Home » Archived » Visual Editor (VE) » Designtime: Components don't show up
Designtime: Components don't show up [message #54312] Tue, 03 August 2004 21:31 Go to next message
Originally posted by: relativityNOtimeshipSPAM.PLEASEyahoo.com
Firstly I'd like to say thanks for the creation of this software.
I've expierienced a strange problem in designing visual components
derived from javax.swing.*
I'm able to create a VisualClass file fine - however the class isn't draw
in the upper frame. I see a "Loading..." an then nothing.
Did I miss something? (class-paths or other properties to
set?) Anybody experienced something similar?
Setup (plus inst. plugins):
WindowsXP
Eclipse 3.0 200406251208
Eclipse SDK 3.0.0 + Examples
FTP/WebDAV Support 3.0.0
EMF 2.0.0 R200406280827 + Docs + Source + Samples
EMF SDO 2.0.0 R200406280827 + Docs + Soource
XML XSD R200406280827 + Docu + Source
GEF SDK 3.0.0 + Samples
VE 1.0.0 M2
---> I've included a full config info at the very bottom of this post!
the .log shows:
!SESSION Aug 04, 2004 03:17:25.181
eclipse.buildId=I200406251208
java.version=1.4.2_03
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_AT
!ENTRY org.eclipse.ve.java.core 4 0 Aug 04, 2004 03:17:25.181
!MESSAGE Exception thrown.
!STACK 0
java.lang.ClassCastException
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.createJavaInstances(JavaSourceTranslator.java:704)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.buildCompositionModel(JavaSourceTranslator.java:773)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSourceTranslator.java:880)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(JavaSourceTranslator.java:655)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1413)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
thanks in advance
Joe
config:
*** Date: 04.08.04 03:31
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
C:\Programme\eclipse\eclipse.exe -showsplash 600
-exitdata
C:\Programme\eclipse\eclipse.exe -exitdata 1480_a8
-vm
C:\WINDOWS\system32\javaw.exe
eclipse.product=org.eclipse.platform.ide
eclipse.startTime=1091582138712
eclipse.vm=C:\WINDOWS\system32\javaw.exe
eclipse.vmargs=-cp
C:\Programme\eclipse\startup.jar
org.eclipse.core.launcher.Main
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\Programme\eclipse\startup.jar
java.class.version=48.0
java.endorsed.dirs=C:\Programme\Java\j2re1.4.2_03\lib\endors ed
java.ext.dirs=C:\Programme\Java\j2re1.4.2_03\lib\ext
java.home=C:\Programme\Java\j2re1.4.2_03
java.io.tmpdir=C:\DOKUME~1\joe\LOKALE~1\Temp\
java.library.path=C:\WINDOWS\system32;.;C:\WINDOWS\System32; C:\WINDOWS;C:\Programme\TeXLive\bin\win32;c:\programme\borla nd\vbroker\bin;C:\Programme\Borland\Delphi7\Bin;C:\Programme \Borland\Delphi7\Projects\Bpl\;C:\WINDOWS\system32;C:\WINDOW S;C:\WINDOWS\System32\Wbem;C:\Programme\UltraEdit;C:\Program me\Gemeinsame
Dateien\Autodesk
Shared\;c:\programme\mysql\bin;c:\programme\tools\cmdlinetoo ls;C:\Programme\3dsmax5\backburner2\;c:\programme\java\j2sdk 1.4.2_01\bin;F:\cygwin\bin;c:\programme\matlab6p5\bin\win32; C:\Programme\ATI
Technologies\ATI Control Panel;C:\Programme\CVS\cvsnt;
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.4.2_03-b02
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.4
java.util.prefs.PreferencesFactory=java.util.prefs.WindowsPr eferencesFactory
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.4.2_03-b02
line.separator=
org.eclipse.jdt.debug.ui.scrapbookActive=false
org.osgi.framework.executionenvironment=
org.osgi.framework.language=de
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.2.0
org.xml.sax.driver=org.apache.crimson.parser.XMLReaderImpl
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.core.runtime@2:start,
org.eclipse.update.configurator@3:start
osgi.bundles.defaultStartLevel=4
osgi.bundlestore=c:\Programme\eclipse\configuration\org.ecli pse.osgi\bundles
osgi.configuration.area=file:/c:/Programme/eclipse/configura tion/
osgi.framework=file:/c:/Programme/eclipse/plugins/org.eclips e.osgi_3.0.0/
osgi.framework.beginningstartlevel=1
osgi.framework.version=3.0.0
osgi.frameworkClassPath=core.jar, console.jar, osgi.jar, resolver.jar,
defaultAdaptor.jar, eclipseAdaptor.jar
osgi.install.area=file:/c:/Programme/eclipse/
osgi.instance.area=file:/C:/Programme/eclipse/workspace/
osgi.logfile=C:\Programme\eclipse\workspace\.metadata\.log
osgi.manifest.cache=c:\Programme\eclipse\configuration\org.e clipse.osgi\manifests
osgi.nl=de_AT
osgi.os=win32
osgi.splashLocation=c:\Programme\eclipse\plugins\org.eclipse .platform_3.0.0\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Programme\Java\j2re1.4.2_03\lib\rt.ja r;C:\Programme\Java\j2re1.4.2_03\lib\i18n.jar;C:\Programme\J ava\j2re1.4.2_03\lib\sunrsasign.jar;C:\Programme\Java\j2re1. 4.2_03\lib\jsse.jar;C:\Programme\Java\j2re1.4.2_03\lib\jce.j ar;C:\Programme\Java\j2re1.4.2_03\lib\charsets.jar;C:\Progra mme\Java\j2re1.4.2_03\classes
