Home » Eclipse Projects » Remote Application Platform (RAP) » Switch for disabling widget pooling
Switch for disabling widget pooling [message #54474] Tue, 23 October 2007 04:26 Go to next message
Hello RAP-team,
during the last weeks we had a lot of problems which were related to the
browser-side widget pooling. Currently, one of the [pooling]-tagged
bugs has a major negative impact on our application (202130 - [pooling]
StackLayout: Label.setText() doesn't work).
What do you think of the idea to add a switch which lets us easily
enable/disable the widget-pooling? This could be realized by a system
property for instance. Another temporary workaround for the above
mentioned bug could be to disable the widget pooling for the label in
the current CVS Head.
Stefan.
Re: Switch for disabling widget pooling [message #54607 is a reply to message #54474] Tue, 23 October 2007 07:15 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
I would prefer the latter approach.
Ciao
Frank
"Stefan R
Re: Switch for disabling widget pooling [message #54634 is a reply to message #54607] Tue, 23 October 2007 09:25 Go to previous messageGo to next message
Hi Frank,
could you submit this to CVS Head then? Or do you see any other
workaround for the bug?
Stefan.
Re: Switch for disabling widget pooling [message #54685 is a reply to message #54634] Tue, 23 October 2007 10:15 Go to previous message
Hi again,
I disabled the widget pooling for labels in CVS-Head. Please confirm that
this works for you.
Ciao
Frank
"Stefan R
Previous Topic:RAP Command Line Launch
Next Topic:Installing RAP, if you didn't follow the directions...
Current Time: Mon Jul 21 23:53:35 EDT 2025
Powered by FUDForum. Page generated in 0.04217 seconds
