Home » Eclipse Projects » Nebula » What's with Nebula?
What's with Nebula? [message #54465] Wed, 11 June 2008 15:42 Go to next message
I went through the list of Projects the other day and noticed, Nebula
got a "strike-through" Incubator Icon next to it.
Normally most such projects have been withdrawn or stopped.
And only those with a Check Mark sign instead of the Incubator Egg
successfully evolved.
Can you explain what this means?
Or please fix the icon if it should be wrong.
Werner
Re: What's with Nebula? [message #54492 is a reply to message #54465] Thu, 12 June 2008 13:15 Go to previous message
It means that the project is not fully compliant with the incubator status.
AFAIK, this is only because some widget doen't provide an IP log.
Each widget is evolving separately with their own developpers, so it's
hard to get a fully conforming project.
Nicolas
Werner Keil a écrit :
> Werner
Re: What's with Nebula? [message #590452 is a reply to message #54465] Thu, 12 June 2008 13:15 Go to previous message
Nicolas
> Werner
Previous Topic:What's with Nebula?
Next Topic:GalleryTreeViewer and model access through content and label provider --- strange
Current Time: Fri Nov 21 13:53:34 EST 2025
Powered by FUDForum. Page generated in 0.03497 seconds