sun.boot.library.path=C:\Programme\Java\j2re1.4.2_03\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium i486 i386
sun.io.unicode.encoding=UnicodeLittle
sun.java2d.fontpath=
sun.net.client.defaultConnectTimeout=60000
sun.net.client.defaultReadTimeout=60000
sun.os.patch.level=Service Pack 1
user.country=AT
user.dir=C:\Programme\eclipse
user.home=C:\Dokumente und Einstellungen\############
user.language=de
user.name=joe
user.timezone=Europe/Berlin
user.variant=
vendor=Apache Software Foundation
vendor-url=http://xml.apache.org/xalan-j
version=2.4.1
*** Features:
org.eclipse.emf (2.0.0.R200406280827) ""
org.eclipse.emf.doc (2.0.0.R200406280827) ""
org.eclipse.emf.ecore.sdo (2.0.0.R200406280827) ""
org.eclipse.emf.ecore.sdo.doc (2.0.0.R200406280827) ""
org.eclipse.emf.ecore.sdo.source (2.0.0.R200406280827) ""
org.eclipse.emf.examples (2.0.0.R200406280827) ""
org.eclipse.emf.source (2.0.0.R200406280827) ""
org.eclipse.gef (3.0.0) ""
org.eclipse.gef.examples (3.0.0) ""
org.eclipse.gef.sdk (3.0.0) ""
org.eclipse.gef.source (3.0.0) ""
org.eclipse.jdt (3.0.0) "Eclipse Java Development Tools"
org.eclipse.jdt.source (3.0.0) "Eclipse Java Development Tools SDK"
org.eclipse.jem (1.0.0) "Java EMF Model"
org.eclipse.pde (3.0.0) "Eclipse Plug-in Development Environment"
org.eclipse.pde.source (3.0.0) "Eclipse Plug-in Development Environment
Developer Resources"
org.eclipse.platform (3.0.0) "Eclipse Platform"
org.eclipse.platform.source (3.0.0) "Eclipse Platform Plug-in Developer
Resources"
org.eclipse.sdk (3.0.0) "Eclipse Project SDK"
org.eclipse.sdk.examples (3.0.0) ""
org.eclipse.team.extras (3.0.0) ""
org.eclipse.ve (1.0.0) "Visual Editor"
org.eclipse.xsd (2.0.0.R200406280827) ""
org.eclipse.xsd.doc (2.0.0.R200406280827) ""
org.eclipse.xsd.source (2.0.0.R200406280827) ""
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.1) "Event Model"
com.ibm.wtp.common.util (1.0.0) "Logging Plug-in"
com.ibm.wtp.emf.workbench (1.0.0) "EMF Workbench"
org.apache.ant (1.6.1) "Apache Ant"
org.apache.lucene (1.3.0) "Apache Lucene"
org.eclipse.ant.core (3.0.0) "Ant Build Tool Core"
org.eclipse.ant.ui (3.0.0) "Ant UI"
org.eclipse.compare (3.0.0) "Compare Support"
org.eclipse.compare.examples (3.0.0) ""
org.eclipse.compare.examples.xml (3.0.0) ""
org.eclipse.core.boot (3.0.0) "Core Boot"
org.eclipse.core.expressions (3.0.0) "Expression Language"
org.eclipse.core.filebuffers (3.0.0) "File Buffers"
org.eclipse.core.resources (3.0.0) "Core Resource Management"
org.eclipse.core.resources.win32 (3.0.0) "Core Resource Management Win32
Fragment"
org.eclipse.core.runtime (3.0.0) "Core Runtime"
org.eclipse.core.runtime.compatibility (3.0.0) "Core Runtime Plug-in
Compatibility"
org.eclipse.core.variables (3.0.0) "Core Variables"
org.eclipse.debug.core (3.0.0) "Debug Core"
org.eclipse.debug.ui (3.0.0) "Debug UI"
org.eclipse.draw2d (3.0.0) ""
org.eclipse.draw2d.doc.isv (3.0.0) ""
org.eclipse.emf (2.0.0.200406280827) ""
org.eclipse.emf.activities (2.0.0.200406280827) ""
org.eclipse.emf.codegen (2.0.0.200406280827) ""
org.eclipse.emf.codegen.ecore (2.0.0.200406280827) ""
org.eclipse.emf.codegen.ecore.ui (2.0.0.200406280827) ""
org.eclipse.emf.codegen.ui (2.0.0.200406280827) ""
org.eclipse.emf.common (2.0.0.200406280827) ""
org.eclipse.emf.common.ui (2.0.0.200406280827) ""
org.eclipse.emf.commonj.sdo (2.0.0.200406280827) ""
org.eclipse.emf.doc (2.0.0.200406280827) ""
org.eclipse.emf.ecore (2.0.0.200406280827) ""
org.eclipse.emf.ecore.change (2.0.0.200406280827) ""
org.eclipse.emf.ecore.change.edit (2.0.0.200406280827) ""
org.eclipse.emf.ecore.edit (2.0.0.200406280827) ""
org.eclipse.emf.ecore.editor (2.0.0.200406280827) ""
org.eclipse.emf.ecore.sdo (2.0.0.200406280827) ""
org.eclipse.emf.ecore.sdo.doc (2.0.0.200406280827) ""
org.eclipse.emf.ecore.sdo.edit (2.0.0.200406280827) ""
org.eclipse.emf.ecore.sdo.editor (2.0.0.200406280827) ""
org.eclipse.emf.ecore.xmi (2.0.0.200406280827) ""
org.eclipse.emf.edit (2.0.0.200406280827) ""
org.eclipse.emf.edit.ui (2.0.0.200406280827) ""
org.eclipse.emf.examples (2.0.0.200406280827) ""
org.eclipse.emf.java (2.0.0.200406280827) ""
org.eclipse.emf.java.edit (2.0.0.200406280827) ""
org.eclipse.emf.java.editor (2.0.0.200406280827) ""
org.eclipse.emf.mapping (2.0.0.200406280827) ""
org.eclipse.emf.mapping.ecore2ecore (2.0.0.200406280827) ""
org.eclipse.emf.mapping.ecore2ecore.editor (2.0.0.200406280827) ""
org.eclipse.emf.mapping.ui (2.0.0.200406280827) ""
org.eclipse.emf.mapping.xsd2ecore (2.0.0.200406280827) ""
org.eclipse.emf.mapping.xsd2ecore.editor (2.0.0.200406280827) ""
org.eclipse.gef.doc.isv (3.0.0) ""
org.eclipse.gef.examples.flow (3.0.0) ""
org.eclipse.gef.examples.logic (3.0.0) ""
org.eclipse.gef.examples.source (3.0.0) ""
org.eclipse.help (3.0.0) "Help System Core"
org.eclipse.help.appserver (3.0.0) "Help Application Server"
org.eclipse.help.base (3.0.0) "Help System Base"
org.eclipse.help.examples.ex1 (3.0.0) ""
