Home » Eclipse Projects » DTP » How do I repair eclipse (remove datatools)?
How do I repair eclipse (remove datatools)? [message #54596] Tue, 07 April 2009 15:10 Go to next message
Originally posted by: asd.asd.com
I have updated eclipse through the update manager for Vista 32 bit. But each
time I try to install something new I get:
An error occurred while collecting items to be installed
No repository found containing:
org.eclipse.datatools.enablement.ibm.feature/org.eclipse.upd ate.feature/1.6.0.v200804021-7D40EB7sQS9RWfUjJLb
org.eclipse.datatools.enablement.jdt.feature/org.eclipse.upd ate.feature/1.6.0.v200804021-1-07w311916263466
org.eclipse.datatools.enablement.mysql.feature/org.eclipse.u pdate.feature/1.6.0.v200804021-441_kE77c7QASCMPN
org.eclipse.datatools.enablement.sybase.ase/osgi.bundle/1.0. 1.v200807010411
org.eclipse.datatools.enablement.sybase.feature/org.eclipse. update.feature/1.6.1.v200809191145-7A-5E9IgKLhLGetRuu9
org.eclipse.datatools.enablement.sybase.ui/osgi.bundle/1.0.0 .v200808221518
org.eclipse.datatools.sqldevtools.data.feature/org.eclipse.u pdate.feature/1.6.1.v200809191145-30-9oA55S5SBG5ND5
org.eclipse.datatools.sqltools.data.core/osgi.bundle/1.0.0.v 200808260630
org.eclipse.datatools.sqltools.data.ui/osgi.bundle/1.1.0.v20 0808260630
org.eclipse.datatools.sqltools.tabledataeditor/osgi.bundle/1 .0.0.v200808300730
It also happens when I try to uninstall plugins. When I eg. try to uninstall
the C/C++ Development Platform I also get the above message. It seems that
dtp has corrupted
the eclipse update manager. Is there someway to fix this kind of problem
without reinstalling eclipse?
Re: How do I repair eclipse (remove datatools)? [message #54624 is a reply to message #54596] Tue, 07 April 2009 18:55 Go to previous messageGo to next message
Originally posted by: brianf.sybase.com
Can anybody help out JS?
JS, can you provide some additional details... What version of Eclipse are
you using? What version of DTP are you trying to install? Etc...
--Fitz
"JS" <asd@asd.com> wrote in message news:grg8fu$8l2$1@build.eclipse.org...
>each time I try to install something new I get:
> uninstall the C/C++ Development Platform I also get the above message. It
> seems that dtp has corrupted
Re: How do I repair eclipse (remove datatools)? [message #54676 is a reply to message #54624] Wed, 08 April 2009 04:16 Go to previous messageGo to next message
I am using eclipse:
Version: 3.4.2
Build id: M20090211-1700
As described earlier the error does not only appear when I try to install
dtp 1.6.1 but also when I try to uninstall some of the other plugins.
When I look at "Installed software" I don't find any references to dtp, so I
don't know why its looking in those repositories.
"Brian Fitzpatrick" <brianf@sybase.com> wrote in message
news:grgllu$j1a$1@build.eclipse.org...
> --Fitz
Re: How do I repair eclipse (remove datatools)? [message #54836 is a reply to message #54676] Thu, 09 April 2009 00:22 Go to previous messageGo to next message
I had a similar problem when I first installed DTP a month or so ago. I
figured the repository I was pointing to with the update manager was
temporarily unreachable for some reason. I downloaded the zip file with
the DTP code and installed it from my file system.
The errors stopped appearing, but I may have done something else as
well, I'm not sure. Perhaps you should click "Manage Sites" in the
Software Update window, and delete the DTP sites, then install DTP from
your file system.
-Mark
JS wrote:
> I am using eclipse:
> Version: 3.4.2
> install dtp 1.6.1 but also when I try to uninstall some of the other
> plugins.
> so I don't know why its looking in those repositories.
>> are you using? What version of DTP are you trying to install? Etc...
>> --Fitz
>>> But each time I try to install something new I get:
>>> message. It seems that dtp has corrupted
>>> problem without reinstalling eclipse?
Re: How do I repair eclipse (remove datatools)? [message #54863 is a reply to message #54836] Thu, 09 April 2009 05:57 Go to previous messageGo to next message
If I remove DTP from "Manage Sites" I cannot install or uninstall anything
anymore, it just hangs (for some reason it reads from the DTP repositories
before it can uninstall eg the C++ plugin). Seems a reinstall of eclipse is
the only solution, even though it could be nice to know what is wrong with
DTP.
"Mark Leone" <midnightjava@verizon.net> wrote in message
news:grjt68$p28$1@build.eclipse.org...
>temporarily unreachable for some reason. I downloaded the zip file with the
> The errors stopped appearing, but I may have done something else as well,
> I'm not sure. Perhaps you should click "Manage Sites" in the Software
> Update window, and delete the DTP sites, then install DTP from your file
> system.
