Home » Eclipse Projects » Equinox » Software update
Software update [message #54469] Mon, 12 December 2005 02:25 Go to next message
OSGi platforms (Equinox) should be a good platform for dealing with
software
updates. Some service could look for updates (automaticaly/"manualy"
triggered),
download them and then replace the outdated bundle.
My question is: How "deep" can the software update work? Are their
possibilites
that the software update service can also update itself or the complete
platform
without restarting the JVM?
Re: Software update [message #54787 is a reply to message #54469] Mon, 12 December 2005 18:18 Go to previous messageGo to next message
Originally posted by: jeff_nospam_mcaffer.ca.ibm.com
the update can go pretty deep. The Eclipse Update Manager for example
allows you to lay down new versions of any bundle (including the framework
itself). In some cases the updates could be activated dynamicially (without
restarting). However, in general, the bundle being updated needs to be
first stopped, then updated, the restarted. When you update the bundle, any
bundles that depend on it must also be stopped and started.
So you see that, for exapml,e updating the runtime bundle would likely shut
down all/most of Eclipse. Note also that it requires all the bundles
involved to be clean (unregister listeners etc).
You can also update the so-called "root files" (eclipse.exe, config.ini,
startup.jar) if you use install handlers.
Jeff
"Stefan Liebig" <Stefan.Liebig@compeople.de> wrote in message
news:7e4625f46c3802a20f1249df62e21e87$1@www.eclipse.org...
> software
> triggered),
> possibilites
> platform
Re: Software update [message #54974 is a reply to message #54787] Thu, 15 December 2005 08:51 Go to previous messageGo to next message
Sounds pretty good. But how does the magic work that code which is
currently running (update service?) replaces itself (file locks,..)?
> Jeff
>>software
>>triggered),
>>possibilites
>>platform
Re: Software update [message #56540 is a reply to message #54974] Wed, 11 January 2006 18:55 Go to previous messageGo to next message
I am also interested in some of the underlying details, as one of my use
cases is running multiple processes on top of the same bundle store.
/djk
Re: Software update [message #57588 is a reply to message #54974] Mon, 23 January 2006 23:00 Go to previous message
Updating bundles is ok since you are actually laying down a completetly new
JAR beside the old one. Then you either restart the framework or recycle
the bundle.
Updating the root files is more complicated. Right now updating things like
eclipse.exe and startup.jar is harder because they are shared and typically
locked and do not have version numbers. We have been talking about a)
making stratup.jar into a versioned file (perhaps in the plugins dir) and b)
a way of updating eclipse.exe by putting a copy beside the old one and then
swapping on restart.
Jeff
news:dnrsdu$p3q$1@news.eclipse.org...
framework
(without
any
shut
> > Jeff
> >>software
> >>triggered),
> >>possibilites
> >>platform
Previous Topic:howto launch osgi to use org.eclipse.core.runtime
Next Topic:Alternatives for deprecated IPluginDescriptor::getPluginClassLoader
Current Time: Tue Nov 04 23:47:55 EST 2025
Powered by FUDForum. Page generated in 0.03955 seconds
