Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Teneo: HibernateException when trying to save HibernateResource
Teneo: HibernateException when trying to save HibernateResource [message #54446] Fri, 29 September 2006 05:50 Go to next message
--------------090207060603010507090305
I have two HibernateResources with the contents of each Resource being
build by a query.
When i set a Reference from an object contained in Resource A to an
object contained in Resource B, trying to save Resource A results in an
HibernateException with the message "Illegal attempt to associate a
collection with two open sessions".
Am I missing some option or is this a bug or a not supported feature ?
I've attached the full stack trace and an class diagram showing my test
model. The classes named First* are contained in Resource A while the
classes named Second* are contained in Resource B.
If it would be helpful, I can also supply my test-plugin containing the
EMF model and a junit test case as well.
greetings,
Hans
name="exception.log"
Content-Disposition: inline;
filename="exception.log"
org.eclipse.emf.teneo.hibernate.HbStoreException: Exception when saving resource test
at org.eclipse.emf.teneo.hibernate.resource.HibernateResource.s aveResource(HibernateResource.java:214)
at org.eclipse.emf.teneo.resource.StoreResource.save(StoreResou rce.java:271)
at de.arcsolutions.remarc.platform.emftest.TwoResourcesLinkTest Case.testTwoResources(TwoResourcesLinkTestCase.java:77)
at junit.framework.TestCase.runTest(TestCase.java:154)
at junit.framework.TestCase.runBare(TestCase.java:127)
at junit.framework.TestResult$1.protect(TestResult.java:106)
at junit.framework.TestResult.runProtected(TestResult.java:124)
at junit.framework.TestResult.run(TestResult.java:109)
at junit.framework.TestCase.run(TestCase.java:118)
at junit.framework.TestSuite.runTest(TestSuite.java:208)
at junit.framework.TestSuite.run(TestSuite.java:203)
at org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestRefer ence.run(JUnit3TestReference.java:128)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:460)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
at org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunne r.main(RemotePluginTestRunner.java:58)
at org.eclipse.pde.internal.junit.runtime.CoreTestApplication.r un(CoreTestApplication.java:24)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Caused by: org.hibernate.HibernateException: Illegal attempt to associate a collection with two open sessions
at org.hibernate.collection.AbstractPersistentCollection.setCur rentSession(AbstractPersistentCollection.java:410)
at org.hibernate.event.def.OnUpdateVisitor.processCollection(On UpdateVisitor.java:40)
at org.hibernate.event.def.AbstractVisitor.processValue(Abstrac tVisitor.java:101)
at org.hibernate.event.def.AbstractVisitor.processValue(Abstrac tVisitor.java:61)
at org.hibernate.event.def.AbstractVisitor.processEntityPropert yValues(AbstractVisitor.java:55)
at org.hibernate.event.def.AbstractVisitor.process(AbstractVisi tor.java:123)
at org.hibernate.event.def.DefaultSaveOrUpdateEventListener.per formUpdate(DefaultSaveOrUpdateEventListener.java:267)
at org.hibernate.event.def.DefaultSaveOrUpdateEventListener.ent ityIsDetached(DefaultSaveOrUpdateEventListener.java:216)
at org.hibernate.event.def.DefaultSaveOrUpdateEventListener.per formSaveOrUpdate(DefaultSaveOrUpdateEventListener.java:93)
at org.hibernate.event.def.DefaultSaveOrUpdateEventListener.onS aveOrUpdate(DefaultSaveOrUpdateEventListener.java:70)
at org.hibernate.impl.SessionImpl.fireSaveOrUpdate(SessionImpl. java:502)
at org.hibernate.impl.SessionImpl.saveOrUpdate(SessionImpl.java :494)
at org.hibernate.engine.CascadingAction$1.cascade(CascadingActi on.java:134)
at org.hibernate.engine.Cascade.cascadeToOne(Cascade.java:213)
at org.hibernate.engine.Cascade.cascadeAssociation(Cascade.java :157)
at org.hibernate.engine.Cascade.cascadeProperty(Cascade.java:10 8)
at org.hibernate.engine.Cascade.cascade(Cascade.java:248)
at org.hibernate.engine.Cascade.cascade(Cascade.java:223)
at org.hibernate.event.def.DefaultSaveOrUpdateEventListener.cas cadeOnUpdate(DefaultSaveOrUpdateEventListener.java:331)
at org.hibernate.event.def.DefaultSaveOrUpdateEventListener.per formUpdate(DefaultSaveOrUpdateEventListener.java:303)
