Home » Eclipse Projects » Eclipse Platform » Accesing version info....
Accesing version info.... [message #54453] Thu, 29 May 2003 13:25 Go to next message
Originally posted by: jmordax.terra.es
I have several projects under SCM control (CVS or CC LT).
Now, I am developing an Eclipse Plugin where I need to know the version
(or more generic, the tag) of a specific file within the workspace. I
mean, for example, to know that I have loaded version 1.1 of class
Test.java
- Is there a generic API within Eclipse to know this? I have been
reviewing SCM API and it seems it has nothing about this.
- Do I have to interact directly with the specific SCM Provider plugin?
If that is the case, does CVS plugin publish and document that API? And
Clear Case (I know this is not included by default with Eclipse.... but
just in case anybody knows.....). Should I use the Resource API? Or.....
I have to access SCM Providers external tools like DLLs or EXEs (like it
seems is the solution with Clear Case)?
Thanks in advance,
Chemi.
Port [message #56444 is a reply to message #54453] Sat, 31 May 2003 04:47 Go to previous messageGo to next message
Someone to inetesting port eclipse to c#? I think that is interesting?
Re: Port [message #58628 is a reply to message #56444] Mon, 02 June 2003 04:25 Go to previous message
What, do you think, are the advantages? Or is it just that creating
such a large C# program is a good opportunity to really learn C#?
bye
Stefan Matthias Aust
www.3plus4software.de // Inter Deum Et Diabolum Semper Musica Est
Previous Topic:Last recently used files implementation
Next Topic:Port eclipse to c#
Current Time: Sat Nov 08 21:32:12 EST 2025
Powered by FUDForum. Page generated in 0.03493 seconds