org.eclipse.help.ide (3.0.0) "Help System IDE"
org.eclipse.help.ui (3.0.0) "Help System UI"
org.eclipse.help.webapp (3.0.0) "Help System Webapp"
org.eclipse.jdt.core (3.0.0) "Java Development Tools Core"
org.eclipse.jdt.debug (3.0.0) "JDI Debug Model"
org.eclipse.jdt.debug.ui (3.0.0) "JDI Debug UI"
org.eclipse.jdt.doc.isv (3.0.0) "Eclipse JDT Plug-in Developer Guide"
org.eclipse.jdt.doc.user (3.0.0) "Eclipse Java Development User Guide"
org.eclipse.jdt.junit (3.0.0) "Java Development Tools JUnit support"
org.eclipse.jdt.junit.runtime (3.0.0) "Java Development Tools JUnit
runtime support"
org.eclipse.jdt.launching (3.0.0) "Java Development Tools Launching
Support"
org.eclipse.jdt.ui (3.0.0) "Java Development Tools UI"
org.eclipse.jdt.ui.examples.projects (3.0.0) ""
org.eclipse.jem.beaninfo (1.0.0) "Java EMF Model BeanInfo (Introspection)
Support"
org.eclipse.jem.proxy (1.0.0) "Java EMF Model Proxy Support"
org.eclipse.jem.ui (1.0.0) "Java EMF Model UI"
org.eclipse.jem.workbench (1.0.0) "Java EMF Model Workbench Support"
org.eclipse.jface (3.0.0) "JFace"
org.eclipse.jface.text (3.0.0) "JFace Text"
org.eclipse.ltk.core.refactoring (3.0.0) "Refactoring Core"
org.eclipse.ltk.ui.refactoring (3.0.0) "Refactoring UI"
org.eclipse.osgi (3.0.0) "OSGi System Bundle"
org.eclipse.osgi.services (3.0.0) "OSGi Release 3 Services"
org.eclipse.osgi.util (3.0.0) "OSGi R3 Utility Classes"
org.eclipse.pde.build (3.0.0) "Plug-in Development Environment Build
Support"
org.eclipse.pde.core (3.0.0) "Plug-in Development Core"
org.eclipse.pde.doc.user (3.0.0) "Eclipse Plug-in Development User Guide"
org.eclipse.pde.junit.runtime (3.0.0) "PDE JUnit Plug-in Test"
org.eclipse.pde.runtime (3.0.0) "Plug-in Development Environment Runtime"
org.eclipse.pde.ui (3.0.0) "Plug-in Development UI"
org.eclipse.platform.doc.isv (3.0.0) "Eclipse Platform Plug-in Developer
Guide"
org.eclipse.platform.doc.user (3.0.0) "Eclipse Workbench User Guide"
Resources"
org.eclipse.platform.source.win32.win32.x86 (3.0.0) "Eclipse Platform
Plug-in Developer Resources"
org.eclipse.sdk.examples.source (3.0.0) ""
org.eclipse.sdk.examples.source.win32.win32.x86 (3.0.0) ""
org.eclipse.search (3.0.0) "Search Support"
org.eclipse.swt (3.0.0) "Standard Widget Toolkit"
org.eclipse.swt.examples (3.0.0) ""
org.eclipse.swt.examples.browser (3.0.0) ""
org.eclipse.swt.examples.controls (3.0.0) ""
org.eclipse.swt.examples.launcher (3.0.0) ""
org.eclipse.swt.examples.layouts (3.0.0) ""
org.eclipse.swt.examples.ole.win32 (3.0.0) ""
org.eclipse.swt.examples.paint (3.0.0) ""
org.eclipse.swt.win32 (3.0.0) "Standard Widget Toolkit for Windows"
org.eclipse.team.core (3.0.0) "Team Support Core"
org.eclipse.team.cvs.core (3.0.0) "CVS Team Provider Core"
org.eclipse.team.cvs.ssh (3.0.0) "CVS SSH Core"
org.eclipse.team.cvs.ssh2 (3.0.0) "CVS SSH2"
org.eclipse.team.cvs.ui (3.0.0) "CVS Team Provider UI"
org.eclipse.team.examples.filesystem (3.0.0) ""
org.eclipse.team.extras.source (3.0.0) ""
org.eclipse.team.ftp (3.0.0) ""
org.eclipse.team.ui (3.0.0) "Team Support UI"
org.eclipse.team.webdav (3.0.0) ""
org.eclipse.text (3.0.0) "Text"
org.eclipse.tomcat (4.1.30) "Tomcat Wrapper"
org.eclipse.ui (3.0.0) "Eclipse UI"
org.eclipse.ui.cheatsheets (3.0.0) "Cheat Sheets"
org.eclipse.ui.console (3.0.0) "Console"
org.eclipse.ui.editors (3.0.0) "Default Text Editor"
org.eclipse.ui.examples.javaeditor (3.0.0) ""
org.eclipse.ui.examples.multipageeditor (2.1.0) ""
org.eclipse.ui.examples.propertysheet (2.1.0) ""
org.eclipse.ui.examples.readmetool (2.1.0) ""
org.eclipse.ui.externaltools (3.0.0) "External Tools"
org.eclipse.ui.forms (3.0.0) "Eclipse Forms"
org.eclipse.ui.ide (3.0.0) "Eclipse IDE UI"
org.eclipse.ui.intro (3.0.0) "Intro Plugin"
org.eclipse.ui.presentations.r21 (3.0.0) "R21 Presentation Plug-in"
org.eclipse.ui.views (3.0.0) "Views"
org.eclipse.ui.win32 (3.0.0) "Win32 fragment"
org.eclipse.ui.workbench (3.0.0) "Workbench"
org.eclipse.ui.workbench.compatibility (3.0.0) "Workbench Compatibility"
org.eclipse.ui.workbench.texteditor (3.0.0) "Text Editor Framework"
org.eclipse.update.configurator (3.0.0) "Install/Update Configurator"
org.eclipse.update.core (3.0.0) "Install/Update Core"
org.eclipse.update.core.win32 (3.0.0) "Install/Update Core for Windows"
org.eclipse.update.scheduler (3.0.0) "Automatic Updates Scheduler"
org.eclipse.update.ui (3.0.0) "Install/Update UI"
org.eclipse.ve.cde (1.0.0) "Visual Editor Common Data Editor"
org.eclipse.ve.doc (1.0.0) "Visual Editor User Guide"
org.eclipse.ve.java.core (1.0.0) "Visual Editor Java Core"
org.eclipse.ve.jfc (1.0.0) "Visual Editor for Java Foundation Classes"
org.eclipse.ve.propertysheet (1.0.0) "Visual Editor PropertySheet"
org.eclipse.ve.swt (1.0.0) "Visual Editor for Standard Widget Toolkit"
org.eclipse.webdav (3.0.0) ""
org.eclipse.xsd (2.0.0.200406280827) ""
org.eclipse.xsd.doc (2.0.0.200406280827) ""
org.eclipse.xsd.edit (2.0.0.200406280827) ""