> -Mark
> JS wrote:
>> I am using eclipse:
>> Version: 3.4.2
>>> --Fitz
Re: How do I repair eclipse (remove datatools)? [message #54891 is a reply to message #54863] Thu, 09 April 2009 06:03 Go to previous messageGo to next message
Update: I have tried removing the check in "Web Tools (WTP) Update Site"
under "Manage Sites" and now I can uninstall the C++ plugin. Are there any
connection/dependency between WTP and DTP?
"JS" <asd@asd.com> wrote in message news:grkgr3$a30$1@build.eclipse.org...
> is the only solution, even though it could be nice to know what is wrong
> with DTP.
>> system.
>> -Mark
>> JS wrote:
>>> I am using eclipse:
>>> Version: 3.4.2
>>> plugins.
>>>> --Fitz
Re: How do I repair eclipse (remove datatools)? [message #54918 is a reply to message #54891] Thu, 09 April 2009 09:52 Go to previous messageGo to next message
WTP is dependent on DTP, but if you install WTP it should install the
correct version of DTP along with it.
I'm not a big fan of the update manager. I just grab zips for the most part
and install them directly as Mark mentioned.
--Fitz
"JS" <asd@asd.com> wrote in message news:grkh5i$c80$1@build.eclipse.org...
>> anything anymore, it just hangs (for some reason it reads from the DTP
>> repositories before it can uninstall eg the C++ plugin). Seems a
>> reinstall of eclipse is the only solution, even though it could be nice
>> to know what is wrong with DTP.
>>> your file system.
>>> -Mark
>>> JS wrote:
>>>> I am using eclipse:
>>>> Version: 3.4.2
>>>> plugins.
>>>>> --Fitz
Re: How do I repair eclipse (remove datatools)? [message #56153 is a reply to message #54918] Fri, 01 May 2009 17:26 Go to previous message
Hi again...
We're trying to narrow down a reproducible scenario to try and figure out
what's going on. We've started to collect details here:
http://wiki.eclipse.org/DTP_1.6.2_Update_Manager_Issues
Please let us know if you find out anything else and we'll continue to bang
on this.
Thanks.
--Fitz
news:grkuj7$ltp$1@build.eclipse.org...
> part and install them directly as Mark mentioned.
> --Fitz
>> any connection/dependency between WTP and DTP?
>>>> your file system.
>>>> -Mark
>>>> JS wrote:
>>>>> I am using eclipse:
>>>>> Version: 3.4.2
>>>>> plugins.
>>>>> dtp, so I don't know why its looking in those repositories.
>>>>>> Eclipse are you using? What version of DTP are you trying to install?
>>>>>> Etc...
>>>>>> --Fitz
Re: How do I repair eclipse (remove datatools)? [message #595157 is a reply to message #54596] Tue, 07 April 2009 18:55 Go to previous message
--Fitz
Re: How do I repair eclipse (remove datatools)? [message #595171 is a reply to message #54624] Wed, 08 April 2009 04:16 Go to previous message
I am using eclipse:
Version: 3.4.2
> --Fitz
Re: How do I repair eclipse (remove datatools)? [message #595243 is a reply to message #54676] Thu, 09 April 2009 00:22 Go to previous message
your file system.
-Mark
JS wrote:
> I am using eclipse:
> Version: 3.4.2
> plugins.
>> --Fitz
Re: How do I repair eclipse (remove datatools)? [message #595253 is a reply to message #54836] Thu, 09 April 2009 05:57 Go to previous message
DTP.
> system.
> -Mark
> JS wrote:
>> I am using eclipse:
>> Version: 3.4.2
>>> --Fitz
Re: How do I repair eclipse (remove datatools)? [message #595260 is a reply to message #54863] Thu, 09 April 2009 06:03 Go to previous message
> with DTP.
>> system.
>> -Mark
>> JS wrote:
>>> I am using eclipse:
>>> Version: 3.4.2
>>> plugins.
>>>> --Fitz
Re: How do I repair eclipse (remove datatools)? [message #595272 is a reply to message #54891] Thu, 09 April 2009 09:52 Go to previous message
--Fitz
>>> your file system.
>>> -Mark
>>> JS wrote:
>>>> I am using eclipse:
>>>> Version: 3.4.2
>>>> plugins.
>>>>> --Fitz
Re: How do I repair eclipse (remove datatools)? [message #595684 is a reply to message #54918] Fri, 01 May 2009 17:26 Go to previous message
Hi again...
on this.
Thanks.
--Fitz
> --Fitz
>>>> your file system.
>>>> -Mark
>>>> JS wrote:
>>>>> I am using eclipse:
>>>>> Version: 3.4.2
>>>>> plugins.
>>>>>> Etc...
>>>>>> --Fitz
Previous Topic:A few last-minute changes to DTP APIs (sorry for late notice)
Next Topic:Re: Can't install a thing
Current Time: Sun Aug 31 05:18:09 EDT 2025
Powered by FUDForum. Page generated in 0.06216 seconds
