Home » Archived » EPF » OpenUP 'footer' information
OpenUP 'footer' information [message #54411] Tue, 11 November 2008 05:36 Go to next message
I've been looking at the OpenUP published website. I'd like to add
something to my process model that is similar to the text (or links)
displayed below the main information (e.g. Main Description), that says
"This program and the accompanying materials are made available under the
Eclipse Public License V1.0, which accompanies this distribution.
OpenUP Copyright"
I've found the copyright guidance element in the model, but can't work out
how to add it to every page by default (as a 'footer' so to speak), as the
OpenUP model seems to do.
Can anyone help me with this?
Re: OpenUP 'footer' information [message #54442 is a reply to message #54411] Tue, 11 November 2008 14:47 Go to previous messageGo to next message
Originally posted by: storaskar.xx.xxx.xxx
You create a guidance with appropriate copyright and attach to Method
plugin. Open method plugin editor->version information->select that
copyright. When you publish the config, that copyright should be available.
Regards.
Re: OpenUP 'footer' information [message #54495 is a reply to message #54442] Wed, 12 November 2008 05:58 Go to previous message
That worked, easy when you know how!
Thank you for your help.
Re: OpenUP 'footer' information [message #590901 is a reply to message #54411] Tue, 11 November 2008 14:47 Go to previous message
Regards.
Re: OpenUP 'footer' information [message #590927 is a reply to message #54442] Wed, 12 November 2008 05:58 Go to previous message
Previous Topic:Importing EPF models
Next Topic:Model Meta-Doc?
Current Time: Tue Nov 11 23:00:12 EST 2025
Powered by FUDForum. Page generated in 0.04261 seconds
