Home » General (non-technical) » Eclipse Foundation » Is it possible to get typed key in webpage but not only get typed key in window?
Is it possible to get typed key in webpage but not only get typed key in window? [message #54224] Sat, 31 May 2008 04:06 Go to next message
Originally posted by: jiaxinl.cn.ibm.com
Does eclipse has such a API as below:
SWT's window?
Considerable two kinds of API:
One API is has a webpage's key event such as
org.eclipse.swt.events.KeyEvent;
The other API would be getting the web source after typing a key in the
web.
Is there anyone who knows this?
Or this is forbidden by Eclipse or Microsoft's API?
I would very appreciate your guidance.
Re: Is it possible to get typed key in webpage but not only get typed key in window? [message #54250 is a reply to message #54224] Sat, 31 May 2008 07:19 Go to previous message
--------------050000080901050105030105
George,
You're asking using inappropriate newsgroup for a technical question
given that this newsgroup is intended to discuss the operations of the
Eclipse foundation as an organization.
Maybe this article will help:
http://www.eclipse.org/articles/Article-SWT-browser-widget/b rowser.html
You might want to check out what kinds of things are possible using WTP:
http://www.eclipse.org/webtools/
> in SWT's window?
> the web.
<html>
<head>
http-equiv="Content-Type">
</head>
George,<br>
<br>
Previous Topic:Eclipse Summit Europe CFP
Next Topic:BIRT 2.3 Webinar - June 24
Current Time: Fri Nov 21 08:55:07 EST 2025
Powered by FUDForum. Page generated in 1.15136 seconds
