Home » Eclipse Projects » Technology Project and PMC » JAXB
| JAXB [message #54062] |
Thu, 15 May 2003 22:08  |
Originally posted by: viraf_bankwalla.yahoo.com
I was on Sun's site and came across the JAXB specs. Is there any plan on
providing JAXB support to this or another eclipse project?
I would like to be able to define schemas, use JAXB to create the supporting
classes, and an XML editor to create documents that conform to the schema.
Thanks.
- viraf
| Re: JAXB [message #54181 is a reply to message #54155] |
Fri, 16 May 2003 09:23   |
--------------90C792FD57E6556423AB7754
Content-Type: text/plain; charset=us-ascii
Viraf,
Yes, EMF can be used standalone. On your classpath you will need the common.jar,
ecore.jar, and ecore.xmi.jar from the org.eclipse.emf.common,
org.eclipse.emf.ecore, and org.eclipse.emf.ecore.xmi plugins, respectively. XSD
itself is based on Ecore and it runs standalone too.
EMF produces high quality model code that you can modify and subsequently
regenerate because it has a merging generator. EMF also generates a complete
application that includes reusable platform-neutral view support and an
Eclipse-based editor. EMF may not handle some schemas that JAXB can handle,
although the reverse may also be true. I'd suggest trying both approaches and
being your own judge. Here's a tutorial to describe the steps:
http://dev.eclipse.org/viewcvs/indextools.cgi/%7Echeckout%7E /emf-home/docs/xlibmod/xlibmod_main.html
Viraf Bankwalla wrote:
> Thanks - I'll check out EMF.
> Can EMF be used standalone (i.e. outside the eclipse environment)? What
> additional baggage do I need to carry if I use it outside eclipse? What are
> the pros/cons of using EMF over JAXB?
> - viraf
> "Luiz Marcelo" <lmap@canada.com> wrote in message
> news:ba1tgn$ld5$1@rogue.oti.com...
> > Check out www.eclipse.org/emf. It is **not** JAXB but it doesn't
> everything
> > you are asking for and much more.
> > "Viraf Bankwalla" <viraf_bankwalla@yahoo.com> wrote in message
> > news:ba1h7e$dth$1@rogue.oti.com...
> > > Hi,
> on
> > supporting
> schema.
> > > Thanks.
> > > - viraf
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Viraf,
<p>Yes, EMF can be used standalone. On your classpath you will need the
common.jar, ecore.jar, and ecore.xmi.jar from the org.eclipse.emf.common,
XSD itself is based on Ecore and it runs standalone too.
<p>EMF produces high quality model code that you can modify and subsequently
a complete application that includes reusable platform-neutral view support
and an Eclipse-based editor. EMF may not handle some schemas that
JAXB can handle, although the reverse may also be true. I'd suggest
trying both approaches and being your own judge. Here's a tutorial
<blockquote> <a href=" http://dev.eclipse.org/viewcvs/indextools.cgi/%7Echeckout%7E /emf-home/docs/xlibmod/xlibmod_main.html"> http://dev.eclipse.org/viewcvs/indextools.cgi/%7Echeckout%7E /emf-home/docs/xlibmod/xlibmod_main.html</a></blockquote>
<p>Viraf Bankwalla wrote:
<blockquote TYPE=CITE>Thanks - I'll check out EMF.
<p>Can EMF be used standalone (i.e. outside the eclipse environment)?
What
<br>additional baggage do I need to carry if I use it outside eclipse?
What are
<br>the pros/cons of using EMF over JAXB?
<p>- viraf
<p>"Luiz Marcelo" <lmap@canada.com> wrote in message
<br><a href="news:ba1tgn$ld5$1@rogue.oti.com">news:ba1tgn$ld5$1@rogue.oti.com</a>...
<br>> Check out www.eclipse.org/emf. It is **not** JAXB but it doesn't
<br>everything
<br>> you are asking for and much more.
<br>>
<br>> "Viraf Bankwalla" <viraf_bankwalla@yahoo.com> wrote in message
<br>> <a href="news:ba1h7e$dth$1@rogue.oti.com">news:ba1h7e$dth$1@rogue.oti.com</a>...
<br>> > Hi,
<br>> >
<br>> > I was on Sun's site and came across the JAXB specs. Is there
any plan
<br>on
<br>> > providing JAXB support to this or another eclipse project?