at org.hibernate.event.def.AbstractFlushingEventListener.cascad eOnFlush(AbstractFlushingEventListener.java:130)
at org.hibernate.event.def.AbstractFlushingEventListener.prepar eEntityFlushes(AbstractFlushingEventListener.java:121)
at org.hibernate.event.def.AbstractFlushingEventListener.flushE verythingToExecutions(AbstractFlushingEventListener.java:65)
at org.hibernate.event.def.DefaultFlushEventListener.onFlush(De faultFlushEventListener.java:26)
at org.hibernate.impl.SessionImpl.flush(SessionImpl.java:985)
at org.eclipse.emf.teneo.hibernate.resource.HibernateResource.s aveResource(HibernateResource.java:210)
... 34 more
Content-Type: image/jpeg;
name="TestModell.jpg"
filename="TestModell.jpg"
/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAYEBQYFBAYGBQYHBwYIChAKCgkJ ChQODwwQFxQY
GBcUFhYaHSUfGhsjHBYWICwgIyYnKSopGR8tMC0oMCUoKSj/2wBDAQcHBwoI ChMKChMoGhYa
KCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgo KCgoKCj/wAAR
CAEDAtUDASIAAhEBAxEB/8QAHAABAAMBAQEBAQAAAAAAAAAAAAUGBwMECAIB /8QATBAAAQQB
AwAFBwkFBgIKAwEAAQACAwQFBhESBxMUIVQVFhciMZPRMkFRVVaSltPUIzdh dbMkM0KBkZQ2
dAg0Q1JicZWhsdIlRaKk/8QAGAEBAQEBAQAAAAAAAAAAAAAAAAECAwT/xAAs EQEAAQIDBwME
AwEAAAAAAAAAAQJRERKRAxMUIqHh8CFBUgQyYdExccGB/9oADAMBAAIRAxEA PwD6pREQEREB
ERAREQEREBERAREQEREBERAREQEREBERAREQEREBERAREQEREBERAREQEREB ERAREQEREBER
AREQEREBERAREQEREBERAREQEREBERAREQEREBERAREQEREBERAREQEREBER AREQEREBERAR
EQEREBERAREQEREBERAREQEREBERAREQEREBERAREQEREBERAREQEREBERAR EQEREBERAREQ
EREBERAREQEREBERAREQEREBERAREQEREBERAREQEREBERAREQEREBERAREQ EREBERAREQER
EBERAREQEREBEUfqOzLT09lLVd3CeCrLJG7YHZzWEg7H+IUmcIxSZwjFIIs4 7fnfrq17mD8t
O35366te5g/LXHiItLz8TFp6fto6LOO35366te5g/LTt+d+urXuYPy04iLSc TFp6fto6LOO3
5366te5g/LTt+d+urXuYPy04iLScTFp6fto6LOO35366te5g/LTt+d+urXuY Py04iLScTFp6
fto6LOO35366te5g/LTt+d+urXuYPy04iLScTFp6fto6LOO35366te5g/LTt +d+urXuYPy04
iLScTFp6fto6LOO35366te5g/LTt+d+urXuYPy04iLScTFp6fto6LOO35366 te5g/LXp0Vqe
/Z1PkcJk5DZETGSRTlrWvG7dy1waACPoO2//AJ792qdtFU4YNUbeK5y4SvyK PzeYpYWqyxff
KGveI444YXzyyv2J4sjjDnvOwc4hoOzWuJ7gSIqbXOn4Y4JHXZTHKwyPcyrM 8VWBzml1ghh7
OA5kjSZeGxjkB24O26u6yoqLqPpOweIw2auQtvWZscyyGxmjZjjsTQcw+KOY xcHEFj9y0u4t
Y959VjiJpusMMb9emZ7LJZurHKSlOyOJ8gBZFLIWBsUruTNo5C1+72Dju5u4 WBFUMD0hYPLN
pMbPKJ52V+ckdSyajJJoo5I4+0uiazdwlj4h3FxL2jiHENTA9IWDyzaTGzyi edlfnJHUsmoy
SaKOSOPtLoms3cJY+IdxcS9o4hxDUFvRUDUfSngsdjpZMdarWro6p7Irb5Kk LoH2IYO09c6M
jqN52kStDmvDXcS7i7Zh+kerYmgF+TCPryQ2ZjZw+UORjDon1WNiG0TS6V7r QAY0E7hoHIvA
AX9FUL/STpXHVWz38lLWLmTSdRLTnbO0QhjpOUJZ1jS1krJCC0Hqzz24AuHq drfBirHM2W9J
I97o+yRY6y+2wtDS7nXbGZWAB8Z3cwDaSM7+u3cLKiqr+kDTjbM0UduzO2Lg HWK9CxNXLnxs
kja2ZjDG5z2yR8WhxLi9jWgucAZDROfZqnSOHzsdeWq3IVWWOpka4GMuG5bu 5rS4A77O2AcN
nDuIQTSIiAiIgIiICIiAiIgIiICIiAiIgIihc3qjEYS0yvkbErJCwSyGOvLK yvGSQJJnsaWw
x+q715C1vqPO/qu2CaRVCpr/ABBge7ImWrIy1ahkEcMs7II4bMsAmmexhbDG 7qXO5SFrRxf3
ng4hJ0k6VZkZKXlKV80T545nR053xwGGTq5utkDCyMMJaXF5Aa17HEhrmkhb 0Vau650/SkvN
tXZYo6bJnyzmrN1Dupa50rI5eHCSRoZJvGxznDq393qO2j7HSLim5fB46tXy UljJXeyOjmx1
qCSu0xSPbI5j4geLnR8QTsCBI4HaKTYLqiquL1RavQxZd+PrQaTnhNiHJSXg 2RsPAvE0sTmg
RxOaNwQ9zwHM5Mb6/BJr/ARQsfJJkmSvmbXZVdibYsuc5j3tIg6rrS0tilIf x4nq3jfdp2C1
IqVS6R8NazeUpt7S2rRpV7RtOqzgPfJLJEYA0xj9qHsawMBL3PL4w3nG8Dta 6QsHXdA+SeVs
D2Sc43VLItskEteNsfZuq5guNqLuOztnsLWua4uaFvRVp2t8GKsczZb0kj3u j7JFjrL7bC0N
LuddsZlYAHxndzANpIzv67d/Xh9VYTM5Ozj8TkIrlmuxkkvUBz2MY9jJGOLw OOz2yNLTv62z
+O/B/EJpERAREQEREBERAREQEREBERAREQEREBERAREQEREBERAREQEREBER AREQFE6v/wCE
83/yM/8ATcpZROr/APhPN/8AIz/03LNf2yxtPsn+kL2P+CjrGPbNqClE+jTu A1Z3dXaOzRs+
Ebj1Xd/f9HzlXTsf8FBZ/BWLWSo2oKGOvRwwzRvhuyFgBe6Mhw/Zv7xwI9g9 q8+12OanBNlR
kqxRE2NZX1BSYzG0KPOrOf7Id+ez4fleo32b93t9pWe9K0xqdIGgaVizl4sX c7f2qDGPsiSb
hEws9Wv67tnd/d7Bv8261TFYC1FnIrkmLxOPhjrSxEUpS90jnOjI3/ZM7gGH 6fauuY0ZSyuq
dP56xLZbcwnaOzsjc0Rv65gY7mCCTsB3bEd/0psdllhraU5qsWX2bNWrrPo7 oUHZ9ta95R4N
s2p4uXCPkevinaZJO/fhyLePcRuNgoat0s2H6b09mreBp0qWdsPr1rE+ReII CwvaevkEB6sl
zRx2DgRyLi0MO+05jRlLK6p0/nrEtltzCdo7OyNzRG/rmBjuYIJOwHdsR3/S oGj0UY7H6QxW
ncfls1Wp4/r2te2WJ/aGTF5kjmjfGYZWnmduUZI2GxHfv1yQ57uPdn+Mz+a1 T0gUMBeoR4/D
28AMpJHWyR67cyta17Z4PaOTdmhjgHMeXOO56sefo66qlj9d57LXM1cj09mc jFEx+SsShteF
gIZ1b5ODyAXbF3fvsd+4Eabpfopwel7+FuYR92vLjaD8cd5Q8WoXvMpEvJp7 +sLn7s4d52+T
s0e/EdHuJxuM1Jj/AO02qeoLlm5djnkHtnaGyMaWhpDdh3d+439quQ3bIKXT HXmx2RnOHjtW
K2GZmWQ4u8LezS8MdFMeDTE9hc1zhs7i3kfmAPPL9Iubt43BWcBQw5gv5ypj u1w5IWIphK1s
