Home » Eclipse Projects » Nebula » CDateTime drop down calendar issue
CDateTime drop down calendar issue [message #54120] Mon, 02 June 2008 08:53 Go to next message
Hi.
I'm trying to integrate the CDateTime widget with DROP_DOWN style on an
RCP application on Linux. The buttons on the drop down calendar are not
working, clicking on a day doesn't change the date, nor it is possible
to change month or any other action.
I've ran the CDateTime snippet and it works perfectly, however if placed
without other changes on the RCP app. it doesn't work. No exceptions, no
messages, nothing at all. It simply doesn't work. Any hint on what may
be wrong with it ?
Marco.
Re: CDateTime drop down calendar issue [message #54147 is a reply to message #54120] Mon, 02 June 2008 09:18 Go to previous message
> be wrong with it ?
Ah, apparently I've hit bug #185739:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=185739
I don't know if it is a regression or what, my SWT version is 3349 and
it doesn't work. If I set SWT_MODAL_FIX_VERSION to 3400 the calendar works.
Marco.
Re: CDateTime drop down calendar issue [message #590295 is a reply to message #54120] Mon, 02 June 2008 09:18 Go to previous message
> be wrong with it ?
Marco.
Previous Topic:CDateTime drop down calendar issue
Next Topic:CTableTree
Current Time: Fri Nov 07 04:55:45 EST 2025
Powered by FUDForum. Page generated in 0.04109 seconds
