| AGR example [message #54531] |
Thu, 23 February 2006 19:18  |
Originally posted by: vik_ram.hotmail.com
I have installed the following:
tptp.sdk-TPTP-4.1.0-200511230100B.zip
and
org.eclipse.tptp.test.auto-TPTP-4.1.0-200511230100.zip
I am trying to run through the TPTP GUI recorder example that creates a
Java Project. It works in the quick run mode ( Great!!)
I tried the deployment file method ( standard mode ).
A new workbench window opens, but nothing really happens.
I had pointed to the startup.jar of another eclipse installation on my
machine. SO, I changed it(startup.jar location) to the one where I have
installed TPTP, and I get a .execution file with a start, inconclusive,
and a stop event.
Not sure what's going on.
Please help!!!
| Re: AGR example [message #55130 is a reply to message #54938] |
Mon, 27 February 2006 09:54  |
> - You don't need a deployment file if you are testing this locally.
OK. In the overview page , I unchecked "Use current workbench as
context" and pointed to the startup.jar and ran in the standard mode.
( Same results )
> - Do you have the Agent Controller installed?
No. Does it matter. I'll be running locally.
> - The startup.jar file that the test suite points to should have the auto
> gui plug-in in its 'plugin' direcotry.
OK. I did try to point to the instance where I have auto gui plugin
installed. ( Didn't help )
> - *Most importantly, make sure that you have the test case included in the
> behavior page of the test suite
Did this and it worked. Awesome.
Thanks for your help.
Vikram
> "vikram" <vik_ram@hotmail.com> wrote in message
> news:dtljd0$9nd$1@utils.eclipse.org...
>>Hi,
>>and
>>and a stop event.
>>Please help!!!
>>Thanks
FUDForum. Page generated in 0.03719 seconds
