OCL Console in EMF RCP editor [message #54665] |
Wed, 30 April 2008 21:57  |
The OCL Console from org.eclipse.emf.ocl.examples.interpreter is showing
up if I deploy the EMF editor in an Eclipse workbench, but the menu to
make it show does not appear if I deploy the RCP version of the
generated EMF editor.
Clearly, the RCP version lacks things the ocl interpreter plugin might
need, but the territory to investigate seems quite large for me at this
point.
Where should I look in order to make the ocl interpreter's menu show up
and to make the console appear?
Lucian
Re: OCL Console in EMF RCP editor [message #54751 is a reply to message #54665] |
Sat, 03 May 2008 21:51  |
Originally posted by: give.a.damus.gmail.com
Hi Lucian,
Which editor are you referring to? The Ecore or UML editor?
The example contributes to the menus of the default (IDE-specific)
generated editors. If you need this action in the RCP editors, then
they will have different editor IDs that you need to specify in the
example's action registration.
It's just an example -- modify it as you need.
HTH,
Christian
> showing up if I deploy the EMF editor in an Eclipse workbench, but
> the menu to make it show does not appear if I deploy the RCP version
> of thegenerated EMF editor.
> might need, but the territory to investigate seems quite large for me
> at thispoint.
> upand to make the console appear?
> Lucian
I'm trying a new usenet client for Mac, Nemo OS X.
You can download it at http://www.malcom-mac.com/nemo
FUDForum. Page generated in 0.03018 seconds