nVj9mHxO23a/rIw5gILWuLt2apjejGCjiJcd5x6mlh7BHjqzheEBpxx/JdEI Wsbz7m+u8OJD
eJJaXA+AdC+C/ts77eRdlrWSgyzskDDHKyxDv1bmsZGIf8Um+8Z5GRxO52IZ IXdxZT9J46fX
dzWlnLZPLVnUsvYw9RmOvS1WV44QNpA1jgHSEvJJfyG4AAAGy/mnr+Qoa66S obFufIQ4qHG9
U25abFFHyrkySOOwZG3/ABvLW+wEhpOzTot3o3ruvZaxhs3msC3LetdgxkkL Y5JSCHTND43m
ORwI3cwtJLQT3jdeW90RYC/DqmK3JkZYtRQ1YbIfZLnR9mZxicx5BcXDYOJe X8iO/cEgsibt
mnpkrNwmWuvwsjn0LFOJ8kb5uzCGy3kyd73QtlawAH/sjuSzjy5gjrkOld9K ajXlw2Pjktw2
ZoLc2ZjbQtdU8tDYLTWOa5ztj3SCLidge9w30at0V14LuYyDdR6i8rZSarPN eZPDFI11cFrA
GxxNjc0tcWuY9rmkbd2/eotvQZgosJaxVTJ5qrTu9cbsUckJitGRzXcjC6Iw xubwaGuiYwtA
Hf3BN3BuqbLPVrumrRSyV5K73sDnQyFpdGSO9ruJLdx7DsSPoJVf0mzq+lzK t+iCP+mr9i8J
WxWMp4+hF1VOpCyvDHyLuDGNDWjckk7ADvJ3WbW8vX0z0lamyl2K1LXp1I5H sqwulkcOrHyW
jvPt9vsHtJABKzFGFUMxRlqifP4aNqfDT5VuOnoW4qmRxtrtdWSaEzRczFJC 4PYHMLhwmfts
5uzuJ7wC01/MaIyOTjutmzsTnZfHjGZd76O5khDpjtX4vaISBYlaC8S9wj35 Fri/5w11/wBK
LUV3INZpGlDiaMTw7lZYJppgD7HA+q0Ebbgbn6HLTein/pEVdUGGjqHB5Cpk Xg8ZsdVltwzF
o3OzGB0jT3ju2d/EhdnoX3UHR15X0qcN5U6ne7lLnXdn5f8AXGXGcePIfI7Z vvv63V+wcu7j
mujd+az9PL38jRfbhtUrrpjjGumbJA+Iuihke9zoa7+rc7q2+sHyOcXuBcx0 35+YjwepPw5k
fyE8/MR4PUn4cyP5CCK0/wBHXkjSow3lTrtruLudd2fj/wBTZTZx48j8vse+ +/q9Z7Dx72n+
jryRpUYbyp1213F3Ou7Px/6mymzjx5H5fY999/V6z2Hj3yvn5iPB6k/DmR/I Tz8xHg9SfhzI
/kIM/wAXofUeTkxkEjrOIpYKlHUx3lKtXk2bFapzxcmwWHmR21QtkcXxA7s4 MHrq16g0He1Q
yF2pspjbUsEMsTGQ4xzIH7z1J2CWN8z+bQ+ps5vIc2yEAtI3Mr5+YjwepPw5 kfyE8/MR4PUn
4cyP5CCv+i6PyVdqx28bSdcxmRx72Y3FMq12OtNrt6xkbXb+qK4JDnOLi4+s 1oa0ddR9GcGX
zlzLOfiLVma1JMyDL4sXa8bHwVYnDq+sYTJvUYQ/kNg97eJ3BE35+YjwepPw 5kfyE8/MR4PU
n4cyP5CDyVdBx1cVboQX9opsnj8gw9mYzg2o2o0R8WcW+t2T2ta0N59zdm7G b0Thp9O6Rw+F
tW4rkmOqsqCeOEwh7GDiw8C52x4gb9/edz3b7CP8/MR4PUn4cyP5CefmI8Hq T8OZH8hBakVV
8/MR4PUn4cyP5CefmI8HqT8OZH8hBakVV8/MR4PUn4cyP5CefmI8HqT8OZH8 hBakVV8/MR4P
Un4cyP5CefmI8HqT8OZH8hBakVV8/MR4PUn4cyP5CefmI8HqT8OZH8hBakVV 8/MR4PUn4cyP
5CefmI8HqT8OZH8hBakVV8/MR4PUn4cyP5CefmI8HqT8OZH8hBakVV8/MR4P Un4cyP5CefmI
8HqT8OZH8hBakVV8/MR4PUn4cyP5CefmI8HqT8OZH8hBalRdZ9HlTUufGUkZ iHySVY6cxyOK
jvPjjY+RwdXLyGxSftX7lzZGnZm7fVIdIefmI8HqT8OZH8hPPzEeD1J+HMj+ QgrV7olqWr0t
mSTEWpLD5xM/I4eO2+KOS3YsDs/N3GOQdpe0uc2RruDCWDYtMhkOjrteOvVf KnDtVLN0+XZ9
+PlGw2blty7+r48dv8W++7fYpXz8xHg9SfhzI/kJ5+YjwepPw5kfyEFayHRL UtSZ0QyYiu3J
MvltsYeN19sltsof1lgu3fG0zP2a1rHbNY0vIDudgzWj572t6Oo6uSigkrPq kwSVjIHsiZdY
8bh7di5t07Hv4lgOzt9h18/MR4PUn4cyP5CefmI8HqT8OZH8hB5HaKtSYSxp t+Z4aTdSkoQ1
IaoFlkL4jGI3Tuc4OaxrvV2ja/1I+T37P5q+jb02pqOoM1lq1jJVpo3EVKTo IXxRwW42M4ul
eQ7ldkcXciCGtAaO9x9fn5iPB6k/DmR/ITz8xHg9SfhzI/kIIRnRxPHLnA3M RGtlGO5wupk+
v2+xba1/7TZ8JFl8Ukew6xu/rM3IUfi+iGPH3GTw5OtE0XRdMFXGsrwtd12P lLGMY4Brd8eQ
PadpQXF7mlz7X5+YjwepPw5kfyE8/MR4PUn4cyP5CCE1H0ZwZfOXMs5+ItWZ rUkzIMvixdrx
sfBVicOr6xhMm9RhD+Q2D3t4ncEWXSGmo9NR5GKCx10VqaKVg6lkXVtjqwVw 3ZgDf+w5eq1o
HLYNAC8vn5iPB6k/DmR/ITz8xHg9SfhzI/kILUiyHKatrzxu0zOzMWI7T4pK di9ibVcljZ4+
ccpljaDsHDZ/zggO9bYv9HkCh4Gr7pvwXGvazTVhEPPtNtNFWWIxasiyGTFY 1k5hGNbJI1oe
4Q0nSbAkgb8WnbfY/wCi/sOJxs0r4hjo2SMAc5ktQxnY77HZzRuPVP8AouXE +uGEY/2m92mG
bJ6efhrqLE8tLpTD2W18vbwVCdzBI2O1LFE4tJI5AOIO24I3/gV6a1bT9qzF XqnFTTy1xbjj
jMbnPhJ2EoA7ywnu5exb31Xx69k4iv49ezY0WU+QKHgavum/BebI4/C4ynJb yUeOqVI9uc04
ZGxu5AG7jsBuSB/mpv6vj17JxFXx69mvosXw7dM5rrvI02GyHU7dZ2R8UvDf fblx3232O2/0
FSXkCh4Gr7pvwTfVfHr2OIq+PXs1ZFjmJrafzFZ1jEHFX4GvMbpKpjlaHAA8 SW7jfYg7fxC9
vkCh4Gr7pvwTf1fHr2OIq+PXs1ZFlPkCh4Gr7pvwTyBQ8DV9034Jv6vj17HE VfHr2asiynyB
Q8DV9034J5AoeBq+6b8E39Xx69jiKvj17NWRZB5PwvlHyf1eO7f1XX9m2Z1v V78efH28d+7f
2brxV5dKWcqcZXt4KXJB7ozUZLE6YObvybwB33Gx3G3dsVd9V8evZeIr+PXs 2xFkGOx+FydO
O3jY8dbqSb8JoAyRjtiQdnDcHYgj/JenyBQ8DV9034Kb+r49eycRV8evZqyL KfIFDwNX3Tfg
nkCh4Gr7pvwTf1fHr2OIq+PXs1ZFQehjI2rulnRW5XSivIY4y87kN3Ozd/oG 3d9A7vZsr8vR
TOMYvVTOaIkREVUREQEREBERAREQF58jUjyGPtU5i4RWInQvLTsQHAg7fx71 6ESYx9EmMfSW
dWcZ0iRzvbDn6ssQPqv7LE3kPp227lz8n9JH11V/28XwWkos5I8mWckfnWWb eT+kj66q/wC3
i+CeT+kj66q/7eL4LSUTJHkyZI/Oss28n9JH11V/28XwTyf0kfXVX/bxfBaS iZI8mTJH51lm
3k/pI+uqv+3i+CeT+kj66q/7eL4LSUTJHkyZI/Oss28n9JH11V/28XwTyf0k fXVX/bxfBaSi
ZI8mTJH51lm3k/pI+uqv+3i+CeT+kj66q/7eL4LSUTJHkyZI/Oss28n9JH11 V/28XwTyf0kf
XVX/AG8XwWkomSPJkyR+dZZt5P6SPrqr/t4vgu2kNM56nq6fM52eGzLPGGPk YGt9jdh3Du9m
w7loaJFMR6rFEROLOtb9DWjNYXWXb+NFW+JBI+xTDWOl79yHtLS12/zkjf8A irZpfS+F0tS7
LgsfDUj2Ac5o3e/buHJ53c7b5tz3KD6Tuw9Xpzy92bze8pnyn23j2Xquy2OH X8vU49d1O3Lu
58Nu/ZOj7JUaGkG9qu1q1Rs2Rs1eslaxgx8duTq5I9zt1DYnQ8XD1AxzNu4h aaXVFStPUux9
KeqibNmw+fGY6Zzp5OXHee8AxoGwa1rQ0AADfbkd3Oc43VAREQEREBERAREQ EREBERAREQER
