| What's with Nebula? [message #54465] |
Wed, 11 June 2008 15:42  |
I went through the list of Projects the other day and noticed, Nebula
got a "strike-through" Incubator Icon next to it.
Normally most such projects have been withdrawn or stopped.
And only those with a Check Mark sign instead of the Incubator Egg
successfully evolved.
Can you explain what this means?
Or please fix the icon if it should be wrong.
Werner
| Re: What's with Nebula? [message #54492 is a reply to message #54465] |
Thu, 12 June 2008 13:15  |
It means that the project is not fully compliant with the incubator status.
AFAIK, this is only because some widget doen't provide an IP log.
Each widget is evolving separately with their own developpers, so it's
hard to get a fully conforming project.
Nicolas
Werner Keil a écrit :
> Werner
| Re: What's with Nebula? [message #590452 is a reply to message #54465] |
Nicolas
> Werner
FUDForum. Page generated in 0.04271 seconds
