Generate source using PDE [message #54604] |
Mon, 13 April 2009 07:11  |
I have a feature and a plugin and I am able to build this feature using
PDE headless mode. So I want to create a feature source, so I add
generated.feature to the build.properties of my feature. Here is what my
feature.xml looks like:
bin.includes = feature.xml
generate.feature@com.test.feature.source = com.test.feature
I expect PDE Build to generate 2 features:
com.test.feature
But I don't see the com.test.feature.source gets generated. Any ideas?
Re: Generate source using PDE [message #54683 is a reply to message #54657] |
Mon, 13 April 2009 13:21  |
You need to include "com.test.feature.source" before it will be
generated. The generate.feature property goes with the feature that
will include the generated source feature.
The normal layout is to do something like this :
com.test.sdk.feature
-(generate.feature@com.test.feature.source=com.test.feature)
- includes com.test.feature
- includes com.test.feature.source
Essentially build goes through the feature hierarchy, and if it hits an
inclusion that doesn't exist (com.test.feature.source) then it consults
the generate properties to see if it can be generated.
You generally don't need both generate.feature and generate.plugin. The
generate.feature will automatically generate source plugins for
everything included in the feature you are basing the source on.
You would use the generate.plugin if you didn't want a source feature
and just wanted source plugins. (And similar to generating the feature,
someone would need to include the source plugin before it got generated.)
-Andrew
hung wrote:
> Hi Chris,
> Thanks for your suggestion. I added it to the build.properties but
> still didn't work.
> Here is the new build.properties looks like:
> generate.plugin@com.test.source = com.test
> individualSourceBundles=true
> I am not sure if I setup my feature/plugin correctly. Do I need a new
> SDK feature as suggested in the Eclipse InfoCenter?
> Here is what the pdebuild.log looks like:
> Buildfile:
> c:/IBM/SDPShared/plugins/org.eclipse.pde.build_3.4.1.R34x_v2 0080805/scripts/build.xml
> main:
> preBuild:
> preSetup:
> checkLocalMaps:
> getMapFiles:
> [concat] No existing resources and no nested text, doing nothing
> postSetup:
> checkLocalBase:
> getBaseComponents:
> fetch:
> generate:
> preGenerate:
> [echo] create jazzsrc.zip
> buildSrcZip:
> [mkdir] Created dir: c:\temp\team.build\working.dir\build.artifacts
> [zip] Building zip:
> c:\temp\team.build\working.dir\build.artifacts\jazzsrc-xxx.z ip
> allElements:
> init:
> generateScript:
> postGenerate:
> process:
> preProcess:
> allElements:
> init:
> processElement:
> init:
> build.jars:
> init:
> all.features:
> all.plugins:
> properties:
> init:
> build.jars:
> properties:
> init:
> @dot:
> c:\temp\team.build\working.dir\plugins\com.test\temp.folder\ @dot.bin
> [javac] Compiling 2 source files to
> [copy] Copying 2 files to
> c:\temp\team.build\working.dir\plugins\com.test\@dot
> [delete] Deleting directory
> update.feature:
> all.children:
> postProcess:
> assemble:
> preAssemble:
> allElements:
> init:
> assembleElement:
> main:
> assemble.com.test.feature:
> main:
> [mkdir] Created dir: c:\temp\team.build\working.dir\tmp
> properties:
> init:
> gather.bin.parts:
> c:\temp\team.build\working.dir\tmp\eclipse\plugins\com.test_ 1.0.0
> [copy] Copying 3 files to
> customAssembly:
> init:
> gather.bin.parts:
> c:\temp\team.build\working.dir\tmp\eclipse\features\com.test .feature_1.0.0
> children:
> [copy] Copying 1 file to
> rootFiles:
> rootFiles*_*_*:
> customAssembly:
> customAssembly:
> jarUp:
> jarIng:
> [jar] Building jar:
> c:\temp\team.build\working.dir\tmp\eclipse\plugins\com.test_ 1.0.0.jar
> customAssembly:
> generate.p2.metadata:
> customAssembly:
> [zip] Building zip:
> c:\temp\team.build\working.dir\build.artifacts\com.test.feat ure-xxx.zip
> [zip] Updating zip:
> [delete] Deleting directory c:\temp\team.build\working.dir\tmp
> postAssemble:
> package:
> prePackage:
> allElements:
> init:
> packageElement:
> main:
> main:
> customAssembly:
> customAssembly:
> customAssembly:
> postPackage:
> postBuild:
> postBuild:
> gatherLogs:
> c:\temp\team.build\working.dir\build.artifacts\compilelogs
> allElements:
> init:
> gatherLogs:
> init:
> zip.logs:
> [mkdir] Created dir: c:\temp\team.build\working.dir\compile.logs.temp
> init:
> all.features:
> all.plugins:
> properties:
> init:
> gather.logs:
> c:\temp\team.build\working.dir\compile.logs.temp\plugins\com .test_1.0.0
> update.feature:
> all.children:
> [zip] Building zip:
> c:\temp\team.build\working.dir\features\com.test.feature\com .test.feature_1.0.0.log.zip
> [unzip] Expanding:
> into c:\temp\team.build\working.dir\build.artifacts\compilelogs
> allElements:
> init:
> gatherSources:
> init:
> build.sources:
> init:
> all.features:
> all.plugins:
> properties:
> init:
> build.sources:
> properties:
> init:
> src.zip:
> zip.src.zip:
> [zip] Building zip:
> c:\temp\team.build\working.dir\plugins\com.test\src.zip
> update.feature:
> all.children:
> init:
> zip.sources:
> c:\temp\team.build\working.dir\features\com.test.feature\fea ture.temp.folder
> init:
> all.features:
> all.plugins:
> properties:
> init:
> gather.sources:
> c:\temp\team.build\working.dir\features\com.test.feature\fea ture.temp.folder\plugins\null\src\com.test_1.0.0
> properties:
> init:
> copy.src.includes:
> update.feature:
> all.children:
> [zip] Building zip:
> c:\temp\team.build\working.dir\features\com.test.feature\com .test.feature_1.0.0.src.zip
> [mkdir] Created dir: c:\temp\team.build\working.dir\coverage-src
> [unzip] Expanding:
> c:\temp\team.build\working.dir\plugins\com.test\src.zip into
> generateUpdateSite:
> [mkdir] Created dir: c:\temp\team.build\working.dir\updateSiteStaging
> c:\temp\team.build\working.dir\updateSiteStaging\features
> c:\temp\team.build\working.dir\updateSiteStaging\plugins
> allElements:
> updateSiteExport:
> init:
> build.update.jar:
> init:
> all.features:
> all.plugins:
> properties:
> init:
> build.update.jar:
> properties:
> init:
> build.jars:
> properties:
> init:
> @dot:
> properties:
> init:
> gather.bin.parts:
> c:\temp\team.build\working.dir\plugins\com.test\temp.folder\ com.test_1.0.0
> [jar] Building jar:
> c:\temp\team.build\working.dir\updateSiteStaging\plugins\com .test_1.0.0.jar
> [jar] Building jar:
> update.feature:
> all.children:
> c:\temp\team.build\working.dir\features\com.test.feature\fea ture.temp.folder\features\com.test.feature_1.0.0
> init:
> gather.bin.parts:
> children:
> rootFiles:
> [jar] Building jar:
> c:\temp\team.build\working.dir\updateSiteStaging\features\co m.test.feature_1.0.0.jar
> BUILD SUCCESSFUL
> BUILD SUCCESSFUL
> Total time: 6 seconds
> Chris Aniszczyk wrote:
>>> using PDE headless mode. So I want to create a feature source, so I
>>> add generated.feature to the build.properties of my feature. Here is
>>> what my feature.xml looks like:
>>> com.test.feature
>> Which version of Eclipse are you using?
>> http://wiki.eclipse.org/PDEBuild/Individual_Source_Bundles
>> I would make sure you have this property:
>> Cheers,
>> Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
>> http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: Generate source using PDE [message #594988 is a reply to message #54630] |
Mon, 13 April 2009 11:32  |
Hi Chris,
still didn't work.
