Re: Integer to String Conversion [message #54778 is a reply to message #54610] |
Sat, 03 May 2008 21:53  |
Originally posted by: give.a.damus.gmail.com
Hi, Lucian,
The interactive console example does not currently support OCL
definitions. You are welcome to contribute an enhancement to it :-)
As far as GMF's support for OCL constraints is concerned, you'd best
ask on the GMF newsgroup to find out what your options are. MDT OCL
provides an API for parsing definitions, but it is up to GMF to use it
in some appropriate way.
Christian
On Wednesday 04-30-2008 (01:30), Lazar Codrut Lucian wrote:
> Hello,
> I want to use the operation Integer.toString() defined here:
> http://wiki.eclipse.org/OCLSnippets#Integer_to_String_Conver sion
> Where should I put it or how should I use it in order to make it
> work inthe Interactive OCL console?
> The initial form of this (
> http://dev.eclipse.org/newslists/news.eclipse.modeling.mdt.o cl/msg0111
> 4.html) works fine, but I'd rather not write this much for every
> query.
> Then, I want to use it to perform initializations in my GMF project.
> Where should I put it so that I can use it to write initializations
> inmy .gmfgraph file at design time?
> Thank you,
> Lucian
I'm trying a new usenet client for Mac, Nemo OS X.
You can download it at http://www.malcom-mac.com/nemo
FUDForum. Page generated in 0.02889 seconds