<br>> >
<br>> > I would like to be able to define schemas, use JAXB to create the
<br>> supporting
<br>> > classes, and an XML editor to create documents that conform to
the
<br>schema.
<br>> >
<br>> > Thanks.
<br>> >
<br>> > - viraf
<br>> >
<br>> >
<br>>
<br>></blockquote>
</html>
--------------90C792FD57E6556423AB7754--
| Re: JAXB [message #56419 is a reply to message #56258] |
Mon, 28 July 2003 01:03  |
Originally posted by: bob.objfac.com
Another possibility would be to write a plugin that adds a project nature to
Java projects that adds a build whatever that automatically runs xjc on xsd
files when they are changed. I'm not sure this is the result you or a user
would want, but it is possible to arrange the build order so xjc runs before
the java compiler.
Bob
"Trevor Williams" <twilliams66@netscape.net> wrote in message
news:bfvio3$9j9$1@eclipse.org...
> No need to apologise, any info is appreciated! I was hoping for
> something a little more seamless but Ant should do the trick well
> enough. Thanks much,
> Trevor
> Ed Merks wrote:
> > Trevor,
> > I expect that using Ant there would be a way to do this, but I'm not
really
> > familiar enough with setting up build rules within Eclipse to be able to
provide
> > details. Sorry.
> > Trevor Williams wrote:
> >>Can we do a quick hypothetical? :)
> >>Suppose you're new to Eclipse and you have an existing code base that
> >>uses JAXB to (un)marshall xml documents and object instances. Is there
> >>a way to have Eclipse invoke JAXB's xjc compiler on .xsd files?
> >>Thanks in advance,
> >>Trevor Williams
everything
> >>>>Hi,
on
> >>>supporting
schema.
> >>>>Thanks.
> >>>>- viraf
| Re: JAXB [message #593722 is a reply to message #54062] |
Fri, 16 May 2003 01:37  |
Originally posted by: lmap.canada.com
Check out www.eclipse.org/emf. It is **not** JAXB but it doesn't everything
supporting
> Thanks.
> - viraf
| Re: JAXB [message #593741 is a reply to message #54128] |
Fri, 16 May 2003 08:17  |
- viraf
everything
> > Hi,
on
> supporting
schema.
> > Thanks.
> > - viraf
| Re: JAXB [message #593754 is a reply to message #54155] |
Viraf,
> - viraf
> everything
> > > Hi,
> on
> > supporting
> schema.
> > > Thanks.
> > > - viraf
<html>
Viraf,
What
What are
<p>- viraf
<br>everything
<br>>
<br>> > Hi,
<br>> >
any plan
<br>on
<br>> >
<br>> supporting
the
<br>schema.
<br>> >
<br>> > Thanks.
<br>> >
<br>> > - viraf
<br>> >
<br>> >
<br>>
<br>></blockquote>
</html>
| Re: JAXB [message #594590 is a reply to message #54128] |
Thu, 24 July 2003 01:16  |
Thanks in advance,
Trevor Williams
>>Hi,
> supporting
>>Thanks.
>>- viraf
| Re: JAXB [message #594600 is a reply to message #56080] |
Wed, 23 July 2003 23:07  |
Trevor,
I expect that using Ant there would be a way to do this, but I'm not really
familiar enough with setting up build rules within Eclipse to be able to provide
details. Sorry.
> Thanks in advance,
> Trevor Williams
> >>Hi,
> > supporting
> >>Thanks.
> >>- viraf
| Re: JAXB [message #594662 is a reply to message #56108] |
Sun, 27 July 2003 00:00  |
Trevor
Ed Merks wrote:
> Trevor,
> details. Sorry.
>>Thanks in advance,
>>Trevor Williams
>>>>Hi,
>>>supporting
>>>>Thanks.
>>>>- viraf
| Re: JAXB [message #594700 is a reply to message #56258] |
the java compiler.
Bob
> Trevor
> Ed Merks wrote:
> > Trevor,
really
provide
> > details. Sorry.
> >>Thanks in advance,
> >>Trevor Williams
everything
> >>>>Hi,
on
> >>>supporting
schema.
> >>>>Thanks.
> >>>>- viraf
Current Time: Sun Nov 16 00:02:25 EST 2025
Powered by FUDForum. Page generated in 0.26690 seconds