org.eclipse.xsd.editor (2.0.0.200406280827) ""
org.eclipse.xsd.test (2.0.0.200406280827) ""
org.junit (3.8.1) "JUnit Testing Framework"
*** User Preferences:
#Wed Aug 04 03:31:06 CEST 2004
@org.eclipse.update.scheduler=3.0.0
/instance/org.eclipse.jdt.ui/tabWidthPropagated=true
/instance/org.eclipse.help.ui/browser.maximized=false
/instance/org.eclipse.ve.java.core/PALETTE_STATE=4
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_LIB=C\:/Programme/Java/j2sdk1.4.2_01/jre/lib/r t.jar
/instance/org.eclipse.ve.java.core/PALETTE_WIDTH=99
/instance/org.eclipse.team.ui/org.eclipse.team.ui.sychronizi ng_default_participant_sec_id=1089992204265
/instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.update.scheduler/enabled=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_SRCROOT=
@org.eclipse.help.ui=3.0.0
@org.eclipse.ve.java.core=1.0.0
file_export_version=3.0
@org.eclipse.pde.core=3.0.0
@org.eclipse.jdt.ui=3.0.0
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.templat es_migrated=true
/instance/org.eclipse.team.cvs.ui/pref_first_startup=false
/instance/org.eclipse.pde.core/platform_path=c\:\\Programme\ \eclipse
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_SRC=C\:/Programme/Java/j2sdk1.4.2_01/src.zip
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.ECLIPSE_HOME=c\:/Programme/eclipse
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.codeComp lete.visibilityCheck=enabled
@org.eclipse.jdt.launching=3.0.0
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.code_te mplates_migrated=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocat ions= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<javadoclocation>\r\n<location_01
path\="C\:/Programme/Java/j2re1.4.2_01/lib/ext/localedata.jar "
url\="http\://java.sun.com/j2se/1.4.2/docs/api"/>\r\n<location_01
path\="C\:/Programme/Java/j2sdk1.4.2_01/jre/lib/jce.jar"
path\="C\:/Programme/Java/j2re1.4.2_03/lib/jsse.jar"
path\="C\:/Programme/Java/j2sdk1.4.2_01/jre/lib/jsse.jar"
path\="C\:/Programme/Java/j2re1.4.2_03/lib/ext/ldapsec.jar"
path\="C\:/Programme/Java/j2re1.4.2_01/lib/ext/dnsns.jar"
path\="C\:/Programme/Java/j2sdk1.4.2_01/jre/lib/sunrsasign.jar "
path\="C\:/Programme/Java/j2re1.4.2_03/lib/ext/sunjce_provider.jar "
path\=" C\:/Programme/Java/j2sdk1.4.2_01/jre/lib/ext/sunjce_provider .jar "
path\="C\:/Programme/Java/j2sdk1.4.2_01/jre/lib/charsets.jar "
path\="C\:/Programme/Java/j2re1.4.2_01/lib/jce.jar"
path\="C\:/Programme/Java/j2re1.4.2_01/lib/jsse.jar"
path\="C\:/Programme/Java/j2re1.4.2_01/lib/ext/sunjce_provider.jar "
path\="C\:/Programme/Java/j2sdk1.4.2_01/jre/lib/ext/dnsns.jar "
path\="C\:/Programme/Java/j2sdk1.4.2_01/jre/lib/ext/ldapsec.jar "
path\="C\:/Programme/Java/j2re1.4.2_03/lib/ext/dnsns.jar"
path\="C\:/Programme/Java/j2re1.4.2_03/lib/jce.jar"
path\="C\:/Programme/Java/j2re1.4.2_01/lib/rt.jar"
path\="C\:/Programme/Java/j2re1.4.2_01/lib/ext/ldapsec.jar"
path\="C\:/Programme/Java/j2sdk1.4.2_01/jre/lib/rt.jar"
path\="C\:/Programme/Java/j2re1.4.2_03/lib/sunrsasign.jar"
path\="C\:/Programme/Java/j2re1.4.2_01/lib/sunrsasign.jar"
path\="C\:/Programme/Java/j2re1.4.2_01/lib/charsets.jar"
path\="C\:/Programme/Java/j2re1.4.2_03/lib/rt.jar"
path\="C\:/Programme/Java/j2sdk1.4.2_01/jre/lib/ext/localedata.jar "
url\="http\://java.sun.com/j2se/1.4.2/docs/api"/>\r\n</javadoclocation>\r\n
/instance/org.eclipse.ant.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.team.ui/org.eclipse.team.ui.sychronizi ng_default_participant=org.eclipse.team.cvs.ui.cvsworkspace- participant
/instance/org.eclipse.jdt.ui/Refactoring.ErrorPage.severityT hreshold=2
/instance/org.eclipse.ui/showIntro=false
@org.eclipse.team.cvs.core=3.0.0
@org.eclipse.jdt.core=3.0.0
/instance/org.eclipse.help.ui/browser.y=87
/instance/org.eclipse.help.ui/browser.x=66
/instance/org.eclipse.help.ui/browser.w=1024
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ code_templates= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<templates/>
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.polylog|org.eclipse.jdt.launching.JRE_CONTAINER= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<classpath>\r\n<classpathentry
sourcepath\="C\:/Programme/Java/j2sdk1.4.2_01/src.zip" kind\="lib"
path\="C\:/Programme/Java/j2sdk1.4.2_01/jre/lib/rt.jar"/>\r\n <classpathentry
path\="C\:/Programme/Java/j2sdk1.4.2_01/jre/lib/sunrsasign.jar "/>\r\n<classpathentry
path\="C\:/Programme/Java/j2sdk1.4.2_01/jre/lib/jsse.jar"/ >\r\n<classpathentry
path\="C\:/Programme/Java/j2sdk1.4.2_01/jre/lib/jce.jar"/>\r\n <classpathentry
path\="C\:/Programme/Java/j2sdk1.4.2_01/jre/lib/charsets.jar "/>\r\n<classpathentry
kind\="lib"
path\="C\:/Programme/Java/j2sdk1.4.2_01/jre/lib/ext/dnsns.jar "/>\r\n<classpathentry
kind\="lib"
path\="C\:/Programme/Java/j2sdk1.4.2_01/jre/lib/ext/ldapsec.jar "/>\r\n<classpathentry
kind\="lib"
path\="C\:/Programme/Java/j2sdk1.4.2_01/jre/lib/ext/localedata.jar "/>\r\n<classpathentry