EBERAREQEREBERAREQEREBERAREQEREBEVaoaXNTXuT1N26V7r1VlR1Yul4M ZHsWEAyFm+5l
J2YPljjxPWOlDyZnDilh57FmY28nat1BPZc3juBYj4sY3c8WN3Ozdz7SSSSS fT2P+CkNVDfF
xD6btMf/AOmNSPZ2rlNONXn5caqM1c/1H+qOHCrqS6w2L8G9Suf7LWM2/rze 31Hbf+3z+1f2
iBb1Ff2mtzcatf1rUHVOG75u4Dg3u/jt9PerFdwBnyT7tbKXqUskTIXtgbEW uDC8tPrsd3+u
72L94zBdiuWbU1+3dnnjjiLrAjHFrC8gAMY0e17vbuuMbCc+LtPrRlYvmI8n F/0imtw1Onbs
eaoLmW7Tq7Q3tZ3Ic2OQk77d23znv7tj5NZZXJ4zpAzhYynWu1dBz5AOjhjl dFO2V3cJXMD3
MBHyTs07bloK3vyNQ8qeUux1vKPU9n7V1Tet6rly6vntvx5d+2+2/euVrT2J uWprNvG0p7M1
Y05ZZYGue+AncxOJG5YSdy0938F6MjnkfNuW1Fq7H4PBZDy7ct0rGnxl7zqM dKS/Ue9rNpTW
cxvOq1x29XZw3kLn7NaFVdbTWMlhOlq8/NWMlWFTBvhcYxHE9kzmStLGEco2 jk7i3ffZ5583
esvrLI6N05k6tOtksFibdakzq6sU9OORkDdgOLAQQ0bNaNht7B9C65PSuDys 0suUw+Ouyywi
vI+zVZI58QeHiMlwO7Q8B23s3G/tTKsUYMFyN7JY7pM1bmMrVp0M1idHvlp0 45nWobcbZHyG
brOMZaGva1hYQCdyQdhuohmW1Rl9HZ2DL3rApW9GOyvKy+iLJm47uMUcXrCu 9pLd3s5DbYFr
l9N2MNQs3ql2xTrS3KnPs08kTXSQ8xs7g4jdu47jt7QvBjtG6cxlW5WxuCxN StdZ1dqKCnHG
yduxHF4AAcNnOGx39p+lMqZHzdBndTUcVp3BYS5cDIdEx5hs0QpsLZTs1pmf OAwQRgAers/Y
7ku7yLnhcvns10l4HGWMn2OpLpevmrFeg2CSKWczBrmiQteTGQdvVd7ACHfO deyOjdOZOrTr
ZLBYm3WpM6urFPTjkZA3YDiwEENGzWjYbewfQvf5GoeVPKXY63lHqez9q6pv W9Vy5dXz2348
u/bfbfvTIZIfO3RZqzVmoclpK7kJd8fm+39oisPpxxfs3OMfY2NcLDuPHi/m Hdx3/wDEOXRl
rDU+Rs9HD8xk470WpWZOOeI1WR8OzkljwWgHnuCCe5vHYceQLz9CUNK4PH5S xkqGHx1XI2eX
X2oKrGSy8ncncngbu3cATue8jdKmlcHS7B2PD46v5P6zsfVVWM7N1n951ew9 Tlud9tt/nTJB
kizBNLarzdjo6g1ne1LS7Zao5S1HhLNeIRyugMhYIOJbLswRjlyMm7SfYdnL npjVmrIMZev5
GXtMA0ic5G3IvpiU2Wt5co4q7g/s7gfa9u+7dt2nuO/0NK4PH5SxkqGHx1XI 2eXX2oKrGSy8
ncncngbu3cATue8jdMJpXB4HrvIeHx2N6/j1vY6rIes477cuIG+2523+kpkg yRZ8wYuzl8pq
i9ZjycmSzk3RwbDHVYwyxFPIWyNj2j29fk8FuzWni5ncT6ztQ6PK+mj0XaGd cOH6h0NXsvWm
Lj27j39Xv3ddz6z2ety5fPutPxmlcHipopcXh8dSlihNeN9aqyNzIi8vMYLQ Nml5LtvZud/a
uVbRunKuYOWrYLEw5UvfIbkdONsxc/fk7mBy3O53O/fufpSacSaMXzn0b5O7 V6Jej7E4W1Yj
y+XmuMrV64iYZBHO90j3zSskYyNjORIEbnuJYG7bO38kGvtX5DR+BzL73Gqc RZs5A4hlaS9E
+Od0TbMlabfnD6jd+r4AEyEuaA0L6Xm0bpyfDwYmbBYmTFQPMkVN9OMwxuO/ rNZtxB9Z3eB/
iP0rlY0LpazRqUrGnMLLTqc+zQSUYnRw8zu7g0t2bue87e0plhckWYLgdbZu fVWOlyedjlwm
SykdShcxlSKfH2GuiB6iVm/aK05LmEc3u2cXAt4NJO79j/gvb5q4Py55a8j4 7yx47srOv+Tw
/vNuXyfV9vs7vYpTs7VJoZnZxLC9KZjIaf0Y7K4ujfuyV7LuUMEkIikBdt1b xJI0kuOwYWBz
g75iCWuuOndYZzJ3r16XSOo3NikdVZTjmotEABB3kD7LXGR3qnvAAaRx3BLn eXoVoVrWH7TY
iEk1Ww90JcTsxx3Bdx9nLbcA7bgEgbbnfSW0Kzck7INiDbb4hC+RpI5sB3Ac PYdjvsT3jc7b
bnfVH2w1s/sj+lf86Mv9hNSe/wAd+qTzoy/2E1J7/HfqlakWm1V86Mv9hNSe /wAd+qTzoy/2
E1J7/HfqlakQVXzoy/2E1J7/AB36pdsRqiS7nYsTfwGWxFqatLahNx1Z7ZGR uja/YwzSbEGZ
nt2337vYrIqrkv3p6e/kuT/r0EFqREQEREBERAREQEREBERAREQEREBERARE QEREBERAREQE
REBERAREQEREBERAREQEREBERAREQEREBERAREQEREBERAREQEREBERAREQe fI0a2SozU70L
Zq0zeL2O+cf/ACD84I7we8LP3dEeGLjxtWw3fuBcSdv9VpCKTTE/zDM00z/M M29EWI8Xa+8f
inoixHi7X3j8VpKKZKbJu6LQzb0RYjxdr7x+KeiLEeLtfePxWkomSmxu6LQz b0RYjxdr7x+K
eiLEeLtfePxWkomSmxu6LQzb0RYjxdr7x+KeiLEeLtfePxWkomSmxu6LQzb0 RYjxdr7x+Kei
LEeLtfePxWkomSmxu6LQzb0RYjxdr7x+KeiLEeLtfePxWkomSmxu6LQzb0RY jxdr7x+KeiLE
eLtfePxWkomSmxu6LQzb0RYjxdr7x+KeiLEeLtfePxWkomSmxu6LQzb0RYjx dr7x+KeiLEeL
tfePxWkomSmxu6LQzb0RYjxdr7x+KeiLEeLtfePxWkomSmxu6LQgdI6ag0zU mrVZnyRSO5+u
O8Hv37/81PIi02IiICIiAqrkv3p6e/kuT/r0FalVcl+9PT38lyf9eggtSIiA iIgIiICIiAiI
gIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiI gIiICIiAiIgI
iICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgI iICquS/enp7+
S5P+vQVqVVyX709PfyXJ/wBeggtSIiAiIgIiICIiAiIgIiICIiAiIgIiICIi AiIgIiICIiAi
IgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAi IgIiICIiAiIg
IiICIiAiIgIiICIiAiIgIiICIiAiIgIiICquS/enp7+S5P8Ar0FalVcl+9PT 38lyf9eggtSI
iAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICI iAiIgIiICIiA
iIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiA iIgIiICIiAiI
gIiICquS/enp7+S5P+vQVqVVyX709PfyXJ/16CC1IiICIiAiIgIiICIiAiIg IiICIiAiIgIi
ICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIi ICIiAiIgIiIC
IiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgKq5L96env5Lk/6 9BWpVXJfvT09
/Jcn/XoILUiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIiA iIgIiICIiAiI
iICIiAiIgIiICIiAqrkv3p6e/kuT/r0FalVcl+9PT38lyf8AXoILUiIgIiIC IiAiIgIiICIi
AiIgIiICIiAiIgIiICIiAiKv611ZjdH4qK9ln7NmmFeFnWxRdZIWudtzleyN vqsed3OaDtsN
3EAhYEWYO6YMNG6a6+SJ2JfVqGrtLDG+SxJLcZLGZXyCDZopu2dzDXcTxc/k wH1elrDTQQSY
vG5fKGVld/8AY2QuY0zWZKrWmV0gjJE0ZZ3PIduHML2BzmhoqLOsx0waYxDq 7b8ksMjmPksx
