| Gallery: make getGroup() public? [message #54199] |
Fri, 06 June 2008 05:19  |
Question for Nicolas I guess!
Can Gallery.getGroup() be exposed as public??
I need this for drag'n'drop support... obviously there's no GalleryItem in
empty areas so can't getParentItem.
Justin
| Re: Gallery: make getGroup() public? [message #54738 is a reply to message #54438] |
Sat, 21 June 2008 05:55  |
Hi Justin,
getGroup() is now public, see latest version on CVS.
Nicolas
Justin Dolezy a écrit :
> Hi Nicolas,
> I can't remember what cut of the code I have but I did try the 2nd idea
> of changing getItem and, as you say, it broke things big time. I made
> getGroup public and this did the trick - this is what I'd prefer as it'd
> be the most straightforward change with no side effects on others.
> Justin
> Nicolas Richeton wrote:
>> There are 2 options here :
>> * make getGroup public
>> * change getItem so it returns the group if there is no child item
>> under the mouse. But this can break some applications.
>> I'm not sure which one is the best right now. I have to check Table
>> and Tree API.
>> Would this 2 options work for you ?
>> Nicolas
>>> GalleryItem in empty areas so can't getParentItem.
>>> Thanks,
>>> Justin
| Re: Gallery: make getGroup() public? [message #590416 is a reply to message #54199] |
Wed, 11 June 2008 04:04  |
* change getItem so it returns the group if there is no child item under
I'm not sure which one is the best right now. I have to check Table and
Tree API.
Nicolas
> Justin
| Re: Gallery: make getGroup() public? [message #590425 is a reply to message #54413] |
Wed, 11 June 2008 05:31  |
Hi Nicolas,
I can't remember what cut of the code I have but I did try the 2nd idea of
Justin
> Tree API.
> Nicolas
>> Thanks,
>> Justin
| Re: Gallery: make getGroup() public? [message #590548 is a reply to message #54438] |
Hi Justin,
Nicolas
> Hi Nicolas,
> Justin
>> and Tree API.
>> Nicolas
>>> Thanks,
>>> Justin
FUDForum. Page generated in 0.03735 seconds