kind\="lib"
path\=" C\:/Programme/Java/j2sdk1.4.2_01/jre/lib/ext/sunjce_provider .jar "/>\r\n</classpath>\r\n
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder. resourceCopyExclusionFilter=*.launch
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.Test-Project|org.eclipse.jdt.launching.JRE_CONTAI NER= <?xml
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
/instance/org.eclipse.jdt.ui/fontPropagated=true
/instance/org.eclipse.update.scheduler/day=Every day
@org.eclipse.ui=3.0.0
/instance/org.eclipse.jdt.launching/org.eclipse.jdt.launchin g.PREF_VM_XML= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<vmSettings
defaultVM\=" 57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType 13,1089989237500 "
defaultVMConnector\="">\r\n<vmType
id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType ">\r\n<vm
id\="0" name\="j2re1.4.2_03" path\="C\:\\Programme\\Java\\j2re1.4.2_03"
javadocURL\="http\://java.sun.com/j2se/1.4.2/docs/api"/>\r\n<vm
id\="1089989237484" name\="j2re1.4.2_01"
path\="C\:\\Programme\\Java\\j2re1.4.2_01"
id\="1089989237500" name\="j2sdk1.4.2_01"
path\="C\:\\Programme\\Java\\j2sdk1.4.2_01"
javadocURL\="http\://java.sun.com/j2se/1.4.2/docs/api"/>\r\n</vmType>\r\n</vmSettings>\r\n
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JUNIT_HOME=c\:/Programme/eclipse/plugins/org.junit _3.8.1
/instance/org.eclipse.team.cvs.ui/pref_ext_connection_method _proxy=pserver
@org.eclipse.ui.workbench=3.0.0
/instance/org.eclipse.help.ui/browser.h=768
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ templates= <?xml
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.formatterpro files.version=6
/instance/org.eclipse.team.ui/org.eclipse.team.ui.first_time =false
/instance/org.eclipse.ve.java.core/VISUAL_CLASS_WIZARD_SELEC TED_ELEMENT_KEY=org.eclipse.ve.jfc.swing.cat-Frame-javax.swi ng.JFrame
/instance/org.eclipse.ui.workbench/ENABLED_DECORATORS=org.ec lipse.jdt.ui.override.decorator\:true,org.eclipse.pde.ui.bin aryProjectDecorator\:false,org.eclipse.team.cvs.ui.decorator \:true,org.eclipse.ui.LinkedResourceDecorator\:true,
/instance/org.eclipse.jdt.core//org.eclipse.jdt.core.classpa thContainer.Test-Project|SWT_CONTAINER/JFACE= <?xml
sourcepath\=" /c\:/Programme/eclipse/plugins/org.eclipse.platform.source.w in32.win32.x86_3.0.0/src/org.eclipse.swt.win32_3.0.0/ws/win3 2/swtsrc.zip "
kind\="lib"
path\=" C\:/Programme/eclipse/plugins/org.eclipse.swt.win32_3.0.0/ws /win32/swt.jar "/>\r\n<classpathentry
sourcepath\=" /c\:/Programme/eclipse/plugins/org.eclipse.platform.source_3 .0.0/src/org.eclipse.jface_3.0.0/jfacesrc.zip "
kind\="lib"
path\=" C\:/Programme/eclipse/plugins/org.eclipse.jface_3.0.0/jface. jar "/>\r\n<classpathentry
sourcepath\=" /c\:/Programme/eclipse/plugins/org.eclipse.platform.source_3 .0.0/src/org.eclipse.jface.text_3.0.0/jfacetextsrc.zip "
kind\="lib"
path\=" C\:/Programme/eclipse/plugins/org.eclipse.jface.text_3.0.0/j facetext.jar "/>\r\n<classpathentry
sourcepath\=" /c\:/Programme/eclipse/plugins/org.eclipse.platform.source_3 .0.0/src/org.eclipse.core.runtime_3.0.0/runtimesrc.zip "
kind\="lib"
path\=" C\:/Programme/eclipse/plugins/org.eclipse.core.runtime_3.0.0 /runtime.jar "/>\r\n<classpathentry
sourcepath\=" /c\:/Programme/eclipse/plugins/org.eclipse.platform.source_3 .0.0/src/org.eclipse.core.runtime.compatibility_3.0.0/compat ibilitysrc.zip "
kind\="lib"
path\=" C\:/Programme/eclipse/plugins/org.eclipse.core.runtime.compa tibility_3.0.0/compatibility.jar "/>\r\n<classpathentry
sourcepath\=" /c\:/Programme/eclipse/plugins/org.eclipse.platform.source_3 .0.0/src/org.eclipse.osgi_3.0.0/osgisrc.zip "
kind\="lib"
path\=" C\:/Programme/eclipse/plugins/org.eclipse.osgi_3.0.0/osgi.ja r "/>\r\n</classpath>\r\n
/instance/org.eclipse.update.scheduler/hour=1\:00 AM
@org.eclipse.ant.ui=3.0.0
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Co urier
New|10|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Courier New;
@org.eclipse.team.cvs.ui=3.0.0
@org.eclipse.team.ui=3.0.0
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.team.cvs.core/repositories/%pserver%joe@localhost%E%%Datenbanken%CVS_repo%projects/location=\:pserver\:joe@localhost\:E\:/Datenbanken/CVS_repo/projects
/instance/org.eclipse.team.cvs.ui/pref_text_ksubst=-kkv
/instance/org.eclipse.ant.ui/useAnnotationsPrefPage=true
*** Update Manager Log:
Configuration=Fri Jul 16 16:40:31 CEST 2004
Is current configuration=false
Configuration=Wed Jul 28 16:29:31 CEST 2004
Configuration=Wed Jul 28 19:24:04 CEST 2004
Configuration=Wed Jul 28 23:27:51 CEST 2004
Configuration=Sat Jul 31 13:42:01 CEST 2004
Is current configuration=true
Re: Designtime: Components don't show up [message #54400 is a reply to message #54312] Wed, 04 August 2004 05:37 Go to previous messageGo to next message
Originally posted by: frank.senn.shunny.de
I experiences a similar problem (or the same?).
