshot of the
particular date of the integration build or an update to Eclipse 3.3 and
Mylyn 3.0.0.
Steffen
Yves-Eric Martin wrote:
> Hi all,
> comment:
> Cheers,
Re: Need Mylyn 2.0.1.v20070920-1000 or later 2.0.x [message #54994 is a reply to message #54941] Wed, 30 July 2008 21:57 Go to previous message
Hello Steffen, and thank you very much for you help.
I will look at upgrading my Eclipse installation to 3.3 (I checked the
"Mylyn/Contributor Reference" document, and a manual build seems a bit
daunting).
Yves-Eric
> Mylyn 3.0.0.
> Steffen
Re: Need Mylyn 2.0.1.v20070920-1000 or later 2.0.x [message #592038 is a reply to message #54713] Wed, 30 July 2008 21:08 Go to previous message
Mylyn 3.0.0.
Steffen
> Hi all,
> comment:
> Cheers,
Re: Need Mylyn 2.0.1.v20070920-1000 or later 2.0.x [message #592062 is a reply to message #54941] Wed, 30 July 2008 21:57 Go to previous message
daunting).
Yves-Eric
> Mylyn 3.0.0.
> Steffen
Previous Topic:web browser
Next Topic:Problems installing Mylyn Trac connector for Eclipse 3.4
Current Time: Sat Nov 08 06:58:05 EST 2025
Powered by FUDForum. Page generated in 0.03817 seconds