yywRPqBkr4n8mvkBlLZIZmkQCUnq+4Hkzly1X0nuxmm83fpYHJc63bq9GxY6 gwWbNYS8xs2b
rA0CCZ5Lg3dsZA3cWNcGlIqgzM5/NXbrcDDRoNxb44bVbKRl8k8zoY5zEHxS FsQDZWNMm0u7
i7ZmzAZOOV6RcbjIb1q1QyXk2t2tkd1rYjHZmrMlfNDG3n1gcBBON3tawmM7 OO7eQXVFQLmv
7jNTafwzNOZKtbuXWxW4bRrl0MD4LD45A5k5b3uryHYFx4wybtBdHz4xdKuG vXpsfTdLBejt
V4hHKIZXvY+3DXcXRMm5wkGZgLZhG9vLfg4sewBoqKgQ9KeJbgostlMfksTU s0mX6RumuO1x
OdEwFrmSubH608APWmMDrASQGvLeuA6TsNn7WPq4qtetWrb5oyyv1M7IDEYC /rJY5HRbBliN
+7Xke1m/WbRkL0iquHymcZqpuKzTsbY6+k+6RQie3sGz2NZFI9zj1vPlJxfx i37PIQ32hlqQ
EREBERAREQEREBERARFH57KwYXGPu2WSyND44Y4ogC+WWR7Y4427kAFz3taC 4ho33JA3ICQR
VWTWLmdnrt07m35ebrXeTOMDJmxx9Xzk5ulELmjroRuyRx3fttu14bHxdJVC y2axjsRl7uLY
+vC3IRCBsUktiKGSCNrXytk3f2iFoJYGhz/WLWhzgF6RZhW6XKGP0jpjKaqq y0Z8pj47s7us
gijjaQOT2B8vKUe1wji6yQNLOTQ5zQ6Qj6SK8UmSbNjclZr43r5712CKGOGp Ay1Zh5Oa6YyP
2FWQng1xcG7hoLgwBf0VAf0t6Vizt/GWLfVdi7SJJ+sifu6u17pm9Sx5nbxE UvrOja08PVJ5
M5QmoukjMwaijxdTHy4lxfUjkbexU16eMyxX5HcY60u0oIqw7GNzg3k/kd2k NDWkWYO6TWYN
03nLLFLGKtR8DhSdi3zTTS3A5pZblAiAjqgjrHt32OxPNjV6vS1hpoIJMXjc vlDKyu/+xshc
xpmsyVWtMrpBGSJoyzueQ7cOYXsDnNDRUWdZjpg0xiHV235JYZHMfJZjllgi fUDJXxP5NfID
KWyQzNIgEpPV9wPJnLlqvpPdjNN5u/SwOS51u3V6Nix1Bgs2awl5jZs3WBoE EzyXBu7YyBu4
sa4NKRVVuta/nJXwj8XkmXXwxzTNPUudWDyAOUbZDI9oc5rXSxtfE0k7vHB/ Fh8pnGaqbis0
7G2OvpPukUInt7Bs9jWRSPc49bz5ScX8Yt+zyEN9oYFqREQEREBERAREQERE BERAREQEREBE
RAREQEREBERAREQEULhNUYjN2n18dYlfIGGWMyV5YmWIwQDJC97Q2aP1m+vG XN9dh39Zu/qz
OZx2FjqvyluKs21aipQB575ZpHBrGNA7yST/AJAEnYAkBIKq5L96env5Lk/6 9BWpVXJfvT09
/Jcn/XoILUiIgIiICidX92k80R4Kf+m5SyidX/8ACeb/AORn/puWa/tljafZ LP8AyBQ8DV90
34LjYxGNg6sPoQudI7gxsdXrHOOxPcGgn2An/JXXsf8ABRWaZ2W5h3mSeLe2 4c4IuseP2Evs
bxdv/oV4q9nhTjEPLR9PTNWEwrgxmN62ON+M6p0h4sMtB8YJ2J23c0DfYE/5 JkcfhcZTkt5K
PHVKke3OacMjY3cgDdx2A3JA/wA1YMhKLGRw0YtZKblad6tqoYm/3EveD1be /wDhv9Pcq/0u
aZjzeAx8UeZr4bLwZGGziZ7DmCOS43l1cZDgeXLd3cATv37O2LTNls833Q1t PpqImIphzxNb
T+YrOsYg4q/A15jdJVMcrQ4AHiS3cb7EHb+IXt8gUPA1fdN+CzfK61y+G0d0 iWLWHxeM1zhH
1YrlupGHw2WzPDYJQSeRLY3Ehr99vV3HeWDrntWas07pLpCsTy/tsV2LsBvv pyXIevLWP66O
s4sbsTyZyaN9+/kO4ddxFmOGizQ/IFDwNX3TfgnkCh4Gr7pvwVU1lk8vpyWl iaerYsjYv6gx
+Okc6vX7bjop2uLg7iOrJdw3aXRDYOd8ruIgptYan8kw16+TjF2HXh032uaq x5mr95HWsaGt
J7wCWcCQ0bEHcpuIOGizSPIFDwNX3TfgoW3d0dT5dryOn4OMr4D1s8LdpGbc 2d5+U3k3ce0b
jf2qreeOofI3Yu3/ANp8+vNjyh1EfX9m5b89uPV9Zt6u/Dbb/Dv3rz6LHaui PpfsizXt8sjm
H9orDaKXeu082Dk71T7R6x7iO8+1NxFjhqfeF5w7dM5rrvI02GyHU7dZ2R8U vDffblx3232O
2/0FSXkCh4Gr7pvwVKymZyen+h/o18imRtjKvxWOe6FkbpgySEFwi6z9mHnj xBfu3vO+3tEZ
LqPW4o1oe0xTSQ5q7Xnr07VB+XmqRMDwGxjnC6WMOdzja0P9WMADkXJuIOGi zSPIFDwNX3Tf
gomvLpSzlTjK9vBS5IPdGajJYnTBzd+TeAO+42O427tisxoZLLak1BNexmoc pk55NCW7VbqK
orOdP1roS1sTeRa/nG0ksduXsHF3Diwaj0eV9NHou0M64cP1DoavZetMXHt3 Hv6vfu67n1ns
9bly+fdNxEexw9Mez1Y7H4XJ047eNjx1upJvwmgDJGO2JB2cNwdiCP8AJeny BQ8DV9034LKu
jfJ3avRL0fYnC2rEeXy81xlavXETDII53uke+aVkjGRsZyJAjc9xLA3bZ2/k g19q/IaPwOZf
e41TiLNnIHEMrSXonxzuibZkrTb84fUbv1fAAmQlzQGhNxBw0WbB5AoeBq+6 b8E8gUPA1fdN
+CzfA62zc+qsdLk87HLhMllI6lC5jKkU+PsNdED1ErN+0VpyXMI5vds4uBbw aSd37H/BSdjE
eyT9PEeypdHtmalr3K4qB3Cg6OOTqANmNdw35NHzE/P9Pz+wK/6hwseahq/2 qzSt1Ju0Vbdb
gZIJODoyQHtcw7skkbs5pGziRsQCMuF61hekHUdyhi7GVtV6kb46VdzWyTHq x3AuO3z7/Odg
dgTsD889JHTt0hZTMugEs+mYq0u4pVgY5GuB7hI8jk49+xHc0/8AdXo2UYU4 PVsYwoiH17No
OpJabeGVy7csxkIjyBljkljfGbO8gD2Fm7hcnaWlpY1rgGNZxbt1OiKL5Hy2 L2SsWJOwmWaa
ZrnPdVtPtMcfV2HKSRwLQA0N2awMACx3oT6ZtaahLaGc0lczJY3vvY5scTx3 bjrWSObGN9+4
8mA/MCti86Mv9hNSe/x36pdHVyj0HUr2JpcflcvRdafKbnZpY2m0ySxNP1Zc WF0Ya6xMGuiL
HgP+US1pDMdH+KyuAOIsWLzaxtX7fKN7A/nbZZbINy0jYC3Jx7u7Zu++x36+ dGX+wmpPf479
UnnRl/sJqT3+O/VIOtnSYmkEkOay9SSZjGX3VXxRnIcWhvOQiP1JC0cTJD1b tuI39SPjH5Xo
6xuThvVbV/JeTbPa3x0muiEdaayyVk00buHWFxE852e5zAZDs0bN4+vzoy/2 E1J7/Hfqk86M
v9hNSe/x36pB1y2j6mR1RUz/AG29WvVn13tEJj4OELbLQ0hzD3ObclDtiD8n iWkbmKi6MsVH
Yx8jsjl5I8cyKClA+dnV14I7FeeOJreHeGuqsbzO8jmkhz3bMLZDzoy/2E1J 7/Hfqk86Mv8A
YTUnv8d+qQcn9H+KdjMHS7ReDcNj24+nKHs5t4vryMlPq7GRr6kThuOJ7w5r gdl78XpiOlla
uTsZPJZHIQQ2IDNbkYebZnQk+qxrWt27PGAGBo+USC5xcvL50Zf7Cak9/jv1 SedGX+wmpPf4
79Ug66V0tLp61bmOoMvkm2nvmljutretK4j9oXRwseSA0MALi1rQGgANaBZV VfOjL/YTUnv8
d+qTzoy/2E1J7/HfqkFqRVXzoy/2E1J7/Hfqk86Mv9hNSe/x36pBakVV86Mv 9hNSe/x36pPO
jL/YTUnv8d+qQWpFVfOjL/YTUnv8d+qTzoy/2E1J7/HfqkFqRVXzoy/2E1J7 /Hfqk86Mv9hN
Se/x36pBakVV86Mv9hNSe/x36pPOjL/YTUnv8d+qQWpR+exUGaxj6Vl8sbS+ OaOWIgPilje2
SORu4IJa9jXAOBadtiCNwYXzoy/2E1J7/Hfqk86Mv9hNSe/x36pAk0c5/Z7D dRZtmXh61vlP