Creating a new visual class leads to neverending 'Loading'.
The process remains at 25%, I've waited for half an hour,
but nothing happened.
I couldn't finishing the 'loading', even if I exited Eclipse.
I had to finish Eclipse over the Taskmanager.
The two tasks are
- Create Remote VM for Visual Editor for Java
- Setup Java Vusual Editor
Eclipse Version: 3.0.0 Build id: 200406251208
EMF Service Data Objects (SDO) Version: 2.0.0 Build id: 200406280827
Eclipse Graphical Editing Framework Version: 3.0 Build id: 200406251257
Java EMF Model Version: 1.0.0 Build id: 200407301410
Visual Editor Version: 1.0.0 Build id: 200407301410
W2000
Java SDK 1.4.2_03
Frank
Re: Designtime: Components don't show up [message #54534 is a reply to message #54400] Wed, 04 August 2004 11:30 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Frank,
Is there anything in your .log file?
Do you have a firewall installed? If so you need to enable localhost
TCP/IP access. If you have SINE installed you need to allow javaw.exe to
have access.
If this is repeatable and the .log doesn't tell us anything, try this:
From a commandline, start eclipse with the -consolelog option.
Then when it appears to be locked, from the command window that pops up
hit ctrl+Break. This should create a trace log in your current
directory. Send that trace to me.
Thanks, Rich Kulp
Re: Designtime: Components don't show up [message #54567 is a reply to message #54312] Wed, 04 August 2004 12:04 Go to previous messageGo to next message
Joe,
What you get shouldn't happen. So I need some more info. I want to send
to you a replacement plugin with some debugging trace stmts in it to
help me figure out what is going on.
What I need from you is your email address that I can send to. You can
use my reply address to this append except remove the NO.SPAM. from it.
Thanks, Rich Kulp
Re: Designtime: Components don't show up [message #54728 is a reply to message #54534] Thu, 05 August 2004 02:24 Go to previous messageGo to next message
Hi, thanks for helping,
here is an entry in the .log-file:
!ENTRY org.eclipse.osgi Aug 05, 2004 08:03:22.515
!MESSAGE Error stopping bundles. Cycle(s) found:
[[org.eclipse.core.runtime,org.eclipse.update.configurator,o rg.eclipse.core.runtime.compatibility]].
here is the trace from the command-window:
"Worker-8" prio=5 tid=0x1871ca20 nid=0x3c4 in Object.wait()
[1a23f000..1a23fd88]
at java.lang.Object.wait(Native Method)
- waiting on <0x10798bc0> (a
org.eclipse.core.internal.jobs.WorkerPool)
org.eclipse.core.internal.jobs.WorkerPool.sleep(WorkerPool.j ava:166)
- locked <0x10798bc0> (a org.eclipse.core.internal.jobs.WorkerPool)
org.eclipse.core.internal.jobs.WorkerPool.startJob(WorkerPoo l.java:19
3)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:59)
"Worker-7" prio=5 tid=0x188b9710 nid=0x484 in Object.wait()
[1a1ff000..1a1ffd88]
3)
"org.eclipse.jdt.internal.ui.text.JavaReconciler" daemon prio=2
tid=0x18911680 n
id=0x474 in Object.wait() [1a05f000..1a05fd88]
- waiting on <0x1228dd90> (a
org.eclipse.jface.text.reconciler.DirtyRegi
onQueue)
org.eclipse.jface.text.reconciler.AbstractReconciler$Backgro undThread
..run(AbstractReconciler.java:176)
- locked <0x1228dd90> (a
org.eclipse.jface.text.reconciler.DirtyRegionQu
eue)
" CodeGen::org.eclipse.ve.internal.java.codegen.java.JavaSourc eSynchronizer[JustT
esting.java]" daemon prio=2 tid=0x18705200 nid=0x450 in Object.wait()
[1a01f000.
..1a01fd88]
- waiting on <0x122830b8> (a java.lang.Object)
org.eclipse.ve.internal.java.codegen.java.JavaSourceSynchron izer$Back
groundThread.run(JavaSourceSynchronizer.java:155)
- locked <0x122830b8> (a java.lang.Object)
" CodeGen::org.eclipse.ve.internal.java.codegen.util.StrategyW orker "
daemon prio=
2 tid=0x18837e48 nid=0x304 in Object.wait() [19fdf000..19fdfd88]
- waiting on <0x1227c460> (a
trategyWorker)
at java.lang.Object.wait(Unknown Source)
org.eclipse.ve.internal.java.codegen.util.StrategyWorker.wai tForStrat
egy(StrategyWorker.java:141)
- locked <0x1227c460> (a
egyWorker)
org.eclipse.ve.internal.java.codegen.util.StrategyWorker.run (Strategy
Worker.java:109)
at java.lang.Thread.run(Unknown Source)
daemon prio=
2 tid=0x18919c20 nid=0x3d8 in Object.wait() [19f9f000..19f9fd88]
- waiting on <0x1227c538> (a
trategyWorker)
- locked <0x1227c538> (a
egyWorker)
Worker.java:109)
"Worker-6" prio=5 tid=0x18827a08 nid=0x294 in Object.wait()
[19f2f000..19f2fd88]
3)
"Worker-5" prio=5 tid=0x19440dc8 nid=0x480 waiting for monitor entry
[19edf000..
