Home » Eclipse Projects » Buckminster dev » Re: [buckminster-dev] help with CVS
Re: [buckminster-dev] help with CVS [message #4822] Tue, 19 February 2008 10:22
No, I don't normally keep those ports open. But I can enable it again.
- thomas
Todd_Lee@amis.com wrote:
> Hi again Thomas,
> I was just going to take a look at the test setup that you created to
> confirm things like structure etc, but it seems that anonymous access to
> the tada repo isn't available (actually, it's reporting a timeout). Should
> I still be able to access the following CVSROOT? (
> :pserver:anonymous@www.tada.se:/cvsroot/test)
> Thanks
> Todd
> Thomas Hallgren
> <thomas@tada.se>
> Sent by: To
> buckminster-dev-b Buckminster developer discussions
> ounces@eclipse.or <buckminster-dev@eclipse.org>
> g cc
> Subject
> 02/15/2008 05:35 Re: [buckminster-dev] help with CVS
> PM
> Please respond to
> Buckminster
> developer
> discussions
> <buckminster-dev@
> eclipse.org>
> Hi Todd,
>> Oh, and so as not to create any wild goose chases, I did find docs last
>> night that confirmed that eclipse cvs should be fine with cvs going all
>> the way back to 1.11.1, so I'm assuming our 1.11.3 shouldn't be a
> problem.
> It should not. And if Eclipse can do things like check-out, then
> Buckminster should be fine too. Our
> CVS support is just a thin layer on top of everything that is included in
> the Eclipse CVS team provider.
>> If you have any other suggestions, please feel free to fire them off.
> The only thing I can think of at this point is to make really sure that the
> repositories (the one I
> published) and yours are structured the same way.
>> One question - is there any way to get more debug info out of the
>> resolution stage? I have all three log settings in the prefs set to full
>> DEBUG and there's still not a whole lot of information in the console or
>> the .metadata/.log file.
>> It would probably be helpful if the debug statements actually printed
>> out checks for the files inside the cvs path that buckminster uses to
>> poll for metadata for a given component type. Could give us a better
>> idea of where it's failing?
> Right. Cases like this really highlights the need for more extensive
> logging. I'll see what I can do
> about that. You're my only eyes into what's happening here so it seems fair
> that I help you see some
> more relevant info :-)
> Thomas Hallgren
> _______________________________________________
> buckminster-dev mailing list
> https://dev.eclipse.org/mailman/listinfo/buckminster-dev
> AMI Semiconductor - "Silicon Solutions for the Real World"
> NOTICE:
> This electronic message contains information that may be confidential or privileged. The information is intended for the use of the individual or entity named above. If you are not the intended recipient, please be aware that any disclosure, copying, distribution or use of the contents of this information is prohibited. If you received this electronic message in error, please notify the sender and delete the copy you received.
Previous Topic:Re: [buckminster-dev] help with CVS
Next Topic:Re: [buckminster-dev] help with CVS
Current Time: Wed Nov 05 11:49:13 EST 2025
Powered by FUDForum. Page generated in 0.02727 seconds