lA+Z0cnV84+DojC1p6mE7Mjad2b77ueXKWhMPRxUuNpdpgpPu0rrYxIHdW6o 2s2JjS4E8dqk
e+5JO7u8bjZ50Zf7Cak9/jv1SedGX+wmpPf479UgipOi3GyabZhDmM22ocY3 ETvjmiZJZrMD
+pY9zYxt1fWP248eYO0nWDcKQb0f4oUtSVRYvdXnqs1SyebN2MlmtTOLPV7j yuSgb79zWe3Y
k9fOjL/YTUnv8d+qTzoy/wBhNSe/x36pAfoijL2+tYvZKXC3e0mTE9c1lcOs c+udyY0Su5GW
U8XSOaC/doBazjHzdHMUuTblXak1B5Za+GTtxfXc/eJlmNuzHQmJo4WpAQ1g B2DtuRc50h50
Zf7Cak9/jv1SedGX+wmpPf479Ug5TaFintNvz5vLyZmNkLIskRXEsZjNnZwY IhESWW5ozuwj
jsQA4cl1OiKL5Hy2L2SsWJOwmWaaZrnPdVtPtMcfV2HKSRwLQA0N2awMACed GX+wmpPf479U
nnRl/sJqT3+O/VIOUeg6lexNLj8rl6LrT5Tc7NLG02mSWJp+rLiwujDXWJg1 0RY8B/yiWtIZ
jo/xWVwBxFixebWNq/b5RvYH87bLLZBuWkbAW5OPd3bN332O/Xzoy/2E1J7/ AB36pPOjL/YT
Unv8d+qQdZdJifJ0LlrNZew2q+OcwSPi4STsZw63cRh8ZI+UyJzI3buBYQ94 c0rpaXT1q3Md
QZfJNtPfNLHdbW9aVxH7QujhY8kBoYAXFrWgNAAa0Dl50Zf7Cak9/jv1SedG X+wmpPf479Ug
9OvmNl0xPG8BzXz12kEbggzxghUryBQ8DV9034Lzz5vIwZFunTp3MVMbNJXs M7XLVf2EdpjA
aTFM89W47hgI3BBA3aP2d37H/Beba0RVX/z9vHttnFe09bR/qkSYrGsnMIxr ZJGtD3CGk6TY
EkDfi07b7H/Rf2HE42aV8Qx0bJGAOcyWoYzsd9js5o3Hqn/RT4cKupLrDYvw b1K5/stYzb+v
N7fUdt/7fP7V/aIFvUV/aa3Nxq1/WtQdU4bvm7gODe7+O30968sUznww9G5+ l2eTHD1VTMN0
zhep8szYbH9dv1fa3xRc9tt+PLbfbcb7fSF7a2HxVqtFYq1qM0ErBJHJGxrm vaRuHAjuII79
1CdIOnswzXVbPaFyeLfqqvjHwz4W+9u1qpzc5rmgEOaet2G5IaTsC5oBDq4z WM1/G9G1fRWN
s4nHZ/tz5aeMiqidhgaeTIuu2hDesLnEkAkAEbEkH0biLOXD02aH5AoeBq+6 b8E8gUPA1fdN
+CouJ1HqbKR9GWLu5KtUt53t/b7uMNewXdmY7hwf+0i9buLtge8bDj3hebOa nzva7GPx2q61
uLHaRs5sZPGV4ON2eOV0Y5B3WtDRw7wwt9Yu7wNmtbiDhos0PyBQ8DV9034L lZw+Kq1pbFqt
RhgiYZJJJGNa1jQNy4k9wAHfus8y+sNT3LLX0snHj4joMakkiiqsf/aNyfUL wSBvxBDuQ48g
AHEPb5taauy2WxL6s9+njadnQbs3O3qhwnnmIi6olx3A9Yhga4Hm5u/MeqW4 g4aLLvdu6Oo9
R23I6frdoibPD108LOsjd8l7dz3tOx2I7ipWth8VarRWKtajNBKwSRyRsa5r 2kbhwI7iCO/d
ZfpN2Vra30tLgsbXydtvR3Vk7NNb7NzHWg7NdwcOROwAPEd/e4bLlo/KX8Vo voowembdyzBm
WX5bElCCBtkuj5PdEztP7MBr3uDnH5Qj3aRvsW4heGp9oablq2n8PWbYy5xV CBzxG2S0Y4ml
xBPEF2w32BO38Cvb5AoeBq+6b8Fl+OfmM7q/oZv5vIxnIzsybZjQkrzQuMTS C5rmBzSZGgB+
zth38Qw7r29FmrNWahyWkruQl3x+b7f2iKw+nHF+zc4x9jY1wsO48eL+Yd3H f/xBuIThos0P
yBQ8DV9034J5AoeBq+6b8Fl2M1bqk9E2kc6/LXLuT1FmocdIGQVWuhZ10zSK 4LGsD3CNo3l5
NG/+H2r3WtTavr4DFsdfrwZCXWjMIJZBWsvNZ3IhlhsDiwSAkBzWFjtmj2b8 i3EHDRZofkCh
4Gr7pvwTyBQ8DV9034LPPPHUPkbsXb/7T59ebHlDqI+v7Ny357cer6zb1d+G 23+HfvXu1FnM
7j9QaZ05jNQSZx129kIrNjFw1G3WCCMPbXd1h6gPbz9clrCQ0bAHfk3EHDRZ dfIFDwNX3Tfg
o3jpnyP5W67DeSvG84up+Vx+X8n5Xd7fb3KpVNXaklo9HFfI5XFUbGVZkZsj fhMNiEioxxaX
Oa4x8DsDJwc09xDXR/NV+jeHlhehA3R/+IfbygkM39x2nlJ2fff1es5cuHz7 78U3EHDU2ajW
l0parRWKtvBTQS2BUjkjlic18xG4iBB2LyO/j7VLeQKHgavum/BVDpgr4dua 0qMf5P8AK/nb
im5AQcOvG7ZOq67b1vk78eXzexR+a1nm4da03Yi5JZwg1NDp+11zImQmV/MP iij4dbvG3gTK
6UBz9+LCw7BuIscPT7Qv/kCh4Gr7pvwTyBQ8DV9034LG7WtNdMsUKYyUUmUy lmUVOzvpux9+
ITtG1K0WkMlADmcJ+fcdzs8sYde6Jss7Uum7ViS7ctzVr09WRt6i2pZrlpB6 qZrSWF7Q4es0
NBBG7Q4OUnYRBP00R7IzU0AwUeOvYtjKlpt2NokhYGnY77g7e0H5we4raqkh mqwyuADnsa47
ezchZV0pV+qwuPdt/wDsIh/7OV5q5aSaxTxuKjZNJCyN12Z2/V12FoPDu9sj h7G/MDyP+EO7
bCnLEx+f8dvp6csTH5/yFW0ZiMzjPN7tmHss82dPy4p200B8oSns2zq+0nyT 2V3fL1R9dnd8
rjYNaYubNVIezY3e7TydAxzSdWHOgbbqzzOY7luG7R97TsSYu4H1SbUi7PQK q5L96env5Lk/
69BWpVXJfvT09/Jcn/XoILUiIgIiICidX/8ACeb/AORn/puUsvzNGyaJ8UzG yRPaWuY4bhwP
tBHzhSqMYmGaozRMOfZ2rwZbCtyIqltuxUlrS9dHLAGFwPBzCNntcCNnn5lT 7PRLhJJ3vhmt
RRuO7Y+sc7j/AA3JXP0RYjxdr7x+KxMTPpMeaJGaPaNey1Radf22pYt5jIXO zSGWOKVsDW8i
xzNzwjafY93zr35PDUMrRlpZSnWu05dusgsxNkjfsQRu1wIOxAP/AJhUb0RY jxdr7x+KeiLE
eLtfePxSmmaf4iPP+EzXPtGvZb6GlcHj8XYxtDD46rjrPLr6sFVjIpeTeLuT ANnbtAB3HeBs
lDSuDx+LsY2hh8dVx1nl19WCqxkUvJvF3JgGzt2gA7jvA2VQ9EWI8Xa+8fin oixHi7X3j8Ve
a3mic1o17LVDo3TkGHnxMOCxMeKneJJabKcYhkcNvWczbiT6re8j/CPoXWLS uDio0qUWHxzK
dKYWKsDarBHXlBJEjG7bNcC5x3Gx3J+lVD0RYjxdr7x+KeiLEeLtfePxTmt5 ovNaNey3y6Vw
ctG7Slw+OfTuzGxagdVYY7EpIJke3bZziWtO53O4H0LrHp7ExVb1aLG0mVr7 5JLcTYGhlhzx
s90g22eXDuJO+/zql+iLEeLtfePxT0RYjxdr7x+Kc1vNE5rRr2XSzp7E2sOM TZxtKbFBjIxT
kga6ENZtxbwI47DYbDbu2H0LyzaN05Ph4MTNgsTJioHmSKm+nGYY3Hf1ms24 g+s7vA/xH6VV
fRFiPF2vvH4p6IsR4u194/FOa3mhzWjXsujdPYlkmOkZjaTZMcwx0nCBoNVp aGlsR29QFoA2
bt3DZeWto3TlXMHLVsFiYcqXvkNyOnG2YufvydzA5bnc7nfv3P0qq+iLEeLt fePxT0RYjxdr
7x+Kc1vNDmtGvZaptG6cnw8GJmwWJkxUDzJFTfTjMMbjv6zWbcQfWd3gf4j9 K5WNC6Ws0alK
xpzCy06nPs0ElGJ0cPM7u4NLdm7nvO3tKrXoixHi7X3j8U9EWI8Xa+8finNb zRea0a9lv81c
H5c8teR8d5Y8d2VnX/J4f3m3L5Pq+32d3sUp2dqzz0RYjxdr7x+KeiLEeLtf ePxTmt5onNaN
ez84hoZ01Zpo9ggi/pBT2vdN6OydRuS1pVxzIabmOF6zL2cxesA0GUFpALiB sTsSfYvxpXQd