19edfd88]
org.eclipse.jem.internal.proxy.core.ProxyPlugin.getContainer Configura
tions(ProxyPlugin.java:716)
- waiting to lock <0x121c3a30> (a
oxyPlugin)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implement
ation(ProxyLaunchSupport.java:405)
ation(ProxyLaunchSupport.java:291)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoNature.cr eateRegis
try(BeaninfoNature.java:368)
org.eclipse.jem.internal.beaninfo.adapters.CreateRegistryJob Handler.d
oCreateRegistry(CreateRegistryJobHandler.java:154)
org.eclipse.jem.internal.beaninfo.adapters.CreateRegistryJob Handler.p
rocessCreateRegistry(CreateRegistryJobHandler.java:109)
org.eclipse.jem.internal.beaninfo.adapters.UICreateRegistryJ obHandler
..processCreateRegistry(UICreateRegistryJobHandler.java:52)
org.eclipse.jem.internal.beaninfo.adapters.CreateRegistryJob Handler.c
reateRegistry(CreateRegistryJobHandler.java:75)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoNature.ge tRegistry
(BeaninfoNature.java:349)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoNature$6. getRegist
ry(BeaninfoNature.java:287)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoAdapterFa ctory.get
Registry(BeaninfoAdapterFactory.java:78)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.getRe
gistry(BeaninfoClassAdapter.java:275)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.apply
ExtensionDocument(BeaninfoClassAdapter.java:512)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.intro
spect(BeaninfoClassAdapter.java:437)
spectIfNecessary(BeaninfoClassAdapter.java:394)
org.eclipse.jem.java.impl.JavaClassImpl.getEAnnotations(Java ClassImpl
..java:339)
org.eclipse.ve.internal.cde.emf.ClassDecoratorSourceIterator .findDeco
rator(ClassDecoratorSourceIterator.java:37)
org.eclipse.ve.internal.cde.emf.ClassDecoratorIterator.initi alize(Cla
ssDecoratorIterator.java:47)
org.eclipse.ve.internal.cde.emf.ClassDecoratorSourceIterator . <init>(C
lassDecoratorSourceIterator.java:33)
org.eclipse.ve.internal.cde.emf.ClassDecoratorFeatureAccess. getDecora
torWithFeature(ClassDecoratorFeatureAccess.java:67)
org.eclipse.ve.internal.java.codegen.java.rules.InstanceVari ableCreat
ionRule.getDefaultBooleanValue(InstanceVariableCreationRule. java:70)
ionRule.isModelled(InstanceVariableCreationRule.java:97)
org.eclipse.ve.internal.java.codegen.java.rules.InstanceVari ableRule.
isModelled(InstanceVariableRule.java:121)
ignoreVariable(InstanceVariableRule.java:43)
org.eclipse.ve.internal.java.codegen.java.TypeVisitor.visit( TypeVisit
or.java:154)
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.visitT
ype(JavaBeanModelBuilder.java:406)
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.build(
JavaBeanModelBuilder.java:372)
Document(JavaSourceTranslator.java:876)
- locked <0x1226d3e0> (a java.lang.Object)
"Worker-4" prio=5 tid=0x19440c60 nid=0x288 runnable [19e5f000..19e5fd88]
at java.util.HashMap$HashIterator.nextEntry(Unknown Source)
at java.util.HashMap$EntryIterator.next(Unknown Source)
org.eclipse.jem.internal.proxy.core.ProxyPlugin.orderPlugins (ProxyPlu
gin.java:392)
org.eclipse.jem.internal.proxy.core.ProxyPlugin.processContr ibutionEx
tensionPoint(ProxyPlugin.java:799)
org.eclipse.jem.internal.proxy.core.ProxyPlugin.processProxy Contribut
ionExtensionPoint(ProxyPlugin.java:736)
- locked <0x121c3a30> (a
tions(ProxyPlugin.java:717)
ation(ProxyLaunchSupport.java:223)
Setup$CreateRegistry.run(JavaVisualEditorPart.java:1330)
tid=0x009b27d0 n
id=0x37c in Object.wait() [192bf000..192bfd88]
- waiting on <0x118699d8> (a
onQueue)
- locked <0x118699d8> (a
eue)
tid=0x186ebb70 n
id=0x4e4 in Object.wait() [1927f000..1927fd88]
- waiting on <0x116c6640> (a
onQueue)
- locked <0x116c6640> (a
eue)
"Java indexing" daemon prio=4 tid=0x18300cd0 nid=0x2c8 in Object.wait()
[191ff00
0..191ffd88]
- waiting on <0x10de68c8> (a
org.eclipse.jdt.internal.core.search.indexi
ng.IndexManager)
org.eclipse.jdt.internal.core.search.processing.JobManager.r un(JobMan
ager.java:338)
- locked <0x10de68c8> (a
org.eclipse.jdt.internal.core.search.indexing.I
ndexManager)
"Reference Cleaner - 2" prio=7 tid=0x182f0b08 nid=0x380 in Object.wait()
[1908f0
00..1908fd88]
- waiting on <0x10d60590> (a java.lang.ref.ReferenceQueue$Lock)
at java.lang.ref.ReferenceQueue.remove(Unknown Source)
- locked <0x10d60590> (a java.lang.ref.ReferenceQueue$Lock)
org.eclipse.jface.action.ActionContributionItem$ImageCache$R eferenceC
leanerThread.run(ActionContributionItem.java:207)
"Reference Cleaner - 1" prio=7 tid=0x18309138 nid=0x220 in Object.wait()
[1904f0
00..1904fd88]
- waiting on <0x10d60600> (a java.lang.ref.ReferenceQueue$Lock)
- locked <0x10d60600> (a java.lang.ref.ReferenceQueue$Lock)
"Start Level Event Dispatcher" daemon prio=5 tid=0x183a5a20 nid=0x494 in
Object.