Buildfile:
main:
preBuild:
preSetup:
checkLocalMaps:
getMapFiles:
postSetup:
checkLocalBase:
getBaseComponents:
fetch:
generate:
preGenerate:
buildSrcZip:
[zip] Building zip:
allElements:
init:
generateScript:
postGenerate:
process:
preProcess:
allElements:
init:
processElement:
init:
build.jars:
init:
all.features:
all.plugins:
properties:
init:
build.jars:
properties:
init:
@dot:
update.feature:
all.children:
postProcess:
assemble:
preAssemble:
allElements:
init:
assembleElement:
main:
main:
properties:
init:
gather.bin.parts:
customAssembly:
init:
gather.bin.parts:
children:
rootFiles:
rootFiles*_*_*:
customAssembly:
customAssembly:
jarUp:
jarIng:
[jar] Building jar:
customAssembly:
customAssembly:
[zip] Building zip:
[zip] Updating zip:
postAssemble:
package:
prePackage:
allElements:
init:
packageElement:
main:
main:
customAssembly:
customAssembly:
customAssembly:
postPackage:
postBuild:
postBuild:
gatherLogs:
allElements:
init:
gatherLogs:
init:
zip.logs:
init:
all.features:
all.plugins:
properties:
init:
gather.logs:
update.feature:
all.children:
[zip] Building zip:
[unzip] Expanding:
allElements:
init:
gatherSources:
init:
build.sources:
init:
all.features:
all.plugins:
properties:
init:
build.sources:
properties:
init:
src.zip:
zip.src.zip:
[zip] Building zip:
update.feature:
all.children:
init:
zip.sources:
init:
all.features:
all.plugins:
properties:
init:
gather.sources:
properties:
init:
copy.src.includes:
update.feature:
all.children:
[zip] Building zip:
[unzip] Expanding:
generateUpdateSite:
allElements:
updateSiteExport:
init:
build.update.jar:
init:
all.features:
all.plugins:
properties:
init:
build.update.jar:
properties:
init:
build.jars:
properties:
init:
@dot:
properties:
init:
gather.bin.parts:
[jar] Building jar:
[jar] Building jar:
update.feature:
all.children:
init:
gather.bin.parts:
children:
rootFiles:
[jar] Building jar:
BUILD SUCCESSFUL
BUILD SUCCESSFUL
>> com.test.feature
> Cheers,
Re: Generate source using PDE [message #594994 is a reply to message #54657] |
-Andrew
hung wrote:
> Hi Chris,
> still didn't work.
> Buildfile:
> main:
> preBuild:
> preSetup:
> checkLocalMaps:
> getMapFiles:
> postSetup:
> checkLocalBase:
> getBaseComponents:
> fetch:
> generate:
> preGenerate:
> buildSrcZip:
> [zip] Building zip:
> allElements:
> init:
> generateScript:
> postGenerate:
> process:
> preProcess:
> allElements:
> init:
> processElement:
> init:
> build.jars:
> init:
> all.features:
> all.plugins:
> properties:
> init:
> build.jars:
> properties:
> init:
> @dot:
> update.feature:
> all.children:
> postProcess:
> assemble:
> preAssemble:
> allElements:
> init:
> assembleElement:
> main:
> main:
> properties:
> init:
> gather.bin.parts:
> customAssembly:
> init:
> gather.bin.parts:
> children:
> rootFiles:
> rootFiles*_*_*:
> customAssembly:
> customAssembly:
> jarUp:
> jarIng:
> [jar] Building jar:
> customAssembly:
> customAssembly:
> [zip] Building zip:
> [zip] Updating zip:
> postAssemble:
> package:
> prePackage:
> allElements:
> init:
> packageElement:
> main:
> main:
> customAssembly:
> customAssembly:
> customAssembly:
> postPackage:
> postBuild:
> postBuild:
> gatherLogs:
> allElements:
> init:
> gatherLogs:
> init:
> zip.logs:
> init:
> all.features:
> all.plugins:
> properties:
> init:
> gather.logs:
> update.feature:
> all.children:
> [zip] Building zip:
> [unzip] Expanding:
> allElements:
> init:
> gatherSources:
> init:
> build.sources:
> init:
> all.features:
> all.plugins:
> properties:
> init:
> build.sources:
> properties:
> init:
> src.zip:
> zip.src.zip:
> [zip] Building zip:
> update.feature:
> all.children:
> init:
> zip.sources:
> init:
> all.features:
> all.plugins:
> properties:
> init:
> gather.sources:
> properties:
> init:
> copy.src.includes:
> update.feature:
> all.children:
> [zip] Building zip:
> [unzip] Expanding:
> generateUpdateSite:
> allElements:
> updateSiteExport:
> init:
> build.update.jar:
> init:
> all.features:
> all.plugins:
> properties:
> init:
> build.update.jar:
> properties:
> init:
> build.jars:
> properties:
> init:
> @dot:
> properties:
> init:
> gather.bin.parts:
> [jar] Building jar:
> [jar] Building jar:
> update.feature:
> all.children:
> init:
> gather.bin.parts:
> children:
> rootFiles:
> [jar] Building jar:
> BUILD SUCCESSFUL
> BUILD SUCCESSFUL
>>> com.test.feature
>> Cheers,
FUDForum. Page generated in 0.04200 seconds