LTeT7ZTsTPcWljmv79x3/wAf4rtroSQ29MZPs9mapjcm6xa7NA+eRkbqlmEE RsBe/wBeWMbN
BIBJPcCRaYwhqiMIwlOYKHGQYio3BR1GYx0YfX7GGiJzHDcObx7iCDvuPbuv S2zA61JVbNEb
MbGyPiDxzaxxcGuI9oBLHgH5+J+gqq6JmOK03Kb9a9G6e1k8mxgqSuf1D7kk rN2taS2QslYR
EQJD3jju1wDAYZmN6SdTWq9SWOC7j6Mj7Dg53XzCa4X+u7fkWtdGNt/VbwaA GhoWmlvREQER
EBERAREQEREBERAREQEREBERAREQEREBERAREQEREBERAREQFybZgdakqtmi NmNjZHxB45tY
4uDXEe0AljwD8/E/QV1VfpaTxtPWV/U8LNspdhFeZ/VRDlGAziOQYHd3Anfl ueWzuQZEIw45
LE18ZhQyJ0ks0+QqST2JiHSTPNiIcnEAfMAAAAAAAAAAFYOztX5yNGtkqM1O 9C2atM3i9jvn
H/yD84I7we8LP3dEeGLjxtWw3fuBcSdv9ViYnHGHOYnNjC23cAZ8k+7Wyl6l LJEyF7YGxFrg
wvLT67Hd/ru9i/eMwXYrlm1Nft3Z5444i6wIxxawvIADGNHte727qneiLEeL tfePxT0RYjxd
r7x+Kzk9ccI8/wCLjX/GEa9lvzelcHnup8uYfHZLqOXVdsqsm6vltvx5A7b7 Dfb6Al/SuDyG
Lr42/h8dax1bj1FWeqx8UXFvFvFhGzdmkgbDuB2VQ9EWI8Xa+8finoixHi7X 3j8Vrmt5onNa
Ney339K4PIYuvjb+Hx1rHVuPUVZ6rHxRcW8W8WEbN2aSBsO4HZcsjo3TmTq0 62SwWJt1qTOr
qxT045GQN2A4sBBDRs1o2G3sH0Kq+iLEeLtfePxT0RYjxdr7x+Kc1vNF5rRr 2XS1p7E3LU1m
3jaU9masacsssDXPfATuYnEjcsJO5ae7+C5WNK4OzDUisYfHSxVIX16zJKrH Nhiezg6NgI9V
pZ6pA7iO72KoeiLEeLtfePxT0RYjxdr7x+Kc1vNE5rRr2XSrp7E07UNmpjaU FmGsKcUsUDWv
ZADuImkDcMBG4aO7+C8trRunLlWatbwWJnrTWTclilpxuY+cjYyuBGxeQdi4 9/8AFVX0RYjx
dr7x+KeiLEeLtfePxTmt5oc1o17Lo3T2JZJjpGY2k2THMMdJwgaDVaWhpbEd vUBaANm7dw2X
KhpXB4/KWMlQw+Oq5Gzy6+1BVYyWXk7k7k8Dd27gCdz3kbqoeiLEeLtfePxT 0RYjxdr7x+Kc
1vNDmtGvZb/NXB+Q/IvkfHeR/A9lZ1Hyuf8Ad7cflet7Pb3+1ItK4OKjSpRY fHMp0phYqwNq
sEdeUEkSMbts1wLnHcbHcn6VUPRFiPF2vvH4p6IsR4u194/FOa3mhzWjXst8 ulcHLRu0pcPj
n07sxsWoHVWGOxKSCZHt22c4lrTudzuB9C5TaN05Ph4MTNgsTJioHmSKm+nG YY3Hf1ms24g+
s7vA/wAR+lVX0RYjxdr7x+KeiLEeLtfePxTmt5ovNaNey6SaexMtWjWlxtJ9 ag+OSpE6BpZX
cwbMdGNtmFo7gRtt8y5eauD8h+RfI+O8j+B7KzqPlc/7vbj8r1vZ7e/2qoei LEeLtfePxT0R
Yjxdr7x+Kc1vNE5rRr2Wqro3TlOrDWqYLEwVobIuRRRU42sZOBsJWgDYPAGw cO/+KWdG6ctZ
gZazgsTNlQ9kguSU43TBzNuLuZHLcbDY792w+hVX0RYjxdr7x+KeiLEeLtfe PxTmt5ovNaNe
yyy6F0tLNdll05hXy3d+1PdRiLrG7w88zx9bd7Wu79+8A+0KUxmGoYqjFSxd OtSpxb9XBWib
HGzcknZrQANySf8AzKo3oixHi7X3j8U9EWI8Xa+8finNbzROa0a9nTpniDNO 40j6yhH/APL1
+fR1p8ZOLJ+a2DycWQLHXY7NKF8jJCBvOxzx3j/vs37/AJTfW3D/AOM6JcSx 7Xtt2eTSCNyT
3g7/AErRK0XU14ot+XBgbvttvsNlaYmMcVoiYxxVn0caH+xum/8A0uD/AOqe jjQ/2N03/wCl
wf8A1VKw3ShloNN6aF3B2ctlJsLVyl91KKxM57JQ4MMYhrub1ruqeSyQxMBI aHuHJzZDXmuc
/j8dq2DF4iKrZx+Ps2K1ixZLJAI4y42Ax0RjkjHdt1b5CHPhbI2Pm7hptZfR xof7G6b/APS4
P/qpDCaT07gbT7ODwGJxtl7DG6WnTjhe5u4PEloBI3AO38As/t69zeM1RkaV irFasi0ytBTF
psdeN724hnEy9SZHBsl6RwfsO7cFp3bw9drpAyNfV1PF2KUUVxrLVOanHPzr Pt70HQO7S6Np
bHwt7EloJc4sa2R3Vh4aeiIgIiICIiAiIgIiICIiAiIgIiICIiAiIgIiICIi AiIgIiICIiAi
IiICIiAiIgIiICIiAiIgIiIKrF0f6cioUaTKlkVKkIqsi7fYLZYASWwzev8A tohycBHJyaA5
zQAHEHrd0Np+7JedapSyx3GTMlgNqbqG9c1zZXxxc+Ecjg+TeRjWuPWP7/Xd vZUQVrzG0/2p
lp9KWSy18cnWy2pnvc9hrFrnFzyXHelWJJ336vv35O5dbmjsFcv27tmjyt2u RklE0jXcnCAc
m7O9Rw7JXLXN2LTGHNIO5NgRAREQEREBERAREQEREBERAREQEREBERAREQER EBERAREQEREB
EREBERAREQEREBERAREQEREBERAREQEREBERAREQEREBERAREQf/2Q==
--------------090207060603010507090305--
Re: Teneo: HibernateException when trying to save HibernateResource [message #54473 is a reply to message #54446] Fri, 29 September 2006 07:00 Go to previous messageGo to next message
Hi Hans,
Each HibernateResource has its own session. When you save one resource the references are followed
and the objects in the second resource are saved also using the session of the first resource. This
results in an error.
So basically working with references between multiple hibernateresources is not yet supported.
The solution would be to move session and transaction control also outside of the resource (to the
resourceset). This has not been implemented yet (adding a feature request in bugzilla can help).
What you can try for now is load all the data in one resource using multiple queries. You can
specify multiple queries in the url by using parameters query1, query2, query3, etc.
gr. Martin
Hans Mueller-Dieckert wrote:
> build by a query.
> greetings,
> Hans
> ... 34 more
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo: HibernateException when trying to save HibernateResource [message #55924 is a reply to message #54473] Mon, 02 October 2006 18:09 Go to previous messageGo to next message
Originally posted by: sprakash.tibco.com
Hi Martin,
I have the same problem. But I notice that HibernateResource.unload()
doesnt actually close the underlying Hibernate session (unless I am
