Home » Modeling » GMF (Graphical Modeling Framework) » mindmap won't run
mindmap won't run [message #54227] Fri, 22 September 2006 11:47 Go to next message
Have gotten to the end of the mindmap tutorial but can't get it to work.
I've followed everything and it all seems to have worked fine.
I then goto Run|Run.. and create a new Eclpise application and don't
change any settings. Then within th new workbench I goto the examples part
and there is the Mindmap Diagram icon, I highlight it and click Next,
within the next window is a heading for Create Mindmap Diagram, printed
under it is 'The folder is empty' witheverything else blank.
Do I need some kind of specific plug-ins for this to work? XML plug-ins or
something so the new workbench can set up properly?
Checked error logs and nothing.
The only other optoin within exanples is ecore, which clicking on has the
same results.
Please help.
Re: mindmap won't run [message #54304 is a reply to message #54227] Fri, 22 September 2006 12:36 Go to previous messageGo to next message
To check completeness of your environment, get to the third tab, "Plug-ins"
in the launch configuration (Run->Run...) and hit "Validatge plug-in set".
Though I doubt that's the reason. You can try to find out specific cause
with debug, e.g. start with MindmapNewDiagramWizard#performFinish method.
Artem
"Gaff" <conorgaff@hotmail.com> wrote in message
news:6bde05f6c237f7ccc73d30ea1804dcaf$1@www.eclipse.org...
> same results.
> Please help.
Re: mindmap won't run [message #54330 is a reply to message #54227] Fri, 22 September 2006 12:43 Go to previous message
Needed a new gmf project first, right click this, then opened the mindmap
file from examples to get it working.
Previous Topic:TargetMetaFeature
Next Topic:Download of "UML2 Class Diagram"
Current Time: Thu Nov 06 15:52:50 EST 2025
Powered by FUDForum. Page generated in 0.03499 seconds
