Home » Modeling » TMF (Xtext) » How to use tree rewrite actions?
How to use tree rewrite actions? [message #54674] Thu, 02 July 2009 06:00 Go to next message
Greetings!
I'm having a problem with some left recursive rules in my grammar. The
documentation gives a solution with left-factoring and tree rewrite rules
but it gives no further information on this subject. Does anyone know
where I can find more Information on these tree rewrite rules? Does it
have anything to do with the ANTLR rewrite rules?
Adalbert
Re: How to use tree rewrite actions? [message #54721 is a reply to message #54674] Thu, 02 July 2009 13:41 Go to previous message
Hi Adalbert,
please have a look at the section about assigned actions. These are the
kind of "rewrite rules", that are supported by Xtext.
In fact, actions allow to create more than one EObject in a parser rule
and thereby you can insert new objects in your semantic model.
Consider the following grammar snippet:
Something:
First ({Second.field = current} 'foo')?
First:
name = ID;
The input "id" will create a semantic object of type 'First' that will
be returned by the rule something.
But if you have an input like "id foo", you'll end up with an instance
of 'First' that will be assigned to the feature 'field' of a second
instance of type "Second".
Actually, the documentation contains a more meaningful example :-)
Sebastian
Am 02.07.2009 12:00 Uhr, schrieb Adalbert Gorecki:
> Greetings!
> rules but it gives no further information on this subject. Does anyone
> know where I can find more Information on these tree rewrite rules? Does
> it have anything to do with the ANTLR rewrite rules?
> Regards
> Adalbert
Previous Topic:[Xtext] Problem modifying enumeration in post processing (Xtend)
Next Topic:Unicode literals in Xtext grammar
Current Time: Fri Nov 07 12:10:45 EST 2025
Powered by FUDForum. Page generated in 0.03765 seconds