looking at the wrong code again). Why is that? So the Hibernate sessions
are cleaned only through garbage collection then? My problem is that if I
retrieve Object A from Resource 1 and then unload Resource 1, I was
expecting that Object A would become a detached object (in Hibernate
terminology). Next when I retrieve Object B in Resource 2 and add Object A
to resource 2, I get the same exception "Illegal ..." when I save Resource
2, because Object A and its collection are still persistent objects of the
session in Resource 1. If HibernateResource.unload() actually closed the
session, wouldnt everything automatically be ok? If so, why doesnt
HibernateResource.unload() actually close the session, only set it to null?
Thanks in advance,
Sundeep
Re: Teneo: HibernateException when trying to save HibernateResource [message #56026 is a reply to message #55924] Tue, 03 October 2006 01:55 Go to previous messageGo to next message
Hi Sundeep,
I think there are two issues which you mention here:
1) closing the session when unloading. This is a missing feature (or oversight from me). Can you
enter a bugzilla for this? I use bugzilla to keep a public record of changes that's why I prefer a
bugzilla entry for also smaller things to add (like this).
2) having multiple resources with objects refering to eachother. This I will solve in the next
release. My idea is to add the concept of a sessioncontroller which is registered by name, the
session controller can then be used by multiple resources sharing one session. The transaction
handling then needs to be done outside of the actual resource save action.
gr. Martin
Sundeep Prakash wrote:
> Hi Martin,
> I retrieve Object A from Resource 1 and then unload Resource 1, I was
> A to resource 2, I get the same exception "Illegal ..." when I save
> Resource 2, because Object A and its collection are still persistent
> objects of the session in Resource 1. If HibernateResource.unload()
> actually closed the session, wouldnt everything automatically be ok? If
> so, why doesnt HibernateResource.unload() actually close the session,
> Thanks in advance,
> Sundeep
The Netherlands
Re: Teneo: HibernateException when trying to save HibernateResource [message #56250 is a reply to message #56026] Tue, 03 October 2006 18:17 Go to previous messageGo to next message
Filed bug #159668 "Resource unload does not close Hibernate session"
thanks
Sundeep
Re: Teneo: HibernateException when trying to save HibernateResource [message #56729 is a reply to message #54446] Thu, 05 October 2006 00:48 Go to previous message
The latest build now provides the possibility to share a session between resources and save multiple
resources within one transaction. Please see here for more information (note url maybe truncated):
http://www.elver.org/hibernate/hibernateresources.html#Shari ng+one+Session+between+Resources%2C+One+transaction+when+sav ing+multiple+resources
gr. Martin
> build by a query.
> greetings,
> Hans
> ... 34 more
The Netherlands
Re: Teneo: HibernateException when trying to save HibernateResource [message #592694 is a reply to message #54446] Fri, 29 September 2006 07:00 Go to previous message
Hi Hans,
gr. Martin
> build by a query.
> greetings,
> Hans
> ... 34 more
The Netherlands
Re: Teneo: HibernateException when trying to save HibernateResource [message #593344 is a reply to message #54473] Mon, 02 October 2006 18:09 Go to previous message
Hi Martin,
Thanks in advance,
Sundeep
Re: Teneo: HibernateException when trying to save HibernateResource [message #593383 is a reply to message #55924] Tue, 03 October 2006 01:55 Go to previous message
Hi Sundeep,
gr. Martin
> Hi Martin,
> Thanks in advance,
> Sundeep
The Netherlands
Re: Teneo: HibernateException when trying to save HibernateResource [message #593515 is a reply to message #56026] Tue, 03 October 2006 18:17 Go to previous message
thanks
Sundeep
Re: Teneo: HibernateException when trying to save HibernateResource [message #593742 is a reply to message #54446] Thu, 05 October 2006 00:48 Go to previous message
gr. Martin
> build by a query.
> greetings,
> Hans
> ... 34 more
The Netherlands
Previous Topic:[OCL] Resolving properties, ambiguities
Next Topic:Teneo HibernateResource
Current Time: Tue Nov 04 05:50:43 EST 2025
Powered by FUDForum. Page generated in 0.54005 seconds