wait() [184ff000..184ffd88]
- waiting on <0x105dcb10> (a
org.eclipse.osgi.framework.eventmgr.EventTh
read)
org.eclipse.osgi.framework.eventmgr.EventThread.getNextEvent (EventThr
ead.java:162)
- locked <0x105dcb10> (a
org.eclipse.osgi.framework.eventmgr.EventThread.run(EventThr ead.java:
100)
"Framework Event Dispatcher" daemon prio=5 tid=0x182a5b18 nid=0x338 in
Object.wa
it() [184bf000..184bfd88]
- waiting on <0x105c7c80> (a
read)
ead.java:162)
- locked <0x105c7c80> (a
100)
"Signal Dispatcher" daemon prio=10 tid=0x0091def8 nid=0x120 waiting on
condition
[0..0]
"Finalizer" daemon prio=9 tid=0x0091b080 nid=0x38c in Object.wait()
[1816f000..1
816fd88]
- waiting on <0x104f79c8> (a java.lang.ref.ReferenceQueue$Lock)
- locked <0x104f79c8> (a java.lang.ref.ReferenceQueue$Lock)
at java.lang.ref.Finalizer$FinalizerThread.run(Unknown Source)
"Reference Handler" daemon prio=10 tid=0x00919bf8 nid=0x4e0 in
Object.wait() [18
12f000..1812fd88]
- waiting on <0x104f7a30> (a java.lang.ref.Reference$Lock)
at java.lang.ref.Reference$ReferenceHandler.run(Unknown Source)
- locked <0x104f7a30> (a java.lang.ref.Reference$Lock)
"main" prio=7 tid=0x00235700 nid=0x14c runnable [6f000..6fc3c]
at org.eclipse.swt.internal.win32.OS.WaitMessage(Native Method)
at org.eclipse.swt.widgets.Display.sleep(Display.java:3076)
org.eclipse.ui.application.WorkbenchAdvisor.eventLoopIdle(Wo rkbenchAd
visor.java:344)
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1378)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.jav
a:254)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformAct
ivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.ja
va:273)
va:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
"VM Thread" prio=5 tid=0x009591f8 nid=0x2d0 runnable
"VM Periodic Task Thread" prio=10 tid=0x0023ec60 nid=0x340 waiting on
condition
"Suspend Checker Thread" prio=10 tid=0x0091d3a0 nid=0x368 runnable
Re: Designtime: Components don't show up [message #54799 is a reply to message #54312] Thu, 05 August 2004 11:47 Go to previous messageGo to next message
We've found the problem with Joe's stuff. It was due to having the EMF
java examples installed (these are from EMF, not JEM). They conflicted
with our code. So the workaround is to not have the EMF java examples
installed. I have opened a defect for us to fix so that they don't
collide like that.
Thanks, Rich Kulp
Re: Designtime: Components don't show up [message #54826 is a reply to message #54728] Thu, 05 August 2004 12:27 Go to previous messageGo to next message
Frank,
It looks like somehow the code got into a infinite loop. I can't figure
out how that could of happened.
I'm going to send you a plugin replacement that should break out of the
infinite loop sooner.
I'm using the email address you used for this append.
Thanks, Rich Kulp
Re: Designtime: Components don't show up [message #54934 is a reply to message #54799] Thu, 05 August 2004 14:17 Go to previous messageGo to next message
Saw that also... Will take thoses examles out......
Thanks in Advance...
IchBin
_____________________________________________
'Black holes are where God divided by zero.'
-Steven Wright, comedian (1955- )
"Rich Kulp" <richkulp@NO.SPAM.us.ibm.com> wrote in message
news:cetkmb$6k6$1@eclipse.org...
> collide like that.
> Thanks, Rich Kulp
Re: Designtime: Components don't show up [message #55037 is a reply to message #54826] Fri, 06 August 2004 02:08 Go to previous messageGo to next message
Hi Rich,
now it works.
Frank
Re: Designtime: Components don't show up [message #55059 is a reply to message #55037] Fri, 06 August 2004 10:20 Go to previous message
Good. You can keep that patch until the next driver after today of VE.
I'll roll that fix into the latest VE code.
For everybody else, the problem was something about Frank's installation
caused a piece of code to go into an infinite loop. The path I sent to
him did some extra tests and was able to break out of the loop.
Thanks, Rich Kulp
Re: Designtime: Components don't show up [message #596675 is a reply to message #54312] Wed, 04 August 2004 05:37 Go to previous message
The two tasks are
W2000
Java SDK 1.4.2_03
Frank
Re: Designtime: Components don't show up [message #596732 is a reply to message #54400] Wed, 04 August 2004 11:30 Go to previous message
Frank,
have access.
Thanks, Rich Kulp
Re: Designtime: Components don't show up [message #596738 is a reply to message #54312] Wed, 04 August 2004 12:04 Go to previous message
Joe,
Thanks, Rich Kulp
Re: Designtime: Components don't show up [message #596774 is a reply to message #54534] Thu, 05 August 2004 02:24 Go to previous message
3)
3)
tid=0x18911680 n
onQueue)
eue)
[1a01f000.
..1a01fd88]
daemon prio=
trategyWorker)
egyWorker)
Worker.java:109)
daemon prio=
trategyWorker)
egyWorker)
Worker.java:109)
3)
[19edf000..
19edfd88]
oxyPlugin)
..java:339)
or.java:154)
gin.java:392)
tid=0x009b27d0 n
onQueue)
eue)
tid=0x186ebb70 n
onQueue)
eue)
[191ff00
0..191ffd88]
ng.IndexManager)
ager.java:338)
ndexManager)
[1908f0
00..1908fd88]
[1904f0
00..1904fd88]
Object.
read)
ead.java:162)
100)
Object.wa
read)
ead.java:162)
100)
condition
[0..0]
[1816f000..1
816fd88]
Object.wait() [18
12f000..1812fd88]
visor.java:344)
a:254)
ivator.java:335)
va:273)
va:129)
condition
Re: Designtime: Components don't show up [message #596807 is a reply to message #54312] Thu, 05 August 2004 11:47 Go to previous message
collide like that.
Thanks, Rich Kulp
Re: Designtime: Components don't show up [message #596818 is a reply to message #54728] Thu, 05 August 2004 12:27 Go to previous message
Frank,
Thanks, Rich Kulp
Re: Designtime: Components don't show up [message #596857 is a reply to message #54799] Thu, 05 August 2004 14:17 Go to previous message
IchBin
> collide like that.
> Thanks, Rich Kulp
Re: Designtime: Components don't show up [message #596897 is a reply to message #54826] Fri, 06 August 2004 02:08 Go to previous message
Hi Rich,
now it works.
Frank
Re: Designtime: Components don't show up [message #596910 is a reply to message #55037] Fri, 06 August 2004 10:20 Go to previous message
Thanks, Rich Kulp
Previous Topic:Tutorials for VE
Next Topic:Need ve Help
Current Time: Mon Nov 03 18:47:07 EST 2025
Powered by FUDForum. Page generated in 0.07896 seconds
