| SubMenu in PopUp Menu [message #54576] |
Sat, 24 May 2003 19:07  |
I want to have submenu in a PopUp Menu.I have created the SWT menu using
the menu class(org.eclipse.swt.widgets.Menu).I tried creating sub menu by
giving parent menu as argument but it doesn't show up.I also tried by giving
menu item as argument still I am not able to get it.I also tried setting
Menu.setVisible(true) but in vain.
How to do solve this problem.
Here is the snippet
//snippet
public RateManagerPocD220503V01PopUp(final Composite parent, final
RateManagerPocD220503V01Book editorBook) {
menu = new Menu(parent.getShell(),SWT.POP_UP);
cut = new MenuItem (menu, SWT.CASCADE);
clearContents = new MenuItem(menu,SWT.CASCADE);
subMenu = new Menu(clearContents);
subMenuItem = new MenuItem(subMenu,SWT.PUSH);
cut.setText("&Cut");
copy.setText("Copy");
clearContents.setText("Clear Contents");
parent.setMenu(menu);
//End of Snippet
MorPheus
| Re: SubMenu in PopUp Menu [message #55030 is a reply to message #54576] |
Tue, 10 June 2003 02:52  |
There are some properties mandatory in setting up a submenu. Here is a
simple example.
Menu menu = new Menu(shell);
MenuItem itemOne = new MenuItem(menu, SWT.PUSH);
itemOne.setText("First");
// Should use the CASCADE style if it holds a submenu
MenuItem itemTwo = new MenuItem(menu, SWT.CASCADE);
itemTwo.setText("Second");
// Should be a DROP_DOWN in its style
Menu subMenu = new Menu(shell, SWT.DROP_DOWN);
MenuItem itemThree = new MenuItem(subMenu, SWT.PUSH);
itemThree.setText("SubMenu Item");
itemTwo.setMenu(subMenu);
"MorPheus" <rgurupackiam@selectica.com> wrote in message
news:baoth8$nbs$1@rogue.oti.com...
using
giving
> Here is the snippet
> //snippet
> //End of Snippet
> MorPheus
| Re: SubMenu in PopUp Menu [message #594031 is a reply to message #54576] |
Tue, 27 May 2003 12:39  |
One thing about SWT is that many components require that you call their
setter methods, not just create them with their parent component in the
constructor.
Right before calling parent.setMenu(menu), insert this line:
clearContents.setMenu(subMenu);
MorPheus wrote:
> Here is the snippet
> //snippet
> //End of Snippet
> MorPheus
| Re: SubMenu in PopUp Menu [message #594206 is a reply to message #54576] |
simple example.
using
giving
> Here is the snippet
> //snippet
> //End of Snippet
> MorPheus
FUDForum. Page generated in 0.30644 seconds
